1 | #define STATE_SAVE_PERIOD UINT32_C(360 * 60 * 1000) // 360 minutes - 4 times a day
2 |
3 | #include <WiFi.h>
4 | #include <ESPmDNS.h>
5 | #include <WiFiUdp.h>
6 | #include <ArduinoOTA.h>
7 | #include <EEPROM.h>
8 | #include "bsec.h"
9 | /* Configure the BSEC library with information about the sensor
10 | 18v/33v = Voltage at Vdd. 1.8V or 3.3V
11 | 3s/300s = BSEC operating mode, BSEC_SAMPLE_RATE_LP or BSEC_SAMPLE_RATE_ULP
12 | 4d/28d = Operating age of the sensor in days
13 | generic_18v_3s_4d
14 | generic_18v_3s_28d
15 | generic_18v_300s_4d
16 | generic_18v_300s_28d
17 | generic_33v_3s_4d
18 | generic_33v_3s_28d
19 | generic_33v_300s_4d
20 | generic_33v_300s_28d
21 | */
22 | const uint8_t bsec_config_iaq[] = {
23 | #include "config/generic_33v_3s_4d/bsec_iaq.txt"
24 | };
25 |
26 |
27 | // Helper functions declarations
28 | void checkIaqSensorStatus(void);
29 | void errLeds(void);
30 | void loadState(void);
31 | void updateState(void);
32 |
33 |
34 | // Create an object of the class Bsec
35 | Bsec iaqSensor;
36 | uint8_t bsecState[BSEC_MAX_STATE_BLOB_SIZE] = {0};
37 | uint16_t stateUpdateCounter = 0;
38 |
39 | String output;
40 |
41 | const char* ssid = "xxx";
42 | const char* password = "xxxxx";
43 |
44 | uint8_t i;
45 | bool ConnectionEstablished; // Flag for successfully handled connection
46 |
47 | #define MAX_TELNET_CLIENTS 2
48 |
49 | WiFiServer TelnetServer(23);
50 | WiFiClient TelnetClient[MAX_TELNET_CLIENTS];
51 |
52 | void setup()
53 | {
54 | Serial.begin(115200);
55 | Serial.println("Over The Air and Telnet Example");
56 |
57 | Serial.printf("Sketch size: %u\n", ESP.getSketchSize());
58 | Serial.printf("Free size: %u\n", ESP.getFreeSketchSpace());
59 |
60 | WiFi.mode(WIFI_STA);
61 | WiFi.begin(ssid, password);
62 | Wire.begin();
63 | iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
64 | output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
65 | Serial.println(output);
66 | checkIaqSensorStatus();
67 |
68 | iaqSensor.setConfig(bsec_config_iaq);
69 | checkIaqSensorStatus();
70 |
71 | loadState();
72 |
73 |
74 | bsec_virtual_sensor_t sensorList[10] = {
75 | BSEC_OUTPUT_RAW_TEMPERATURE,
76 | BSEC_OUTPUT_RAW_PRESSURE,
77 | BSEC_OUTPUT_RAW_HUMIDITY,
78 | BSEC_OUTPUT_RAW_GAS,
79 | BSEC_OUTPUT_IAQ,
80 | BSEC_OUTPUT_STATIC_IAQ,
81 | BSEC_OUTPUT_CO2_EQUIVALENT,
82 | BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
83 | BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
84 | BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
85 | };
86 |
87 | iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_LP);
88 | checkIaqSensorStatus();
89 |
90 | // ... Give ESP 10 seconds to connect to station.
