1 | mkdir -p build/output/samples
2 | mkdir -p build/output/test
3 | echo OSTYPE is Linux
4 | OSTYPE is Linux
5 | mkdir -p /usr/local/include
6 | install -m 644 build/output/libpaho-mqtt3c.so.1.0 /usr/local/lib
7 | install -m 644 build/output/libpaho-mqtt3cs.so.1.0 /usr/local/lib
8 | install -m 644 build/output/libpaho-mqtt3a.so.1.0 /usr/local/lib
9 | install -m 644 build/output/libpaho-mqtt3as.so.1.0 /usr/local/lib
10 | install build/output/paho_c_version /usr/local/bin
11 | install build/output/samples/paho_c_pub /usr/local/bin
12 | install build/output/samples/paho_c_sub /usr/local/bin
13 | install build/output/samples/paho_cs_pub /usr/local/bin
14 | install build/output/samples/paho_cs_sub /usr/local/bin
15 | /sbin/ldconfig /usr/local/lib
16 | ln -s libpaho-mqtt3c.so.1 /usr/local/lib/libpaho-mqtt3c.so
17 | ln -s libpaho-mqtt3cs.so.1 /usr/local/lib/libpaho-mqtt3cs.so
18 | ln -s libpaho-mqtt3a.so.1 /usr/local/lib/libpaho-mqtt3a.so
19 | ln -s libpaho-mqtt3as.so.1 /usr/local/lib/libpaho-mqtt3as.so
20 | install -m 644 src/MQTTAsync.h /usr/local/include
21 | install -m 644 src/MQTTClient.h /usr/local/include
22 | install -m 644 src/MQTTClientPersistence.h /usr/local/include
23 | install -m 644 src/MQTTProperties.h /usr/local/include
24 | install -m 644 src/MQTTReasonCodes.h /usr/local/include
25 | install -m 644 src/MQTTSubscribeOpts.h /usr/local/include
26 | install -m 644 doc/man/man1/paho_c_pub.1 /usr/local/share/man/man1
27 | install -m 644 doc/man/man1/paho_c_sub.1 /usr/local/share/man/man1
28 | install -m 644 doc/man/man1/paho_cs_pub.1 /usr/local/share/man/man1
29 | install -m 644 doc/man/man1/paho_cs_sub.1 /usr/local/share/man/man1
30 | install -m 644 build/output/doc/MQTTClient/man/man3/MQTTClient.h.3 /usr/local/sh are/man/man3
31 | install: cannot stat 'build/output/doc/MQTTClient/man/man3/MQTTClient.h.3': No s uch file or directory
32 | make: [Makefile:303: install] Error 1 (ignored)
33 | install -m 644 build/output/doc/MQTTAsync/man/man3/MQTTAsync.h.3 /usr/local/shar e/man/man3
34 | install: cannot stat 'build/output/doc/MQTTAsync/man/man3/MQTTAsync.h.3': No suc h file or directory
35 | make: [Makefile:304: install] Error 1 (ignored)
