Forum: Haus & Smart Home Pizzaofen - Sicherung springt raus - warum?
von Jens B. (fernostler)
Bei meinem G3 Kopie Pizzaofen (230V, 1000W) springt die Sicherung raus -
wie kann das sein?
An der gleichen Steckdose war vorher mein Backofen (3000W) ein paar
Jahre lang dran, ohne Problem.
Also an der Last kann es nicht liegen. Es ist auch die Sicherung und
nicht der FI.
Es geht ca. 5 Minuten gut, dann springt die 10A Sicherung an. An zwei
getrennten Kreisen getestet.
Wie kann das sein?
von H. H. (Gast)
Da wird wohl der Ofen wegen defekten Heizelements deutlich mehr als
1000W aufnehmen.
von Phasenschieber S. (Gast)
> nicht der FI.
Doch, es muss an der Last liegen!
von Ashna S. (ashna_s)
There are a few possible reasons why the fuse on your G3 copy pizza oven
is blowing:
1. Overheating: If the oven is not getting enough ventilation, it could
overheat and cause the fuse to blow. Make sure the oven is not placed
too close to a wall or other object that could restrict airflow.
2. Short circuit: A short circuit can occur when a live wire comes into
contact with a neutral wire or the earth wire. This can cause a sudden
surge of current that can blow the fuse. Check the wiring connections in
the oven to ensure they are secure and not touching each other.
3. Faulty component: A faulty component within the oven, such as a
heating element or thermostat, could be causing the fuse to blow. If you
are not familiar with electrical components, it is best to have a
qualified technician inspect the oven.
4. Power fluctuations: If the voltage in your electrical circuit is
fluctuating, it could cause the fuse to blow. This can be caused by
other appliances in your home that are drawing power at the same time,
or by external factors such as lightning strikes. Installing a surge
protector could help to protect the oven from power fluctuations.
It is important to keep in mind that you should never replace a blown
fuse with a higher amperage fuse, as this could create a fire hazard.
von S. Z. (moennky)
Nein, der FI misst nicht die Last, sondern vergleicht den zufliessenden
Strom mit dem Abfliessenden.
> 1000W aufnehmen.
Ich Messe wenn beide Elemente an sind 4,6A (wirklich gemessen, nicht
errechnet)
Jetzt fällt mir auf ich sollte mal bis zum anspringen der Sicherung
messen.
@S. Z.
Der FI spricht ja NICHT an.
Eine Überlastung/Schluss nach 5 Minuten könnte eine Erklärung sein.
@Ashna S.
My guess is some sort of oven defect. Maybe a shortcut when the (a)
heating element is hot. Will investigate further.
PS: Ziel ist den Ofen von den jetzt (bzw. wenn er mal geht) 250°C auf
~400°C zu bekommen, das könnte aber mit 1000W evtl. eng werden.
Der FI ist hier ja garnicht im Spiel!  Leseschwäche?
von Wastl (hartundweichware)
Jens B. schrieb:
> Wie kann das sein?
Vermutlich floss ein zu grosser Strom. Geniale Erkenntnis.
Daß das Heizelement einen Kurzschluss verursacht, halte ich für wenig
plausibel, eher daß eventuell das Steuerteil (Schalter, Zeitschaltuhr,
Thermostat) infolge der Hitze einen Kurzen erzeugt.
von Peter G. (ham)
Hallo
10A Sicherung... Uraltbau?
Aber wie auch immer:
Wahrscheinlich wird bei der erwünschten Erwärmung sich in den
Heizelementen irgendwas ausdehnen und einen satten Kurzschluss machen,
der aber nicht, ausreicht, dass es zu Verschweißungen und einem
dauerhaften Kurzschluss kommt - was aber ungewöhnlich wäre.
Hast du die Möglichkeit einen höher (normal) abgesicherten Anschluss zu
nutzen?
