Forum: PC Hard- und Software DHCP geht, Ping nicht. Wtf?
von Frank K. (fchk)
Hallo!
Gegen ist:
- ein Olimex A20-SOM204-EVB
(https://www.olimex.com/Products/SOM204/A20-SOM204-EVB/)
- darauf ein frisch installiertes Debian Image vom hier:
https://images.olimex.com/release/a20/ (und hier das Base Image)
root@a20-olinuxino:~# uname -a
Linux a20-olinuxino 5.10.105-olimex #090538 SMP Wed Apr 13 09:06:56 UTC 2022 armv7l GNU/Linux
root@a20-olinuxino:~# cat /etc/debian_version
Problem:
1. Ethernet Link ist da.
root@a20-olinuxino:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP    MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: No
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 100Mb/s
        Duplex: Full
        Auto-negotiation: on
        Port: MII
23
        PHYAD: 1
24
        Transceiver: external
25
        Current message level: 0x00000000 (0)
26
27
        Link detected: yes
2. DHCP funktioniert:
root@a20-olinuxino:~# cat /etc/network/interfaces.d/eth0
allow-hotplug eth0
iface eth0 inet dhcp
root@a20-olinuxino:~# ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether 76:77:ca:dd:2f:ad  txqueuelen 1000  (Ethernet)
        RX packets 195  bytes 39501 (38.5 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 37  base 0x6000
root@a20-olinuxino:~# dhclient eth0
        inet 192.168.235.242  netmask 255.255.255.0  broadcast 192.168.235.255
        RX packets 382  bytes 76806 (75.0 KiB)
        TX packets 17  bytes 2759 (2.6 KiB)
23
24
root@a20-olinuxino:~# netstat -rn
25
Kernel IP routing table
26
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
27
0.0.0.0         192.168.235.2   0.0.0.0         UG        0 0          0 eth0
28
192.168.235.0   0.0.0.0         255.255.255.0   U         0 0          0 eth0
Er bekommt also IP-Adresse und Default Gateway. Im Prinzip muss das
Netzwerk funktionieren.
3. Tut es aber nicht. Kein Ping, kein nichts.
root@a20-olinuxino:~# ping 192.168.235.2
PING 192.168.235.2 (192.168.235.2) 56(84) bytes of data.
From 192.168.235.242 icmp_seq=1 Destination Host Unreachable
From 192.168.235.242 icmp_seq=5 Destination Host Unreachable
From 192.168.235.242 icmp_seq=8 Destination Host Unreachable
^C
--- 192.168.235.2 ping statistics ---
12 packets transmitted, 0 received, +3 errors, 100% packet loss, time 11250ms
Das ist eine Fritzbox, das geht von woanders.
Auch Ping von außen auf die Kiste geht nicht.
iptables sind leer.
root@a20-olinuxino:~# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
WTF. Was kann das sein?
fchk
von Hmmm (Gast)
Ist es gewollt, dass das Interface nur eine lokale MAC-Adresse hat? Wenn
ja, ist die in Deinem Netz eindeutig?
Auf jeden Fall gingen schonmal Pakete rein und raus.
Klingt danach, dass der ARP-Request schiefgeht. Wie sieht die ARP-Table
aus, und was siehst Du mit tcpdump?
von Frank K. (fchk)
Keine Ahnung, wo die herkommt. Im Uboot steht eine andere. Die hab ich
auch mal übernommen (mit hwaddress ether ....), hat aber nichts
geändert.
root@a20-olinuxino:/etc# arp -an
? (192.168.235.2) at <incomplete> on eth0
? (192.168.235.1) at <incomplete> on eth0
tcpdump ist auf dem System nicht vorhanden, und ohne Netz tu ich mich
auch etwas schwer, da was nachzuinstallieren.
fchk
von Thomas W. (Gast)
ein
  arp -s fritte 11:22:33:44:55:66
koennte Dir helfen. Das schreibt Dir einen Host in die Arp-Tabelle. Die
MAC-Adresse der Fritzbox natuerlich einsetzen.
