Weiß jemand zufällig wie hier die MPPT-Funktion funktioniert? https://www.aliexpress.com/item/1005004341258995.html?algo_pvid=3aeefd05-3137-412d-82cd-aafed96507ba&algo_exp_id=3aeefd05-3137-412d-82cd-aafed96507ba-7&pdp_ext_f=%7B%22sku_id%22%3A%2212000028825606824%22%7D&pdp_npi=2%40dis%21EUR%21%217.23%21%21%21%21%21%40210318be16573655223208331e4f5f%2112000028825606824%21sea Liebe Grüße
Verschoben durch Moderator
x3oo schrieb: > Weiß jemand zufällig wie hier die MPPT-Funktion funktioniert? > > https://www.aliexpress.com/item/1005004341258995.html Es gibt keine.
... was nicht heißt, daß MPPT mit StepDown-Wandlern nicht möglich wäre, hab ich selbst schon gebastelt.
Ich habe eine Erklärung gefunden. Wie soll das angeblich funktionieren? "4. Set the MPPT voltage value: A. The method of setting with an adjustable regulated power supply: adjust the adjustable regulated power supply to the voltage value to be set (such as 18V), and the output is not connected to the load. When the module has an output voltage, adjust the MPPT counterclockwise. Set the potentiometer to the critical point where the output voltage is just reduced. B. The method of setting directly with the solar panel: the input is directly connected to the solar panel, the output voltage is set according to the load, part of the light shining on the solar panel is blocked, and the output is connected to the load. Use a multimeter to measure the output voltage of the solar panel (switch to the input voltage display with a voltmeter), and adjust the MPPT potentiometer until the voltage of the solar panel reaches the maximum power point voltage. (The actual maximum power point voltage of the solar panel will be lower than the nominal voltage, such as 18V solar panel, the maximum power point will be around 17.5V.) You can also adjust the MPPT value by measuring the output current, and connect the current gear of the multimeter in series. Between the output and the load (the one with the meter can be switched to the current display), the MPPT potentiometer can be adjusted back and forth until the output current reaches the maximum value. Note: When using the solar panel to directly adjust the MPPT value, when the power emitted by the solar panel is greater than the load power, please block part of the light shining on the solar panel first to reduce the power of the solar panel, so that the MPPT value can be adjusted. " Glaube ich weiß wie es geht. Ähnlich wie hier: https://de.mathworks.com/solutions/power-electronics-control/mppt-algorithm.html
x3oo schrieb: > Wie soll das angeblich funktionieren? Das ist kein MPPT! Der Regler kann lediglich den Dead Lock vermeiden.
https://de.wikipedia.org/wiki/Maximum_Power_Point_Tracking Guckst Du beim Kaptitel „Methode der konstanten Spannung“, da wird es genauer erklärt. Mit dem Unterschied, dass bei dem Modul zwischendurch die Leerlaufspannung nicht gemessen wird sondern nur fix eingestellt. In der Tat sind „echte“ MPPT in so einer Modulform selten. Für eine einfache Solarzelle reicht aber Constant Voltage durchaus für gute Ergebnisse.
Harald A. schrieb: > Guckst Du beim Kaptitel „Methode der konstanten Spannung“, > da wird es genauer erklärt. Sowas nenne ich "MPPT für Arme". Insbesondere, wenn man von vornherein eine feste "MPPT-Spannung" für die Solarmodule annimmt. Solche Schaltungen haben den Vorteil, ohne grossen Bauteileaufwand mit allen Schaltreglern zu funktionieren, wobei die Verringerung des theoretisch möglichen Wirkungs- grads gegenüber einer "echten" MPPT-Schaltung nur wenige Prozent beträgt.
Man kann an dem eine zielspannung angeben, das ungefähr beim mppt der solarzelle liegen soll. Wenn man den an ein fahrraddynamo anschließen würde und bspw. Eine höhere zielspannung einstellen würde, müsste es doch möglich sein mehr Leistung aus dem dynamo zu ziehen? Ich glaube mein mabensynamo hat noch eine zener diode innen drin zur Spannungsbegrenzung versteckt.
X3oo schrieb: > mein mabensynamo hat noch eine zener diode innen drin zur > Spannungsbegrenzung versteckt Ja, kann durchaus so sein, denn bei hemmungsloser Bergabfahrt sollen die empfindlichen LED-Lampen oder sogar herkömmliche Glühbirnen vor zu viel Spannung und der damit verbundenen Beschädigungsgefahr geschützt werden. mfg
X3oo schrieb: > Wenn man den an ein fahrraddynamo anschließen > würde und bspw. Eine höhere zielspannung einstellen würde, müsste es > doch möglich sein mehr Leistung aus dem dynamo zu ziehen? Da ein Fahrraddynamo zwar auch eine Stromquelle ist, aber ein völlig anderes Verhalten als eine Solarzelle hat, dürfte es nicht klappen, den an eine Solar-MPPT anzuschliessen.
Die "richtigen" MPPT haben immer neben einer maximalen Spannung auch einen maximal zulässigen Kurzschlussstrom des PV Moduls angegeben. Dabei weis ich nicht, warum das so ist und was passieren würde wenn man etwas anderes als ein PV Modul anschliesst. Man könnte z. Bsp. einen (Windkraft)Dynamo oder eine Speicherbatterie anschliessen welche einen deutlich kleineren Kurzschlußstrom mit viel kleinerem Innenwiderstand hat. Ein wirklicher MPPT macht bei Batterien zwar keinen großen Sinn mehr, dürfte aber auch nicht kaputt gehen. Die Chinesen schreiben eben als Verkaufsargument MPPT drauf in der Hoffnung daß der Käufer sowieso nicht weis was das ist.
