I have a STM32F411RE nucleo board which I connect to an external button. The button is connected via following pins: +5V, GND and GPIO_PIN_8 (PB_8) I also have the USART connection to PUTTY. My code does the follows: when the button is pressed, the onboard green LED is on. In PUTTY the message "button is pressed" is shown. when the button is not pressed, the onboard green LED is off and in PUTTY the message "button not pressed" is shown. I would like to save the input from GPIO_PIN_8 in some form of file either directly on an external drive (microsd oder usb) so that I can open it later on. Since the STM32F411RE does not have EEPROM functionality, I read that storing data to flash memory is an option. Could someone explain to me a) how can I store data in flash memory b) how can I "export" data from flash memory to a readable file later on Any help appreciated, thanks guys
Max M. schrieb: > a) how can I store data in flash memory https://stackoverflow.com/questions/54159802/how-to-write-to-stm32-flash
thank you very much. Now I have to find out how to access the flash memory as a file 😅
Max M. schrieb: > Now I have to find out how to access the flash > memory as a file No. Now first you will have to learn how to really program your problem regarding item a)