91 | unsigned long startTime = millis();
92 | Serial.print("Waiting for wireless connection ");
93 | while (WiFi.status() != WL_CONNECTED && millis() - startTime < 10000)
94 | {
95 | delay(200);
96 | Serial.print(".");
97 | }
98 | Serial.println();
99 |
100 | while (WiFi.status() != WL_CONNECTED)
101 | {
102 | Serial.println("Connection Failed! Rebooting...");
103 | delay(3000);
104 | ESP.restart();
105 | }
106 |
107 | Serial.print("IP address: ");
108 | Serial.println(WiFi.localIP());
109 |
110 | Serial.println("Starting Telnet server");
111 | TelnetServer.begin();
112 | TelnetServer.setNoDelay(true);
113 |
114 | pinMode(LED_BUILTIN, OUTPUT); // initialize onboard LED as output
115 |
116 | // OTA
117 |
118 | // Port defaults to 8266
119 | // ArduinoOTA.setPort(8266);
120 |
121 | // Hostname defaults to esp8266-[ChipID]
122 | // ArduinoOTA.setHostname("myesp8266");
123 |
124 | // No authentication by default
125 | ArduinoOTA.setPassword((const char *)"1234");
126 |
127 | ArduinoOTA.onStart([]() {
128 | Serial.println("Start");
129 | });
130 |
131 | ArduinoOTA.onEnd([]() {
132 | Serial.println("\nEnd");
133 | });
134 |
135 | ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
136 | Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
137 | });
138 | ArduinoOTA.onError([](ota_error_t error) {
139 | Serial.printf("Error[%u]: ", error);
140 | if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
141 | else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
142 | else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
143 | else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
144 | else if (error == OTA_END_ERROR) Serial.println("End Failed");
145 | });
146 |
147 | ArduinoOTA.begin();
148 | }
149 |
150 | void loop() {
151 | //ArduinoOTA.handle(); // Wait for OTA connection
152 | blinkLED(); // Blink LED
153 | Telnet(); // Handle telnet connections
154 | unsigned long time_trigger = millis();
155 | if (iaqSensor.run()) { // If new data is available
156 | output = "time=" +String(time_trigger);
157 | output += ", rawTemperature=" + String(iaqSensor.rawTemperature);
158 | output += ", pressure=" + String(iaqSensor.pressure);
159 | output += ", rawHumidity=" + String(iaqSensor.rawHumidity);
160 | output += ", gasResistance=" + String(iaqSensor.gasResistance);
161 | output += ", iaq=" + String(iaqSensor.iaq);
162 | output += ", iaqAccuracy=" + String(iaqSensor.iaqAccuracy);
163 | output += ", temperature=" + String(iaqSensor.temperature);
164 | output += ", humidity=" + String(iaqSensor.humidity);
165 | output += ", staticIaq=" + String(iaqSensor.staticIaq);
166 | output += ", co2Equivalent=" + String(iaqSensor.co2Equivalent);
167 | output += ", breathVocEquivalent=" + String(iaqSensor.breathVocEquivalent);
168 | TelnetMsg(output);
169 | } else {
170 | checkIaqSensorStatus();
171 | }
172 | delay(30000);
173 | }
174 |
175 | void TelnetMsg(String text)
176 | {
177 | for(i = 0; i < MAX_TELNET_CLIENTS; i++)
178 | {
179 | if (TelnetClient[i] || TelnetClient[i].connected())
180 | {
181 | TelnetClient[i].println(text);
182 | }
183 | }
184 | delay(10); // to avoid strange characters left in buffer
185 | }
186 |
187 | void Telnet()
188 | {
189 | // Cleanup disconnected session
190 | for(i = 0; i < MAX_TELNET_CLIENTS; i++)
191 | {
192 | if (TelnetClient[i] && !TelnetClient[i].connected())
193 | {
194 | Serial.print("Client disconnected ... terminate session "); Serial.println(i+1);
195 | TelnetClient[i].stop();
196 | }
197 | }
198 |
199 | // Check new client connections
200 | if (TelnetServer.hasClient())
201 | {
202 | ConnectionEstablished = false; // Set to false
203 |
204 | for(i = 0; i < MAX_TELNET_CLIENTS; i++)
205 | {
206 | // Serial.print("Checking telnet session "); Serial.println(i+1);
207 |
208 | // find free socket
209 | if (!TelnetClient[i])
210 | {
211 | TelnetClient[i] = TelnetServer.available();
212 |
213 | Serial.print("New Telnet client connected to session "); Serial.println(i+1);
214 |
215 | TelnetClient[i].flush(); // clear input buffer, else you get strange characters
216 | TelnetClient[i].println("Welcome!");
217 |
218 | TelnetClient[i].print("Millis since start: ");
219 | TelnetClient[i].println(millis());
220 |
221 | TelnetClient[i].print("Free Heap RAM: ");
222 | TelnetClient[i].println(ESP.getFreeHeap());
223 |
