1 | avrdude -B16 -vvv -P /dev/ttyACM0 -c stk500 -p t2313 -Uflash:w:blink.hex:a
2 |
3 | avrdude: Version 6.3-20171130
4 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
5 | Copyright (c) 2007-2014 Joerg Wunsch
6 |
7 | System wide configuration file is "/etc/avrdude.conf"
8 | User configuration file is "~/.avrduderc"
9 | User configuration file does not exist or is not a regular file, skipping
10 |
11 | Using Port : /dev/ttyACM0
12 | Using Programmer : stk500
13 | Setting bit clk period : 16.0
14 | avrdude: stk500v2_getsync(): found STK500 programmer
15 | avrdude: Skipping parameter write; parameter value already set.
16 | AVR Part : ATtiny2313
17 | Chip Erase delay : 9000 us
18 | PAGEL : PD4
19 | BS2 : PD6
20 | RESET disposition : possible i/o
21 | RETRY pulse : SCK
22 | serial program mode : yes
23 | parallel program mode : yes
24 | Timeout : 200
25 | StabDelay : 100
26 | CmdexeDelay : 25
27 | SyncLoops : 32
28 | ByteDelay : 0
29 | PollIndex : 3
30 | PollValue : 0x53
31 | Memory Detail :
32 |
33 | Block Poll Page Polled
34 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
35 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
36 | eeprom 65 6 4 0 no 128 4 0 4000 4500 0xff 0xff
37 | Block Poll Page Polled
38 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
39 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
40 | flash 65 6 32 0 yes 2048 32 64 4500 4500 0xff 0xff
41 | Block Poll Page Polled
42 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
43 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
44 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
45 | Block Poll Page Polled
46 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
47 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
48 | lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
49 | Block Poll Page Polled
50 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
51 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
52 | lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
53 | Block Poll Page Polled
54 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
55 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
56 | hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
57 | Block Poll Page Polled
58 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
59 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
60 | efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
61 | Block Poll Page Polled
62 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
63 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
64 | calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
65 |
66 | Programmer Type : STK500V2
67 | Description : Atmel STK500
68 | Programmer Model: STK500
69 | Hardware Version: 10
70 | Firmware Version Master : 2.10
71 | avrdude: stk500v2_command(): command failed
72 | avrdude: stk500v2_getparm(): failed to get parameter 0x9a
73 | Topcard : Unknown
74 | Vtarget : 5.0 V
75 | SCK period : 17.4 us
76 | Varef : 5.0 V
77 | Oscillator : Off
78 |
79 | avrdude: AVR device initialized and ready to accept instructions
80 |
81 | Reading | | 0% 0.00savrdude: stk500isp_read_byte(.., signature, 0x0, ...)
82 | avrdude: stk500isp_read_byte(): Sending read memory command: avrdude: stk500isp_read_byte(.., signature, 0x1, ...)
83 | Reading | ################# | 33% 0.00savrdude: stk500isp_read_byte(.., signature, 0x2, ...)
84 | Reading | ################################################## | 100% 0.00s
85 |
86 | avrdude: Device signature = 0x1e010a
87 | avrdude: Expected signature for ATtiny2313 is 1E 91 0A
88 | Double check chip, or use -F to override this check.
89 |
90 | avrdude done. Thank you.