Gruesse
Th.
von c-hater (Gast)
Ja, es klemmt also ganz klar an arp. Allerdings: so ein Fehlerbild habe
ich noch niemals gesehen. Das wird vermutlich schwierig.
Dann hast du noch zwei Chancen (die allerdings beide einen weiteren
Rechner benötigen):
1) Monitorport am Switch einrichten und Rechner als Sniffer für den
ausgeleiteten Traffic.
2) Rechner mit zwei NICs als Bridge zwischen diesem Olimex-Teil und dem
Switch als Sniffer.
BTW: Vor allem anderen würde ich erstmal ein anderes Patchkabel
probieren. Nicht dass ein beschädigtes Kabel die Ursache des Spuks ist.
von oszi40 (Gast)
Wenn es kein krankes Patchkabel war, würde ich auch mal ICMP prüfen ob
ein. https://de.wikipedia.org/wiki/Internet_Control_Message_Protocol
von c-hater (Gast)
> ein.
ICMP prüfen ergibt keinen Sinn, wenn schon ARP nachweislich nicht geht.
ICMP ist schließlich zwingend auf ARP angewiesen, um funktionieren zu
können.
von oszi40 (Gast)
Sorry, so genau habe ich nicht gelesen. Dafür bin ich schon öfter von
abgestelltem ICMP überlistet worden. ping 127.0.0.1 wäre auch
interessant.
von Frank K. (fchk)
Das Kabel ist nachweislich in Ordnung. Ich hatte noch einen 100M
USB-Ethernet-Adapter, und damit konnte ich erstmal Pakete
nachinstallieren. Das scheint mir irgendeine Treibersache zu sein. Keine
Ahnung. Ich muss mal Olimex fragen.
fchk
von Hmmm (Gast)
Dann lass tcpdump auf dem angepingten System laufen.
Der ARP-Request geht sowieso als Broadcast raus, wäre also für jedes
System im gleichen Netz sichtbar, und wenn tcpdump auf dem angepingten
System läuft, siehst Du auch noch den Rest.
Wäre einen Versuch wert. Passt zwar nur teilweise zu den Symptomen, weil
DHCP funktioniert, aber sporadische Ausfälle und Murphy's Law machen es
durchaus denkbar.
von c-hater (Gast)
Gut, wenn man das erstmal sicher weiß ;o)
Nun ja, der Netzwerk-Stack funktioniert ja nachweislich in vielen
Millionen Geräten. Da bleiben dann eigentlich nur die Treiber oder
defekte Hardware.
von foobar (Gast)
Oder die 192.168.235.2 ist (warum auch immer) verkehrt.  Ist das
tatsächlich die IP des Ethernetports der Fritzbox?  Mal nen Ping auf die
Broadcastadresse gemacht (ping -b 192.168.235.255)?
Beitrag #7051011 wurde von einem Moderator gelöscht.
von Manfred (Gast)
Du kannst Dich mal bei mir ans Gastenetz klemmen: Du bekommst per DHCP
eine IP samt Gateway zugewiesen und kannst gerne auf p0rnoslon.ru nackte
xxx angucken, aber bekommst auf Ping weder vom Router noch von anderen
lokalen Maschinen eine Antwort.
Im vertrauenswürdig lokalen Netz sind die natürlich erlaubt.
Guckst Du mal ptbtime3.ptb.de, der liefert zuverlässig die Uhrzeit, aber
Ping versickert im Timeout.
Es kann also gewollt sein, Ping nicht zu beantworten, ohne dass ein
Fehler vorliegt.
Wenn das nicht vorsätzlich so eingerichtet ist, kommt immer noch eine
fehlende Route in Frage, das Ziel kennt den Rückweg nicht.
von (prx) A. K. (prx)
Es ist eine Sache, auf Ping keine Antwort zu erhalten (timeout). Eine
andere aber, den Frame überhaupt nicht in Netz zu kriegen (unreachable).
von Manfred (Gast)
"unreachable" würde ich interpretieren, dass das Ziel in einem anderen
Netz liegt und das Gateway fehlt.
von Markus M. (adrock)
Ja, oder eben im gleichen Subnetz und arp funktioniert nicht. Genau das
ist hier der Fall (siehe oben, arp incomplete). Das hat nichts mit
geblocktem ICMP echo-request o.ä. zu tun.