Wenn die Zeit bis zum Auslösen der 16A oder eventuell mittlerweile öfter
leider nur 13A Sicherung genauso lange dauert, wird es sich um einen von
mir beschriebenen "richtigen" Kurzschluss handeln, dauert es deutlich
länger sogar so lange das dein alter 3000W den Automaten nicht ausgelöst
hatten (700W zu viel hätten es aber meinen Gefühlen nach sollen...?) ,
zieht der Ofen einfach "nur" zu viel Leistung, wobei ein 10A Automat
aber auch nicht bei 2310W  (10A * 230V = 2300W) auslöst, sondern es
schon über einen längeren Zeitraum wie z.B. deine 5 Minuten eine
Leistung von (geraten - bitte Selbst in die Kennlinien des Automatentyps
schauen) 2500W und mehr braucht - das fühlt man  dann aber auch an den
üblicherweise immer knapp bemessenen Kabeln der Geräte an einer
fühlbaren Erwärmung bzw. sieht man auch an den Heizstäben, wenn diese so
langsam zu "Glühlampen" mutieren.
Wenn noch möglich:
Zurückgeben oder Umtauschen bzw.es  als Defekt und Pech gehabt hinnehmen
- solche Pizzaöfen kosten ja kein Vermögen.
Eine Reparatur, wen sie nicht aus Neugier und echten Interesse erfolgt
(Hobby) , lohnt sich nämlich nicht
von Michael B. (laberkopp)
Jens B. schrieb:
> Ziel ist den Ofen von den jetzt (bzw. wenn er mal geht) 250°C auf ~400°C
Das wird vor allem eng, weil die Heizelemente nicht so viel aushalten.
Glaubt du, bei dem billigen Consumerschrott wird nutzlos
überdimensioniert ?
Dein Kurzschluss der die Sicherung kommen lässt kann durchaus was mit
Überhitzung zu tun haben.
Bisher jetzt hab ich noch nichts modifiziert, alles noch original.
von B e r n d W. (smiley46)
Das G3-Heizelement hält über 400°C aus, der Thermostat wurde jedoch
später wegen einer EU-Vorschrift auf 390°C kastriert.
Ein defekt des Heizelements ist trotzdem nicht auszuschließen.
von Thomas R. (thomasr)
Sicherung ist wirklich seltsam denn bei einem Defekt IM Heizelement
kommt es üblicherweise nicht zu einem Kurzschluß sondern zuerst zu einem
erhöhten Stromfluß gegen PE (dem Gehäuse des Heizelementes) Damit sollte
zuerst der RCD kommen.
Nur bei einem satten Kurzschluß gegen PE oder N würde ausschließlich der
LS kommen. Dann wäre das Heizelement aber auch sofort Schrott, das hält
die Glühwendel nämlich nicht aus.
Warum aber erst nach xx Minuten? Ich würde einen Defekt in der Steuerung
vermuten....
Ein gewöhnliches Heizelement kann frei in der Luft vor sich hin glühen
ohne Probleme. Damit können beliebige Temperaturen erreicht werden, je
nach Steuerung bzw. Temperaturabschaltung. Die Umgebung ist das Problem,
nicht das Element selbst.
von H. H. (Gast)
Thomas R. schrieb:
> Damit sollte
Wenn denn dieser Stromkreis einen hat.
H. H. schrieb:
> Thomas R. schrieb:
>> Damit sollte
Schreibt er doch. Heisst bei ihm nur noch FI.
von Rudi (experte)
Hatte mal auch das Problem an einem Heizgerät, wenn es aufgeheizt hat
und der Thermostat abschaltete, dass die Sicherung in diesem Moment
auslöste. Erst nach Ausbau des Thermostaten konnte gesehen werden, dass
beim Abschalten ein blanker Draht (Kunststoffummantelung weggebrochen)
an der Wippe der Schaltkontakte den Kurzschluss verursacht hatte.
Nach Austausch des Thermostaten war alles wieder in Ordnung.
Da der KS erst nach dem Aufheizen auftritt, ist davon auszugehen, dass
das Heizelement in Ordnung ist. FI ebenfalls. Was bleibt also noch
übrig?
von Helmut H. (quacksalber)
Gibt es an diesem Pizzaofen eine optische Anzeige (Glühlampe etc) die
bei erreichen der Solltemperatur diesen Zustand anzeigen soll? Wenn ja,
könnte diese Leuchte vermutlich den Kurzschluss auslösen, wenn Leuchte
defekt und erst ab gewissem Zeitpunkt zugeschaltet wird.
