Hi does anyone now of such a device: a USB power supply: Input USB output 0-5 volt DC adjustable/controlled via windows or linux thx
>>Voltage/current output range?
it should be powered via USB, 100 ma are enough
Since USB is allowed to output as little as 4,25V this device will be somewhat complex as it will need a stepup converter inside.
The DPS5005 and other from that series can be controlled via UART/USB.
Brränko schrieb: > can be controlled via UART/USB. Mat. K. schrieb: > it should be powered via USB !!!
Ich hab das Teil: https://sirutec.de/sirubox/ Macht genau was du suchst. Keine Softwarenotwendig wegen integriertem http-Server. Ziemlich geil. Olaf