Dann gibts nicht "destination host unreachable" wie hier, sondern
"network is unreachable".
Probier es aus: Pinge ein existierendes Gerät an, und während das läuft,
schalte es aus oder zieh es aus dem Netz. Das läuft auf 2 Varianten
raus, gleich oder mit der Zeit:
ARP Eintrag existiert => timeout
ARP Eintrag incomplete => host unreachable
Deshalb haben hier schon einige Leute zurecht auf ARP Problem erkannt.
von foobar (Gast)
Oder halt eben auch, wenn es den Rechner/die IP einfach nicht gibt.
Genau die gleiche Meldung, die gleichen ARP-Einträge gibt es, wenn er
z.B. den (nicht existierenden) 192.168.235.66 anpingen würde.
Deshalb die Frage: ist 192.168.235.2 die korrekte Adresse des
Ethernetports der Fritzbox?  Kannst du die von einer anderen Kiste aus
mit der Adresse anpingen?
Er arbeitet mit DHCP und im Startbeitrag steht die daraus abgeleitete
Default-Route auf .2. Um das falsch zu machen muss man schon mit Absicht
Mist bauen.
Yep, hier wird es interessant. Lokale Adresse heisst, die ist selbst
vergeben, nicht offiziell definiert. Bei Bastelkram mit µC ist das nicht
ungewöhnlich. Aber wehe man verwendet die gleiche mehrfach.
Wird bei den Fritzbox-Ports schwierig. Und wer hat privat schon Switches
mit Mirrorport? Vielleicht hat man aber im Karton mit Hardware-Schrott
noch einen 10- oder 100-Mbit Hub liegen.
von DPA (Gast)
Versuche mal sämtliches checksum offloading auszuschalten: "ethtool -K
eth0 tx off rx off"
https://linux.die.net/man/8/ethtool
Vielleicht ist das in der Karte ja kaputt.
von c-hater (Gast)
Das stimmt, das Ergebnis bei arp -a sieht dann genauso aus.
Das sollte man auf jeden Fall probieren/überprüfen. Es gibt nämlich ein
Szenario, bei dem das Gezeigte passieren könnte ganz ohne Hardware- oder
Treiberprobleme. Das wäre ein "parasitärer" DHCP-Server im Netz,
zusätzlich zu dem der Fritzbox, z.B. einer, der auf der Olimex-Kiste
selber läuft...
Da der DHCP-Offer ein Broadcast ist, könnte man das auf jedem Rechner im
Netz problemlos mit tcpdump sehen, also ohne jede Bastelmaßnahme.
von PC-Freak (Gast)
> Fehler vorliegt.
Das schimpft sich dann 'stealth modus'. Und kann man einstellen im
Router.
Ist hier aber nicht anwendbar. Ein (IP-) Router, der auf ARP nicht
reagiert, der ist derart stealthy, dass er ohne manuellem ARP auch nicht
routet, sondern nur unnütz Strom verbraucht.
Ein Gerät, das auf ARP reagiert, aber nicht auf PING, ergibt kein "host
not reachable", sondern timeouts.
NB: Mindestens in Linux gibts auch ein "arping", eine Version von
"ping", die nicht nur über ICMP, sondern auch über ARP arbeiten kann.
von Michael W. (dbru61)
Auf der Fritzbox kann man unter der Adresse
ip-Adresse-der-Fritzbox/html/capture.html Packetmitschnitte machen.
Vielleicht hilfts ja bei der Fehlersuche.
Viel Erfolg
von oszi40 (Gast)
Es muß ja nicht immer eine Fritzbox sein.
Er könnte auch über ein Crosskabel zu einem 2.PC mit fester Nachbar-IP
gehen um herauszubekommen ob das Übel evtl. an der Treiber-SW liegt und
ob diese Karte grundsätzlich noch gesund ist?