Eventuell mal prüfen.
von H. H. (Gast)
Thomas R. schrieb:
> H. H. schrieb:
>> Thomas R. schrieb:
>>> Damit sollte
Ich kenne den sogar auch als DDR.
Und er hat keineswegs geschrieben, dass in diesem Stromkreis ein FI
vorhanden ist.
> vorhanden ist.
> nicht der FI.
Wenn er keinen FI hätte, hätte er es geschrieben, so aber, ist es nicht
der FI!
von H. H. (Gast)
>> vorhanden ist.
>> nicht der FI.
> der FI!
Er hat einen FI, aber wohl nicht in diesem Stromkreis.
von Rainer W. (rawi)
> Wie kann das sein?
Die verzögerte Auslösung liegt wahrscheinlich an der
Abschaltcharakteristik der Sicherung. Was für eine Sicherung ist das?
Die thermische Auslösung aktueller Leitungsschutzschalter kann mit
erheblicher Verzögerung erfolgen.
https://de.wikipedia.org/wiki/Leitungsschutzschalter#/media/Datei:Standard-Ausl%C3%B6sekennlinie.svg
Dann meinst du wiedermal mehr zu wissen als alle anderen.
Bei solchen schwierig zu lokalisierenden Fehlern, kann nur die Wahl auf
Pizzavarianten fallen, die innerhalb der 5 Minuten bereits fertig sind.
mfg
von Michi S. (mista_s)
> Sicherung und nicht der FI.
Dann liegt es mit Sicherheit an der (Über)last ggf. infolge eines (z.B.
durch die Wärmeausdehnung entstehenden) Kurzschlusses.
> Es geht ca. 5 Minuten gut, dann springt die 10A Sicherung an. > An zwei
Damit fällt eine defekte Sicherung oder Verkabelung als mögliche Ursache
schon mal raus.
> gemessen, nicht errechnet)
Das paßt ganz gut zu den 1000W. Verzögerte Auslösung der Sicherung
infolge moderater Überlast ist damit ebenfalls raus.
> Sicherung messen.
Kannst Du versuchen, aber dann solltest Du die Anzeige jedenfalls
filmen, sonst schaust Du sicher genau im entscheidenden Moment grad
nicht drauf - Murphy schläft nicht!
Wenn die 4,6A aber mal über 2-3 Min. mehr oder weniger konstant bleiben,
würde ich mir davon nicht allzuviel erwarten:
Wenns zu einem satten Kurzschluß kommt, schaltet die Sicherung vmtl.
schneller ab, als dein DMM reagieren kann; bei  einem analogen Meßgerät
könnte man da noch eher ein Zucken erkennen.
Wenn der entstehende Schluß noch einen Restwiderstand läßt, so daß der
Stromfluß (dann wohl so 20A bis 50A) nicht zur Schnellabschaltung
ausreicht, dann könnte das sogar Deinem MM zum Verhängnis werden.
Helmut H. schrieb:
> wenn Leuchte
Gute Idee - zumal zumindest Glühobst durchaus öfter mal mit
Dauer-Kurzschluß ausfallen kann.
von Cha-woma M. (Firma: --------------) (cha-ar-196)
Jens B. schrieb:
> Wie kann das sein?
Deine Sicherung ist wohl zuverlässiger wie dein Verstand!
Wenn du weniger Leistung ansteckst als vorher dran waren, dann haste
keine Überlastproblem.
Du hast einen Fehler in dem Pizzaofen!
Wenn da 10A -> 2,4 kW auch deinen alten Ofen mit 3kW "abkonnten", dann
würde ich einen Defekt an deinen
> wie kann das sein?
Pizzaofen sehr stark vermuten!
Wenn neu gekauft geh zurüch zum Händler und gib ihm das teil zur
Überprüfung zurück.
Gebraucht gekauft, Verkäufer mal fragen was er dazu sagt.
Geerbt oder Geschenkt?
von Carypt C. (carypt)
Eine Heizwendel könnte durch thermische Ausdehnung evtl internen
Kurzschluß mit resultierendem kleinerem Gesamtwiderstand haben.
Glas wird bei 500°C zum Leiter.
