ESP8266 -> shelly3em Programmierhilfe?
OP #7398872
Guten Tag, versuche gerade den 3EM auszulesen. Bis zum Aufbau einer Verbindung hab ich das geschafft. Aber was soll der ESP dem shelly senden, damit der die Power-Daten rausrückt? Ich bekomme einfach keine Antwort:
    This sketch establishes a TCP connection to a "quote of the day" service.
    It sends a "hello" message, and then prints received data.
#include <ESP8266WiFi.h>
#ifndef STASSID
#define STASSID "shellyem3-3494547B8D61"
#define STAPSK ""
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
const char* host = "192.168.33.1";
const uint16_t port = 80;
void setup() {
  Serial.begin(115200);
  // We start by connecting to a WiFi network
23
24
  Serial.println();
25
  Serial.println();
26
  Serial.print("Connecting to ");
27
  Serial.println(ssid);
28
29
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
30
     would try to act as both a client and an access-point and could cause
31
     network-issues with your other WiFi-devices on your WiFi-network. */
32
  WiFi.mode(WIFI_STA);
33
  WiFi.begin(ssid, password);
34
35
  while (WiFi.status() != WL_CONNECTED) {
36
    delay(500);
37
    Serial.print(".");
38
39
40
  Serial.println("");
41
  Serial.println("WiFi connected");
42
  Serial.println("IP address: ");
43
  Serial.println(WiFi.localIP());
44
45
46
void loop() {
47
  static bool wait = false;
48
49
  Serial.print("connecting to ");
50
  Serial.print(host);
51
  Serial.print(':');
52
  Serial.println(port);
53
54
  // Use WiFiClient class to create TCP connections
55
  WiFiClient client;
56
  if (!client.connect(host, port)) {
57
    Serial.println("connection failed");
58
    delay(5000);
59
    return;
60
61
62
  // This will send a string to the server
63
  Serial.println("sending data to server");
64
65
66
 if (client.connected()) { client.println("shellyem3-3494547B8D61/emeter/0?"); }
67
68
69
70
  // wait for data to be available
71
  unsigned long timeout = millis();
72
  while (client.available() == 0) {
73
    if (millis() - timeout > 5000) {
74
      Serial.println(">>> Client Timeout !");
75
      client.stop();
76
      delay(60000);
77
      return;
78
79
80
81
  // Read all the lines of the reply from server and print them to Serial
82
  Serial.println("receiving from remote server");
83
  // not testing 'client.connected()' since we do not need to send data here
84
  while (client.available()) {
85
    char ch = static_cast<char>(client.read());
86
    Serial.print(ch);
87
88
89
  // Close the connection
90
  Serial.println();
91
  Serial.println("closing connection");
92
  client.stop();
93
94
  if (wait) {
95
    delay(300000);  // execute once every 5 minutes, don't flood remote service
96
97
  wait = true;
98
OP #7398927
Walta S. schrieb:
Wozu? Was genau willst du machen?
Ich lese die Daten über ioBroker aus oder über die App oder direkt über die Web Oberfläche.
Hast du schon im Shelly Forum nachgefragt?
Walta
Ich will die Daten letztlich über eine Impulslänge an einem Pin an einen Attiny45 liefern, der dann an seinen 4 anderen Pin's bis zu 16 verschiedene Aktionen auslösen kann. Wie ich die in den ESP bringe, da bin ich völlig frei. Ja, auch meinen Code hab ich über das Shelly-Forum geklaut und durch rumprobieren immerhin bis zu einer "Verbindung" gebracht, wobei mein größtes Hindernis die Syntax von "C" ist. Wie sieht denn deine Lösung aus? Gruß Helle
(Firma: Gast) #7398949
Meine?
Ich mag standardisierte Schnittstellen. (dafür gibts fertige Werkzeuge/Verfahren zum erstellen und debuggen)
Bei mir "passiert" es auch mal, dass ein ESP zu wenige Ausgänge hat. Dann klemme ich mir meist einen Atmel/Arduino als I2C Slave da dran. Oder einen MCP23017. Oder, oder ...
Ein Tiny85 hat 6 IO Pins. Geht also!
Auch UART wäre machbar.
OP #7398974
Arduino F. schrieb:
Meine?
Ich will den Reset nicht gebrauchen. Vlt teste ich's erst mal mit der Seriellen und nur 3 OUTPUT. Aber das sind die Übernächsten Stolperfallen. Zunächst muß ich der Daten erst mal habhaft werden.
#7399001
Wie gesagt - ich hol mir die Daten der Shelly über ioBroker und/oder über homebridge in homekit - je nachdem was ich machen will. Und von dort gehts dann weiter zur Steuerung von was-auch-immer.
Ein d1mini hat 11 Ausgänge und kann über tasmota angesprochen werden.
Walta
