Forum: Mikrocontroller und Digitale Elektronik Importierte Funktionen werden nicht ausgeführt Python
von Kevin B. (kevin_b502)
Hallo Zusammen
ich habe folgendes Problem: im einen File (LCD_Config) habe ich zur
Konfiguration eines LCD Displays folgenden Code:
from machine import Pin,SPI,PWM
import framebuf
import time
#color is BGR
RED = 0x00F8
GREEN = 0xE007
BLUE = 0x1F00
WHITE = 0xFFFF
BLACK = 0x0000
class LCD_0inch96(framebuf.FrameBuffer):
    def __init__(self):
        self.width = 160
        self.height = 80
        self.cs = Pin(9,Pin.OUT)
        self.rst = Pin(12,Pin.OUT)
#        self.bl = Pin(13,Pin.OUT)
        self.cs(1)
        # pwm = PWM(Pin(13))#BL
23
        # pwm.freq(1000)
24
        self.spi = SPI(1)
25
        self.spi = SPI(1,1000_000)
26
        self.spi = SPI(1,10000_000,polarity=0, phase=0,sck=Pin(10),mosi=Pin(11),miso=None)
27
        self.dc = Pin(8,Pin.OUT)
28
        self.dc(1)
29
        self.buffer = bytearray(self.height * self.width * 2)
30
        super().__init__(self.buffer, self.width, self.height, framebuf.RGB565)
31
        self.Init()
32
        self.SetWindows(0, 0, self.width-1, self.height-1)
33
34
    def reset(self):
35
        self.rst(1)
36
        time.sleep(0.2)
37
        self.rst(0)
38
        time.sleep(0.2)
39
        self.rst(1)
40
        time.sleep(0.2)
41
42
    def write_cmd(self, cmd):
43
        self.dc(0)
44
        self.cs(0)
45
        self.spi.write(bytearray([cmd]))
46
47
    def write_data(self, buf):
48
        self.dc(1)
49
        self.cs(0)
50
        self.spi.write(bytearray([buf]))
51
        self.cs(1)
52
53
    def backlight(self,value):#value:  min:0  max:1000
54
55
        pwm.freq(1000)
56
        if value>=1000:
57
            value=1000
58
        data=int (value*65536/1000)
59
        pwm.duty_u16(data)
60
61
    def Init(self):
62
        self.reset()
63
        self.backlight(10000)
64
65
        self.write_cmd(0x11)
66
        time.sleep(0.12)
67
        self.write_cmd(0x21)
68
69
70
        self.write_cmd(0xB1)
71
        self.write_data(0x05)
72
        self.write_data(0x3A)
73
74
75
        self.write_cmd(0xB2)
76
77
78
79
80
        self.write_cmd(0xB3)
81
82
83
84
85
86
87
88
        self.write_cmd(0xB4)
89
        self.write_data(0x03)
90
91
        self.write_cmd(0xC0)
92
        self.write_data(0x62)
93
        self.write_data(0x02)
94
        self.write_data(0x04)
95
96
        self.write_cmd(0xC1)
97
        self.write_data(0xC0)
98
99
        self.write_cmd(0xC2)
100
        self.write_data(0x0D)
101
        self.write_data(0x00)
102
103
        self.write_cmd(0xC3)
104
        self.write_data(0x8D)
105
        self.write_data(0x6A)
106
107
        self.write_cmd(0xC4)
108
109
        self.write_data(0xEE)
110
111
        self.write_cmd(0xC5)
112
        self.write_data(0x0E)
113
114
        self.write_cmd(0xE0)
115
        self.write_data(0x10)
116
117
118
119
120
        self.write_data(0x07)
121
122
123
        self.write_data(0x0A)
124
        self.write_data(0x12)
125
        self.write_data(0x27)
126
        self.write_data(0x37)
127
128
129
130
131
132
        self.write_cmd(0xE1)
133
134
135
136
137
        self.write_data(0x0F)
138
        self.write_data(0x06)
139
140
        self.write_data(0x08)
141