Kann es sein daß evtl Ruß Stromleitung verursacht. Wärmeausdehnung .
ich finde auf die Schnelle kein Widerstandsverhalten von Ruß, ist es ein
Kalt- oder Heißleiter ?
kondenswasser ?
ist der Erdungsschutzleiter wirklich mit dem Gehäuse verbunden ?
Sorry für die Unklarheiten. Mit FI meinte ich einen
Fehlerstromschutzschalter, also etwas das anspringt wenn es zwischen den
Phasen eine Differenz gibt, ich glaube 50mA sind da normal. Aber der ist
ja gerade eben nicht angesprungen.
Also weiter.....
Hab nun noch etwas hin und her probiert. Die Sicherung hat noch 3 mal
angesprochen, dann nicht mehr.
Ein Problem durch lange (Jahre) Nichtbenutzung? Feuchtigkeit?
Das Oben und Unten Element ist getrennt schaltbar. Oben 2,4A, Unten 2A,
zusammen 4,4A (mit Zangenmessgerät getestet)
Unten gab es gar kein Problem, Oben ging die Sicherung sofort beim
Zuschalten raus (da war es schon heiss).
Jetzt scheint es zu gehen. Die max Temp is ~280°C (beide Elemente
zusammen), für Pizza etwas niedrig.
Die Lampe bleibt komplett an, ist daher schwer zu sagen ob/wann Elemente
ab-/zuschalten.
Ich werde wohl nichts mehr umbauen und schauen dass ich den so loswerde.
Hab noch andere und einen Pizzastahl für den Backofen, das funktioniert
auch gut.
Danke für die rege Beteiligung!
Schade ! keine Lösung des Rätsels, hmm , aber gut. ok
von J. S. (jojos)
der Fehler wird wieder auftreten wenn du ein Dutzend hungrige Gäste am
Tisch sitzen hast.
Murphy lebt...
> ab-/zuschalten.
Der Heizt dauern!
Der ist Defekt!
> auch gut.
Momentmal, du willst einen anderen arglosen deinen Schrott für gutes
Geld andrehen?
Klingt in der Tat so, als wenn demnächst ein Pizzaofen "Dachbodenfund,
aus Nachlass, konnte ich nicht prüfen" in der e-Bucht angeboten wird.
von Karls Q. (karlsquell)
Der Klassiker auf Ebay... defekten Schrott als neuwertig zu verkaufen
>> auch gut.
> Geld andrehen?
Was soll bitte der dumme Kommentar? Wo ist das Schrott? Ich habe alle
Messwerte, wer Lust hat kann ja umbauen. Wer mit den 280°C leben kann
kann dass doch bitte auch selber entscheiden. Der normale Backofen geht
nur bis 230°C oder 250°C und viele sind damit zufrieden.
Nach dem Dauertest heute gehe ich davon aus dass er geht, teste sicher
nochmal um sicher zu gehen.
Jens B. schrieb:
> Die max Temp is ~280°C (beide Elemente zusammen), für Pizza etwas
> niedrig.
Na ja, schnell schwarze Pizzen wollen vor allem die takeaways haben,
damit der Kunde nicht 15 min warten muss. Zu Hause sind schon 220
ausreichend, der Teig geht dann auch besser auf bevor die Pepperoni
verascht wird.
Aber zum bleifrei-löten ist es zu wenig.
Pizzaöfen für Pizzerien gibt es übrigens fertig
https://pizza1.de/effeuno-p150h-450-elektro-pizzaofen
die muss man nicht tunen bis der Kunststoff schmilzt, das Blech
korrodiert, die Heizelemente verglühen.
Ist eigentlich schon mal erwähnt worden,
was das für ein Modell ist? Hat der einen Lüfter?
von Thomas W. (goaty)
Hab ewig bei einem "Ferrari" Pizzaofen der Nachbarin mit der
Leckstromzange nach dem sporadischen Auslösen des FI gesucht.
Passierte immer nur beim öffnen des Deckels, wenn Feuchtigkeit nach
hinten in den Bereich des Thermostaten lief.
Ziemlicher Schrott diese Geräte. Trotz Komplettreinigung war immer noch
5mA zu messen, wenn das Gerät komplett abgeschaltet war.
