1 | ELF file SHA256: 8a4bae0599313399
2 |
3 | Rebooting...
4 | ets Jun 8 2016 00:22:57
5 |
6 | rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
7 | configsip: 0, SPIWP:0xee
8 | clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
9 | mode:DIO, clock div:2
10 | load:0x3fff0030,len:6608
11 | load:0x40078000,len:14788
12 | ho 0 tail 12 room 4
13 | load:0x40080400,len:3792
14 | 0x40080400: _init at ??:?
15 |
16 | entry 0x40080694
17 | I (29) boot: ESP-IDF v4.4.1 2nd stage bootloader
18 | I (29) boot: compile time 16:40:24
19 | I (29) boot: chip revision: 1
20 | I (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0
21 | I (39) boot.esp32: SPI Speed : 40MHz
22 | I (43) boot.esp32: SPI Mode : DIO
23 | I (48) boot.esp32: SPI Flash Size : 2MB
24 | I (52) boot: Enabling RNG early entropy source...
25 | I (58) boot: Partition Table:
26 | I (61) boot: ## Label Usage Type ST Offset Length
27 | I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000
28 | I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000
29 | I (84) boot: 2 factory factory app 00 00 00010000 00100000
30 | I (91) boot: End of partition table
31 | I (95) boot_comm: chip revision: 1, min. application chip revision: 0
32 | I (102) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=137d8h ( 79832) map
33 | I (140) esp_image: segment 1: paddr=00023800 vaddr=3ffb0000 size=03804h ( 14340) load
34 | I (146) esp_image: segment 2: paddr=0002700c vaddr=40080000 size=0900ch ( 36876) load
35 | I (161) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=6d5ech (447980) map
36 | I (324) esp_image: segment 4: paddr=0009d614 vaddr=4008900c size=0b318h ( 45848) load
37 | I (343) esp_image: segment 5: paddr=000a8934 vaddr=50000000 size=00010h ( 16) load
38 | I (353) boot: Loaded app from partition at offset 0x10000
39 | I (353) boot: Disabling RNG early entropy source...
40 | I (365) cpu_start: Pro cpu up.
41 | I (365) cpu_start: Starting app cpu, entry point is 0x40081184
42 | 0x40081184: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v4.4.1/components/esp_system/port/cpu_start.c:160
43 |
44 | I (351) cpu_start: App cpu up.
45 | I (379) cpu_start: Pro cpu start user code
46 | I (380) cpu_start: cpu freq: 160000000
47 | I (380) cpu_start: Application information:
48 | I (384) cpu_start: Project name: network_time_protocol
49 | I (390) cpu_start: App version: cfe213f-dirty
50 | I (396) cpu_start: Compile time: Jul 5 2022 16:39:35
51 | I (402) cpu_start: ELF file SHA256: 8a4bae0599313399...
52 | I (408) cpu_start: ESP-IDF: v4.4.1
53 | I (413) heap_init: Initializing. RAM available for dynamic allocation:
54 | I (420) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
55 | I (426) heap_init: At 3FFB74A8 len 00028B58 (162 KiB): DRAM
56 | I (432) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
57 | I (438) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
58 | I (445) heap_init: At 40094324 len 0000BCDC (47 KiB): IRAM
59 | I (452) spi_flash: detected chip: generic
60 | I (456) spi_flash: flash io: dio
61 | W (460) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
62 | I (474) cpu_start: Starting scheduler on PRO CPU.
63 | I (0) cpu_start: Starting scheduler on APP CPU.
