An Efficient VLSI Architecture for Removal of Impulse Noise in Image : This project aims to reinforce the visual quality of images and to avoid chances of being corrupted by impulse noise by implementing an efficient VLSI architecture using edge preserving filters.The main aim of this project is to assist with image coding so as to supply high accurate images without losing any information. The plan of this VLSI Project for M.Tech is to implement a modified booth encoder using a 4 bit SFQ multiplier which gives better performance as compared to the conventional booth encoder. https://takeoffprojects.com/VLSI-Projects-for-MTech A Processor-In-Memory Architecture for Multimedia Compression: This project presents the implementation of a coffee complexity processor-in –memory architecture that supports multimedia applications like video and compression by applying very large command word and single-instruction and multiple data concepts.