Vermutlich haben sich irgendwelche Isolatoren am Thermostat mit
Feuchtigkeit vollgesogen. Hab´s aufgegeben.
Isolationswiderstand war so im 10MOhm Bereich.
kürzlich lief mir mal so ein Ofen von Severin zu.
Ich wollte den Timer (mech) heraus operieren.
Das war zwar alles soweit verschraubt, aber immer noch
ein uglaubliches Gegnaggel. Und ich hab sogar JIS-Schraubendreher.
Reparieren darf man sowas nicht wirklich wollen,
ausser das Design ist einem danach egal ;-]
von J. S. (jojos)
steht doch im ersten Post, mit G3 Pizzaofen findet Google diese
Ferraris. Und die Kopien gibt es für unter 100 €, kein Profigerät für
800 €.
Und es geht dabei um die Napoletanas die in 60 s durch sind und das
Tigerflecken Muster haben müssen. Pepperoni gehören da auch nicht drauf,
darum wären die mir auch zu langweilig.
Vielleicht das Teil mal beim Elektriker nach VDE0700 prüfen lassen.
J. S. schrieb:
> Tigerflecken
von J. S. (jojos)
na die Leopardenstreifen
von Rbx (rcx)
Das auf jeden Fall, jedenfalls als "Pizza-Ofen". Nun kann man aber
durchaus den normalen Backofen (mit Grill) benutzen. Man kann auch noch
Backpulver einsetzen, oder Sauerteig, Weisbrotmehl dazumischen usw. und
bis man hinsichtlich der Technik noch nicht im grünen Bereich ist (was
bei mir der Fall ist), hat man wohl noch Luft nach oben - bevor man
einen 500°C Ofen besorgt.
Ich denke meist, man sollte es nicht übertreiben mit den Investitionen.
Können statt kaufen. Und dieser Spruch ist bei Pizzen schon kritisch.
(Effeuno P134H® 509 | Pizzaofen der Superlative
 https://www.youtube.com/watch?v=N25PqaKLD4w)
(How to Make NEAPOLITAN PIZZA DOUGH like a World Best Pizza Chef
https://www.youtube.com/watch?v=8Q_9h6VKm9c)
von Joachim S. (oyo)
Mein "Alfredo"-Pizzaofen (der dem G3 sehr ähnlich ist) hat nach vielen
Jahren treuer Dienste letztes Jahr beim Aufheizen auch plötzlich die
Sicherung oder den FI rausspringen lassen.
Nachdem ich das Ding auseinandergeschraubt hatte, war das Problem
schnell zu erkennen: Da war eine Lüsterklemme verbaut, deren Plastik
durch die Hitze offenbar weich geworden war, was dann einen Kurzschluss
verursacht hatte.
von Manfred P. (pruckelfred)
Michael B. schrieb:
>> niedrig.
> verascht wird.
Komisch, neulich war der Tester von Kabel Eins in der Pizzabude: Der
lässt seinen Teig zwei Tage im Kühlschrank reifen und backt dann im
Steinofen nur 3 Minuten, aber bei 400°C.
Ist wohl ein Unterschied, ob der sachkundige Italiener frischen Teig
macht oder Laberkopp Wagner-Tk aufbäckt.
Das Problem gab es hier mit einem Wasserkocher, wo Wasser durch den
Spalt zwischen Topf und Kunststoffuß in die Keramik zieht.
Ist aber für diesen Fall nicht relevant, da eben nicht der FI kommt. Das
Ding muß fett Überstrom ziehen, damit der LS auslöst. Nach einer
Demontage sollten eigentlich Spuren sichtbar werden, Strom macht
schwarz.
Oder sich einen Isolationstester kaufen und selbst mal gucken?
Beitrag "Re: Isolationstestgerät"
Aber, ob das wirklich helfen kann, diesen zeitabhängigen / sporadischen
Fehler zu finden? Er müsste mal ganz schnell sein und direkt nach dem
Abflug messen, bevor das Ding wieder abkühlt.
von Kay-Uwe R. (dfias)
Radio Eriwan schreibt dazu:
> Im Prinzip ja, aber ...
> Der FI kennt weder einen zufließenden, noch einen abfließenden Strom.
