gdb problem mit openocd
Gast #6598528
ich habe Probleme mit meinem SAMD21 Xplainded board. Ich
programmiere/debugge bereits seit einem tag mit openocd und gdb und nun
auf einmal erhalte ich die meldung, dass der gdb nicht mehr auf das
device zugreifen kann:
blah@blah:~/Desktop/samd21/blinky-2302$ openocd
Open On-Chip Debugger 0.9.0 (2018-01-24-01:05)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'swd'
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 03.25.01B6
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 500 kHz
Info : SWD IDCODE 0x0bc11477
Error: Failed to read memory and, additionally, failed to find out where
Polling target at91samd21j18a.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
23
Examination failed, GDB will be halted. Polling again in 700ms
24
25
Examination failed, GDB will be halted. Polling again in 1500ms
26
27
Examination failed, GDB will be halted. Polling again in 3100ms
28
die openocd config:
# Atmel-ICE JTAG/SWD in-circuit debugger.
# get serial: lsusb -vd 03eb:2111 | grep iSerial
interface cmsis-dap
#cmsis_dap_vid_pid 0x03eb 0x2111
#cmsis_dap_serial ATML2130021800030238
# Chip info
set CHIPNAME at91samd21j18a
source [find target/at91samdXX.cfg]
dmeseg sagt:
[24771.247890] usb 3-2: new high-speed USB device number 15 using xhci_hcd
[24771.565383] usb 3-2: config 1 interface 2 altsetting 0 bulk endpoint 0x84 has invalid maxpacket 64
[24771.565408] usb 3-2: config 1 interface 2 altsetting 0 bulk endpoint 0x5 has invalid maxpacket 64
[24771.566527] usb 3-2: New USB device found, idVendor=03eb, idProduct=2169
[24771.566529] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[24771.566530] usb 3-2: Product: EDBG CMSIS-DAP
[24771.566531] usb 3-2: Manufacturer: Atmel Corp.
[24771.566532] usb 3-2: SerialNumber: ATML2130031800038334
[24771.570909] hid-generic 0003:03EB:2169.000C: hiddev0,hidraw1: USB HID v1.11 Device [Atmel Corp. EDBG CMSIS-DAP] on usb-0000:03:00.0-2/input0
[24771.570999] cdc_acm 3-2:1.1: ttyACM0: USB ACM device
[24771.571399] usb-storage 3-2:1.3: USB Mass Storage device detected
[24771.572173] scsi host42: usb-storage 3-2:1.3
[24772.573450] scsi 42:0:0:0: Direct-Access     ATMEL    EDBG             1.00 PQ: 0 ANSI: 3
[24772.574133] sd 42:0:0:0: Attached scsi generic sg2 type 0
[24772.574899] sd 42:0:0:0: [sdb] 4096 512-byte logical blocks: (2.10 MB/2.00 MiB)
[24772.575791] sd 42:0:0:0: [sdb] Write Protect is off
[24772.575793] sd 42:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[24772.576746] sd 42:0:0:0: [sdb] No Caching mode page found
[24772.576748] sd 42:0:0:0: [sdb] Assuming drive cache: write through
[24772.580202]  sdb:
[24772.586103] sd 42:0:0:0: [sdb] Attached SCSI removable disk
#6598586
Aus den dmesg-Meldungen werde ich jetzt nicht direkt schlau aber ein
typischer Fehler, der bei OpenOCD in ein Timeout führt, ist wenn man die
SWD-Pins fälschlicherweise "umkonfiguriert".
Schau also mal ins Datenblatt deines Controllers, mache aus welche Pins
das sind und schaue dann mal scharf in deinen Quellcode ob du da nicht
irgendeinen der beiden Pins für etwas anderes hergenommen hast.
