Hallo, wir haben hier ein Board mit einem LPC54113 und bekommen den nicht mit einem segger j-link programmiert. Wir haben schon mehrere Boards und Programmer getestet, immer mit dem gleichen Ergebnis. Connect funktioniert noch, alles weitere aber nicht mehr ... Log File : Connecting ... - Connecting via USB to probe/ programmer device 0 - Device "LPC54113J256_M4" selected. - Target interface speed: 100 kHz (Fixed) - VTarget = 3.291V - Found SW-DP with ID 0x2BA01477 - DPIDR: 0x2BA01477 - Scanning AP map to find all available APs - AP[1]: Stopped AP scan as end of AP map has been reached - AP[0]: AHB-AP (IDR: 0x24770011) - Iterating through AP map to find AHB-AP to use - AP[0]: Core found - AP[0]: AHB-AP ROM base: 0xE00FF000 - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) - Found Cortex-M4 r0p1, Little endian. - FPUnit: 6 code (BP) slots and 2 literal slots - CoreSight components: - ROMTbl[0] @ E00FF000 - ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 - ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT - ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB - ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM - ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU - Executing init sequence ... - Initialized successfully - Target interface speed: 100 kHz (Fixed) - CPU clock frequency: 5981 kHz (Auto detected) - Found 1 JTAG device. Core ID: 0x2BA01477 (None) - Connected successfully Blank checking target ... - 8 of 8 sectors selected, 1 range, 0x0 - 0x3FFFF - Start of preparing flash programming - ERROR: Failed to download RAMCode. - ERROR: Failed to prepare for programming. Failed to download RAMCode! - End of preparing flash programming - Start of restoring - End of restoring - ERROR: Failed to check blank target Disconnecting ... - Disconnected Hat jemand eine Ahnung was das sein kann? Andreas
Andreas R. schrieb: > Found 1 JTAG device. Core ID: 0x2BA01477 (None) Segger Version zu alt? Mal die neueste JLink Version von Segger.com ausprobiert?
