1 | /*********
2 | Rui Santos
3 | Complete project details at https://randomnerdtutorials.com/esp8266-nodemcu-access-point-ap-web-server/
4 |
5 | Permission is hereby granted, free of charge, to any person obtaining a copy
6 | of this software and associated documentation files.
7 | The above copyright notice and this permission notice shall be included in all
8 | copies or substantial portions of the Software.
9 | *********/
10 |
11 | // Import required libraries
12 | #include <Arduino.h>
13 | #include <ESP8266WiFi.h>
14 | #include <Hash.h>
15 | #include <ESPAsyncTCP.h>
16 | #include <ESPAsyncWebServer.h>
17 | #include <Adafruit_Sensor.h>
18 | #include <DHT.h>
19 |
20 | const char* ssid = "ESP_Temp";
21 | const char* password = "0123456789";
22 | int channel = 6;
23 | int ssid_hidden = 0;
24 | int max_connection = 8;
25 |
26 |
27 | #define DHTPIN 2 // Digital pin connected to the DHT sensor
28 |
29 | // Uncomment the type of sensor in use:
30 | #define DHTTYPE DHT11 // DHT 11
31 | //#define DHTTYPE DHT22 // DHT 22 (AM2302)
32 | //#define DHTTYPE DHT21 // DHT 21 (AM2301)
33 |
34 | DHT dht(DHTPIN, DHTTYPE);
35 |
36 | // current temperature & humidity, updated in loop()
37 | float t = 0.0;
38 | float h = 0.0;
39 |
40 | // Create AsyncWebServer object on port 80
41 | AsyncWebServer server(80);
42 |
43 | // Generally, you should use "unsigned long" for variables that hold time
44 | // The value will quickly become too large for an int to store
45 | unsigned long previousMillis = 0; // will store last time DHT was updated
46 |
47 | // Updates DHT readings every 10 seconds
48 | const long interval = 10000;
49 |
50 | const char index_html[] PROGMEM = R"rawliteral(
51 | <!DOCTYPE HTML><html>
52 | <head>
53 | <meta name="viewport" content="width=device-width, initial-scale=1">
54 | <style>
55 | html {
56 | font-family: Arial;
57 | display: inline-block;
58 | margin: 0px auto;
59 | text-align: center;
60 | }
61 | h2 { font-size: 3.0rem; }
62 | p { font-size: 3.0rem; }
63 | .units { font-size: 1.2rem; }
64 | .dht-labels{
65 | font-size: 1.5rem;
66 | vertical-align:middle;
67 | padding-bottom: 15px;
68 | }
69 | </style>
70 | </head>
71 | <body>
72 | <h2>ESP8266 DHT Server</h2>
73 | <p>
74 | <span class="dht-labels">Temperature</span>
75 | <span id="temperature">%TEMPERATURE%</span>
76 | <sup class="units">°C</sup>
77 | </p>
78 | <p>
79 | <span class="dht-labels">Humidity</span>
80 | <span id="humidity">%HUMIDITY%</span>
81 | <sup class="units">%</sup>
82 | </p>
83 | </body>
84 | <script>
85 | setInterval(function ( ) {
86 | var xhttp = new XMLHttpRequest();
87 | xhttp.onreadystatechange = function() {
88 | if (this.readyState == 4 && this.status == 200) {
89 | document.getElementById("temperature").innerHTML = this.responseText;
90 | }
91 | };
92 | xhttp.open("GET", "/temperature", true);
93 | xhttp.send();
94 | }, 10000 ) ;
95 |
96 | setInterval(function ( ) {
97 | var xhttp = new XMLHttpRequest();
98 | xhttp.onreadystatechange = function() {
99 | if (this.readyState == 4 && this.status == 200) {
100 | document.getElementById("humidity").innerHTML = this.responseText;
101 | }
102 | };
103 | xhttp.open("GET", "/humidity", true);
104 | xhttp.send();
105 | }, 10000 ) ;
106 | </script>
107 | </html>)rawliteral";
108 |
109 | // Replaces placeholder with DHT values
110 | String processor(const String& var){
111 | //Serial.println(var);
112 | if(var == "TEMPERATURE"){
113 | return String(t);
114 | }
115 | else if(var == "HUMIDITY"){
116 | return String(h);
117 | }
118 | return String();
119 | }
120 |
121 | void setup(){
122 | // Serial port for debugging purposes
123 | Serial.begin(115200);
124 | dht.begin();
125 |
126 | Serial.print("Setting AP (Access Point)…");
127 | // Remove the password parameter, if you want the AP (Access Point) to be open
128 | WiFi.softAP(ssid, password, channel, ssid_hidden, max_connection);
129 |
130 | IPAddress IP = WiFi.softAPIP();
131 | Serial.print("AP IP address: ");
132 | Serial.println(IP);
133 |
134 | // Print ESP8266 Local IP Address
135 | Serial.println(WiFi.localIP());
136 |
137 | // Route for root / web page
138 | server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
139 | request->send_P(200, "text/html", index_html, processor);
140 | });
141 | server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
142 | request->send_P(200, "text/plain", String(t).c_str());
143 | });
144 | server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
145 | request->send_P(200, "text/plain", String(h).c_str());
146 | });
147 |
148 | // Start server
149 | server.begin();
150 | }
151 |
152 | void loop(){
153 | unsigned long currentMillis = millis();
154 | if (currentMillis - previousMillis >= interval) {
155 | // save the last time you updated the DHT values
156 | previousMillis = currentMillis;
157 | // Read temperature as Celsius (the default)
158 | float newT = dht.readTemperature();
159 | // Read temperature as Fahrenheit (isFahrenheit = true)
160 | //float newT = dht.readTemperature(true);
161 | // if temperature read failed, don't change t value
162 | if (isnan(newT)) {
163 | Serial.println("Failed to read from DHT sensor!");
164 | }
165 | else {
166 | t = newT;
167 | Serial.println(t);
168 | }
169 | // Read Humidity
170 | float newH = dht.readHumidity();
171 | // if humidity read failed, don't change h value
172 | if (isnan(newH)) {
173 | Serial.println("Failed to read from DHT sensor!");
174 | }
175 | else {
176 | h = newH;
177 | Serial.println(h);
178 | }
179 | }
180 | }