> Wenn er etwas vergleicht, dann den (gleichgerichteten) Summenstrom
> (Common Mode) gegen einen Schwellenwert. Mehr Details kennt er nicht
> und die Energieflussrichtung schon garnicht.
Ein Fehler der sporadisch auftritt ist kein Fehler.
Sowas ist eine Systemeigenschaft.
Und kann was passieren?
Auf den ersten Blick würde ich sagen: "Nein!"
Aber, wenn schon die Sicherung "rausfliegt", und man dann erst mal
schaut ob denn die Sicherung nicht der Fehler ist.
Dann sollte man die "rote" Flagge schwenken!
> wie kann das sein?
Dann ist der Fehler wohl der TO selbst.
> nicht der FI.
> Wie kann das sein?
Weil der Fehlersucher keine Ahnung hat, dass ist  oft auch ein Fehler!
Das Beste kommt aber noch!
>>> auch gut.
>> Geld andrehen?
Das zeigt endgültig was für eine "Type" der TO ist
> Wo ist das Schrott?
Noch nicht mal das!
Das Ding ist eigentlich  brandgefährlich, und zwar im wahrsten Sinne des
Wortes!
> Ich habe alle
Nur haste du vor den potentiellen Käufer darüber vorsätzlich im Unklaren
zu lassen.
Lügen nennt man sowas!
Glück gehabt, hätte auch der FI defekt sein können nicht auslösen
können!
Dann könntest du Pizzen u.U. in Rollstuhl genießen.
> verursacht hatte.
Aber CE-Kennzeichen hatte der Pizzenbräter schon!
Das Verschweigen eines Defekts gegenüber einem arglosen Käufer ist nicht
nur lügen, sondern auch betrügen. § 263 StGB.
Klar, so ein Gerät ist kein Profibackofen. Wenn er nach 200 Pizzen "die
Löffel streckt", dann kann ein neues Heizelement eingebaut werden oder
er wird gegen einen neuen ausgetauscht. Gerätekosten von 50 Cent pro
Pizza sollte man einplanen. Solch ein Gerät benötigt nur einen Bruchteil
der Energie eines normalen Backofens und liefert ein deutlich besseres
Ergebnis.
Jens B. schrieb:
> Wer mit den 280°C leben kann kann dass doch bitte auch
Proportional zur Backdauer trocknet die Pizza mehr und mehr aus.
Backdauer
Steinofen 450°C: 1,5 Minuten
Elektrischer Pizzaofen: 2-3 Minuten
G3 Ferrari, Ariete 909, Alfredo.. 390°C: 4-5 Minuten
Normaler Backofen 250°C: 12-15 Minuten.
4-5 Minuten Backzeit mit dem G3 sind ein guter Kompromiss und ungefähr
das Limit, was man Zuhause mit einfachen Mitteln als Hobby-Pizzabäcker
erreichen kann.
Zubereitung für Napolitana. Achtung, nicht mit Oregano würzen!
- Pizzamehl Typ 00 mit mindestens >= 12% Eiweißgehalt
  (Thumbs up für "Caputo Couco" und "La Farina 14")
- 155g Mehl, 100g Wasser mit 1g gelöster Hefe, 5g Salz
  (65% Wassergehalt)
- Teig 24h gehen lassen, 6 Stunden vor dem Backen Kugel formen
- Den Teig auf Hartweizengrieß ausbreiten, den Rand nicht
  zusammendrücken, nicht mit dem Nudelholz ausrollen
- Ganze geschälte Tomaten ohne Brühe mit der Hand zerdrücken
- Tomaten mit Salz abschmecken und dünn auf den Teig streichen
- Optional geriebenen Parmesankäse draufstreuen
- 6 trockene Mozzarellastücke (nicht aus der Lake) drauflegen
- Backofen 10 Minuten auf Stufe 2,5 vorheizen, Pizzastein 350°C
- Pizza in den Ofen geben, auf Stufe 3 erhöhen
- Timer auf 4 Minuten -> Pizza 4 lang Minuten backen
- Nach dem Backen einige frisch geerntete Basilikumblätter draufstreuen
Rezept und Zubereitung stammen größtenteils aus diesem Video.