Bei STM32 ist eine sehr einfache Möglichkeit die SWD-Pins wieder in
einen funktionalen Zustand zu versetzen, den Controller per Boot-Pin in
irgendeinen ROM-Bootloader zu booten (sei es UART, USB, ganz egal), denn
innerhalb dieses ROM-Bootloaders sind die SWD-Pins eben für SWD
konfiguriert. Wie das jetzt im Detail bei Atmel aussieht kann ich nicht
sagen. ymmv
Gast #6599182
Hex danke für den Hinweis. Mit dem Microchip Studio habe ich ein
Beispiel auf den Controller schreiben können. Jetzt kann ich wieder ein
älteres programm mittel openocd drauf spielen.
PA30 und PA31 wären die PINS für das SWD, aber diese Überschreibe ich
nicht. Ich probiere mich gerade an dem TC3 (zunächste einfache PWM) aus
und wollte den TC3 auf PA14 legen. Kann es sein, dass der µC hängt, weil
ich z.b. den Clock garnicht richtig initialisiert habe?
Gast #6599550
Klar kann das sein. Einige I/O Funktionen lösen einen Hardfault aus,
wenn man drauf zugreifen will bevor ihr Takt aktiviert ist.
Zumindest ist das bei STM so.
Gast #6600710
Ok, der OPENOCD kam per SWD nicht mehr auf den µC drauf. Was machen dann
solche tools wie microchip Studio anders, .. ich meine mit diesem Tool
habe ich irgendein beispiel drauf geflasht und erst danach konnte ich
OPENOCD wieder nutzen. Ginge das nicht auch mit OPENOCD?
#6601230
Ja, das geht auch mit OpenOCD und wird oft als "connect under reset"
bezeichnet.
Das funktioniert so, dass man das Target resettet. Entweder macht man
das per OpenOCD mittels Resetleitung des Debug-Adapters oder man macht
das manuell per Reset-Taster des Targets.
Manuell geht das dann so:
- Resetbutton drücken und gedrückt halten
- OpenOCD Verbindung starten
- Resetbutton loslassen
Das funktioniert, weil die SWD-Pins nach einem Reset (bei mir bekannten
Controllern) "korrekt konfiguriert" sind und der Debug-Adapter so mit
dem Target kommunizieren kann, bevor der Code geladen wird, der die
SWD-Pins umkonfiguriert.
#6602373
Jim M. schrieb:
>> bezeichnet.
> Vorsicht: Funktioniert bei einigen µCs, aber bei vielen anderen wird mit
> der Reset Leitung auch das Debug Interface abgeklemmt.
Das ist ein guter Punkt aber im Fall des SAMD geben die OpenOCD-Quellen
direkt die Antwort:
# SAMD DSU will hold the CPU in reset if TCK is low when RESET_N
# deasserts (see datasheet Atmel-42181E–SAM-D21_Datasheet–02/2015, section 12.6.2)
# dsu_reset_deassert configures whether we want to run or halt out of reset,
# then instruct the DSU to let us out of reset.
$_TARGETNAME configure -event reset-deassert-post {
        at91samd dsu_reset_deassert
# SRST (wired to RESET_N) resets debug circuitry
# srst_pulls_trst is not configured here to avoid an error raised in reset halt
reset_config srst_gates_jtag
# Do not use a reset button with other SWD adapter than Atmel's EDBG.
# DSU usually locks MCU in reset state until you issue a reset command
# in OpenOCD.
Interessanterweise liegt da wohl auch was im Argen und wenn man sich die
älteren OpenOCD-Quellen anschaut, war dort die Resetkonfiguration leicht
verändert:
reset_config srst_gates_jtag srst_pulls_trst
Da ich hier kein Xplained-Board zum testen rumfliegen habe, kann ich das
auch nicht genau nachvollziehen. Das kann ja bei Gelegenheit der TO mal
machen und berichten. Der Code stammt direkt aus dem target.tcl aus dem
OpenOCD-Mirror von hier:
https://github.com/ntfreak/openocd/blob/master/tcl/target/at91samdXX.cfg