64 | I (484) main: Starting program
65 | I (534) main: Done nvs_flash_init
66 | I (534) main: Starting Tasks
67 | I (544) wifi station: start wifiTask
68 | I (574) wifi:wifi driver task: 3ffc6104, prio:23, stack:6656, core=0
69 | I (574) system_api: Base MAC address is not set
70 | I (574) system_api: read default base MAC address from EFUSE
71 | I (604) wifi:wifi firmware version: 63017e0
72 | I (604) wifi:wifi certification version: v7.0
73 | I (604) wifi:config NVS flash: enabled
74 | I (604) wifi:config nano formating: disabled
75 | I (604) wifi:Init data frame dynamic rx buffer num: 32
76 | I (614) wifi:Init management frame dynamic rx buffer num: 32
77 | I (614) wifi:Init management short buffer num: 32
78 | I (624) wifi:Init dynamic tx buffer num: 32
79 | I (624) wifi:Init static rx buffer size: 1600
80 | I (624) wifi:Init static rx buffer num: 10
81 | I (634) wifi:Init dynamic rx buffer num: 32
82 | I (644) wifi_init: rx ba win: 6
83 | I (644) wifi_init: tcpip mbox: 32
84 | I (644) wifi_init: udp mbox: 6
85 | I (644) wifi_init: tcp mbox: 6
86 | I (654) wifi_init: tcp tx win: 5744
87 | I (654) wifi_init: tcp rx win: 5744
88 | I (664) wifi_init: tcp mss: 1440
89 | I (664) wifi_init: WiFi IRAM OP enabled
90 | I (674) wifi_init: WiFi RX IRAM OP enabled
91 | I (694) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
92 | I (794) wifi:mode : sta (24:62:ab:e0:1b:c0)
93 | I (794) wifi:enable tsf
94 | I (794) event handler: WIFI_EVENT_STA_START
95 | I (794) wifi station: wifi_init_sta finished.
96 | I (804) wifi:new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
97 | I (804) wifi:state: init -> auth (b0)
98 | I (814) wifi:state: auth -> assoc (0)
99 | I (824) wifi:state: assoc -> run (10)
100 | I (834) wifi:connected with FRITZ!Box Fon WLAN 7360, aid = 5, channel 1, 40U, bssid = 9c:c7:a6:ef:08:93
101 | I (834) wifi:security: WPA2-PSK, phy: bgn, rssi: -49
102 | I (844) wifi:pm start, type: 1
103 |
104 | I (844) event handler: WIFI_EVENT_STA_CONNECTED
105 | I (934) wifi:AP's beacon interval = 102400 us, DTIM period = 1
106 | W (1044) wifi:<ba-add>idx:0 (ifx:0, 9c:c7:a6:ef:08:93), tid:0, ssn:0, winSize:64
107 | I (3044) esp_netif_handlers: sta ip: 192.168.10.38, mask: 255.255.255.0, gw: 192.168.10.1
108 | I (3044) event handler: IP_EVENT_STA_GOT_IP
109 | I (3044) event handler: got ip:192.168.10.38
110 | I (3064) wifi station: connected to ap SSID:FRITZ!Box Fon WLAN 7360 password:
111 |
112 | assert failed: spinlock_acquire spinlock.h:123 ((result == SPINLOCK_FREE) == (lock->count == 0))
113 |
114 |
115 | Backtrace:0x400819f2:0x3ffc13100x400883b9:0x3ffc1330 0x4008ef25:0x3ffc1350 0x4008b725:0x3ffc1470 0x4008b26d:0x3ffc1490 0x400d5ed4:0x3ffc14c0 0x4008b545:0x3ffc1650
116 | 0x400819f2: panic_abort at C:/Espressif/frameworks/esp-idf-v4.4.1/components/esp_system/panic.c:402
117 |
118 | 0x400883b9: esp_system_abort at C:/Espressif/frameworks/esp-idf-v4.4.1/components/esp_system/esp_system.c:128
119 |
120 | 0x4008ef25: __assert_func at C:/Espressif/frameworks/esp-idf-v4.4.1/components/newlib/assert.c:85
121 |
122 | 0x4008b725: spinlock_acquire at C:/Espressif/frameworks/esp-idf-v4.4.1/components/esp_hw_support/include/soc/spinlock.h:123
123 | (inlined by) xPortEnterCriticalTimeout at C:/Espressif/frameworks/esp-idf-v4.4.1/components/freertos/port/xtensa/port.c:288
124 |
125 | 0x4008b26d: vPortEnterCritical at C:/Espressif/frameworks/esp-idf-v4.4.1/components/freertos/port/xtensa/include/freertos/portmacro.h:578
126 | (inlined by) xEventGroupWaitBits at C:/Espressif/frameworks/esp-idf-v4.4.1/components/freertos/event_groups.c:379
127 |
128 | 0x400d5ed4: wifiTask at h:\projects\c\esp\esp32\ntp\build/../main/wifi.c:185 (discriminator 15)
129 |
130 | 0x4008b545: vPortTaskWrapper at C:/Espressif/frameworks/esp-idf-v4.4.1/components/freertos/port/xtensa/port.c:131