142
        self.write_data(0x13)
143
        self.write_data(0x26)
144
        self.write_data(0x36)
145
146
147
148
149
150
        self.write_cmd(0x3A)
151
152
153
        self.write_cmd(0x36)
154
        self.write_data(0xA8)
155
156
        self.write_cmd(0x29)
157
158
    def SetWindows(self, Xstart, Ystart, Xend, Yend):#example max:0,0,159,79
159
        Xstart=Xstart+1
160
        Xend=Xend+1
161
        Ystart=Ystart+26
162
        Yend=Yend+26
163
        self.write_cmd(0x2A)
164
165
        self.write_data(Xstart)
166
167
        self.write_data(Xend)
168
169
        self.write_cmd(0x2B)
170
171
        self.write_data(Ystart)
172
173
        self.write_data(Yend)
174
175
        self.write_cmd(0x2C)
176
177
    def display(self):
178
179
        self.SetWindows(0,0,self.width-1,self.height-1)
180
        self.dc(1)
181
        self.cs(0)
182
        self.spi.write(self.buffer)
183
        self.cs(1)
184
185
if __name__=='__main__':
186
    lcd = LCD_0inch96()
187
    lcd.fill(BLACK)
188
    lcd.text("Hello dude!",35,15,BLUE)
189
    lcd.text("This is:",50,35,BLUE)
190
    lcd.text("Pico-LCD-0.96",30,55,BLUE)
191
    lcd.display()
Im Main file (unten) möchte ich zuerst auf diesen Code zugreifen durch
import LCD_Config, um dann auf dessen Funktionen zuzugreifen. Allerdings
findet er die Funktionen nicht. (Im Anhang die Fehlermeldung)
import LCD_Config
lcd = LCD_0inch96()
lcd.fill(BLACK)
lcd.display()
von Sebastian (Gast)
LCD_0inch96 ist nicht global sondern nur innerhalb von LCD_Config
definiert.
LG, Sebastian
& wie kann ich dann von einem anderen Skript darauf zugreiffen?
von Holger (Gast)
from LCD_Config import LCD_0inch96
sollte helfen
von Sauron (Gast)
from
Kevin B. schrieb:
> import LCD_Config
geraten:
from LCD_config import *
Entweder indem du die Klasse aus dem Modul importierst, so wie von den
anderen Forenten beschrieben, oder indem du über den Modulnamen gehst,
also als LCD_Config.LCD_0inch96 notierst. Das ist alles im Detail unter
https://docs.python.org/3/reference/executionmodel.html#naming-and-binding
beschrieben.
Hättest du aber nach meiner obigen Hilfe auch selbst rausfinden können
LG, Sebastian
von Karl Käfer (Gast)
Die Datei heißt hoffentlich nicht "LCD_Config", sondern "LCD_Config.py",
oder? ;-)
> import LCD_Config
> lcd = LCD_0inch96()
Dieser Code importiert das Modul LCD_Config, aber dessen Elemente lassen
sich nur über den importierten Modulnamen ansprechen, also so:
import LCD_Config
lcd = LCD_Config.LCD_0inch96()
Die andere Alternative ist, bestimmte Namen (wie hier "LCD_0inch96") aus
Deinem Modul "LCD_Config" zu importieren, dann kannst Du die
importierten Namen direkt (also ohne Modulnamen) benutzen:
lcd = LCD_0inch96()
Eine dritte und unter Umständen elegantere Möglichkeit wäre, die
importierten Namen mit einem Aliasnamen zu versehen und dann das Alias
zu benutzen:
from LCD_Config import LCD_0inch96 as Display
lcd = Display()
HTH, YMMV. ;-)
Diese Methode funktioniert zwar, aber fortgeschrittene Entwickler machen
so etwas lieber nicht. Einerseits verstößt sie gegen PEP 20, also das
"Zen of Python" [1], andererseits kann dann am Ende niemand mehr ohne
größere Klimmzüge nachvollziehen, woher die verwendeten Symbole jeweils
kommen.
[1] https://peps.python.org/pep-0020/