224 | TelnetClient[i].println("----------------------------------------------------------------");
225 |
226 | ConnectionEstablished = true;
227 |
228 | break;
229 | }
230 | else
231 | {
232 | // Serial.println("Session is in use");
233 | }
234 | }
235 |
236 | if (ConnectionEstablished == false)
237 | {
238 | Serial.println("No free sessions ... drop connection");
239 | TelnetServer.available().stop();
240 | // TelnetMsg("An other user cannot connect ... MAX_TELNET_CLIENTS limit is reached!");
241 | }
242 | }
243 |
244 | for(i = 0; i < MAX_TELNET_CLIENTS; i++)
245 | {
246 | if (TelnetClient[i] && TelnetClient[i].connected())
247 | {
248 | if(TelnetClient[i].available())
249 | {
250 | //get data from the telnet client
251 | while(TelnetClient[i].available())
252 | {
253 | Serial.write(TelnetClient[i].read());
254 | }
255 | }
256 | }
257 | }
258 | }
259 |
260 | ////////////////////////////////////////////////////////////////////////////////////////
261 | // Blink function with telnet output
262 |
263 | const long interval = 2000;
264 | int ledState = LOW;
265 | unsigned long previousMillis = 0;
266 |
267 | void blinkLED()
268 | {
269 | unsigned long currentMillis = millis();
270 |
271 | // if enough millis have elapsed
272 | if (currentMillis - previousMillis >= interval)
273 | {
274 | previousMillis = currentMillis;
275 |
276 | // toggle the LED
277 | ledState = !ledState;
278 | digitalWrite(LED_BUILTIN, ledState);
279 |
280 | String ledStateMsg = "LED State = ";
281 | ledStateMsg += ledState;
282 | TelnetMsg(ledStateMsg);
283 | }
284 | }
285 | // Helper function definitions
286 | void checkIaqSensorStatus(void)
287 | {
288 | if (iaqSensor.status != BSEC_OK) {
289 | if (iaqSensor.status < BSEC_OK) {
290 | output = "BSEC error code : " + String(iaqSensor.status);
291 | Serial.println(output);
292 | for (;;)
293 | errLeds(); /* Halt in case of failure */
294 | } else {
295 | output = "BSEC warning code : " + String(iaqSensor.status);
296 | Serial.println(output);
297 | }
298 | }
299 |
300 | if (iaqSensor.bme680Status != BME680_OK) {
301 | if (iaqSensor.bme680Status < BME680_OK) {
302 | output = "BME680 error code : " + String(iaqSensor.bme680Status);
303 | Serial.println(output);
304 | for (;;)
305 | errLeds(); /* Halt in case of failure */
306 | } else {
307 | output = "BME680 warning code : " + String(iaqSensor.bme680Status);
308 | Serial.println(output);
309 | }
310 | }
311 | iaqSensor.status = BSEC_OK;
312 | }
313 |
314 | void errLeds(void)
315 | {
316 | pinMode(LED_BUILTIN, OUTPUT);
317 | digitalWrite(LED_BUILTIN, HIGH);
318 | delay(100);
319 | digitalWrite(LED_BUILTIN, LOW);
320 | delay(100);
321 | }
322 |
323 | void loadState(void)
324 | {
325 | if (EEPROM.read(0) == BSEC_MAX_STATE_BLOB_SIZE) {
326 | // Existing state in EEPROM
327 | Serial.println("Reading state from EEPROM");
328 |
329 | for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE; i++) {
330 | bsecState[i] = EEPROM.read(i + 1);
331 | Serial.println(bsecState[i], HEX);
332 | }
333 |
334 | iaqSensor.setState(bsecState);
335 | checkIaqSensorStatus();
336 | } else {
337 | // Erase the EEPROM with zeroes
338 | Serial.println("Erasing EEPROM");
339 |
340 | for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE + 1; i++)
341 | EEPROM.write(i, 0);
342 |
343 | EEPROM.commit();
344 | }
345 | }
346 |
347 | void updateState(void)
348 | {
349 | bool update = false;
350 | /* Set a trigger to save the state. Here, the state is saved every STATE_SAVE_PERIOD with the first state being saved once the algorithm achieves full calibration, i.e. iaqAccuracy = 3 */
351 | if (stateUpdateCounter == 0) {
352 | if (iaqSensor.iaqAccuracy >= 3) {
353 | update = true;
354 | stateUpdateCounter++;
355 | }
356 | } else {
357 | /* Update every STATE_SAVE_PERIOD milliseconds */
358 | if ((stateUpdateCounter * STATE_SAVE_PERIOD) < millis()) {
359 | update = true;
360 | stateUpdateCounter++;
361 | }
362 | }
363 |
364 | if (update) {
365 | iaqSensor.getState(bsecState);
366 | checkIaqSensorStatus();
367 |
368 | Serial.println("Writing state to EEPROM");
369 |
370 | for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE ; i++) {
371 | EEPROM.write(i + 1, bsecState[i]);
372 | Serial.println(bsecState[i], HEX);
373 | }
374 |
375 | EEPROM.write(0, BSEC_MAX_STATE_BLOB_SIZE);
376 | EEPROM.commit();
377 | }
378 | }