Die Mengen sind an einen Durchmesser von 27-28cm angepasst.
https://www.youtube.com/watch?v=vf0god0LtP8
von J. S. (jojos)
Wer jetzt Hunger bekommen hat: bei Lidl ist so ein Ofen für 80 € im
Angebot.
> Angebot.
Und, noch zwei Tage, die Tk-Fertigware dazu im Sonderangebot.
von Rbx (rcx)
Waldi hat übrigens zu vielen Themen ganz gute Hinweise. Er meinte auch
mal, das er auch gelegentlich durchgeweichte Pizzen hat - bzw. wie man
das auf die schnelle fixen kann. Meistens geht das eher schlecht, also
sollte man schauen, dass man den Teig kurz vor Hineingabe in den Ofen
zügig mit der Tomatensoße bestreicht, nicht zu schwer belegt und mit dem
Teig formen noch etwas übt in dieser Richtung (nicht zu dünn in der
Mitte z.B.)
Tipps und Tricks für den G3 Ferrari | Wie gelingt die perfekte Pizza!?
https://www.youtube.com/watch?v=-9cppkFCSyo
Beim Mehl ist wichtig, dass es "doppelgriffig" ist (bei uns "Instant" -
Mehl)  und der Wassergehalt beim Teig so bei 60-62%. Ich nehme lieber
etwas weniger Wasser (58-60%), damit der Teig am Ende nicht so klebt.
Die richtigen Maße für 2x250g habe ich noch nicht raus (meistens zu
wenig)
Beim normalen Küchenbackofen mit 250°C, Grill, Pizzastein und oberste
Stufe (direkt unterm Grill) braucht die Pizza auch nur ein paar Minuten.
10 Minuten wären schon zuviel, da wird der Teig zu hart. 4,5,6 Minuten
kann man versuchen, eventuell mehr, aber dann ist die Gefahr des
Aushärtens recht groß.
Tiefkühlpizzen sind kein Vergleich, die schmecken weder so schön nach
Hefe, noch kommen sie mit dem Mozzarella-Belag mit.
Dafür machen sie weniger Schweinerei, und brauchen keine so lange
Vorheizzeit für den Pizzastein.
Aber man kann natürlich mehrere Pizzen in einem Rutsch verarbeiten, und
die dann selber einfrieren für Folgetage.
Wenn man keine Pizzaschaufel und ähnliches hat, kann man Pizza auch auf
einem Blech backen, und dann Vierecke rausschneiden - ziemlich gute
Pizzen dieser Art gab es früher bei uns in den Städten zum Mitnehmen für
wenig Geld.
Blechpizza | einfaches Rezept
https://www.youtube.com/watch?v=uJWRCAunc-U
>> wie kann das sein?
Bei genügend Blindleistung kann schon mal die Sicherung auslösen.
Sollte aber der Leistung die Augenbinde abgefallen sein, funktioniert
alles wieder zufriedenstellend, wie in den ersten Tagen.
Ende der Blödelei.
Und wer weiß, ob der Sichungsautomat nicht schon nachgelassen hat.
mfg
B e r n d W. schrieb:
> Solch ein Gerät benötigt nur einen Bruchteil der Energie eines normalen
> Backofens und liefert ein deutlich besseres Ergebnis.
Blöd nur, wenn man kein Single ist und nicht nur Fertigpizza aufwärmt,
denn Focaccia, Flammkuchen, Familienpizza, Calzone, Dinnerle,
Pizzaladiere und was man der Abwechslung halber noch alles aus Pizzateig
macht passt da nicht rein.
Rbx schrieb:
> ziemlich gute Pizzen dieser Art gab es früher bei uns in den Städten zum
> Mitnehmen für wenig Geld.
Hmm, bei uns waren die immer schlecht, zumal nur das erste Stück frisch
war, der Rest aufgewärmt.
Wagner ist seit dem es GustavoGusto gibt aber ziemlich abgeschlagen, da
hat sich Nestlé einen Ladehüter aufgekauft den es nur noch zum halben
Preis los wird um die Produktionsanlagen nicht abreissen zu müssen. Und
auch vorher hatte Wagner wenig mit Pizza zu tun, erinnerte eher an
Blätterteig/Mürbeteig.
Komisch aber auch, so ein Pruckelfred glaubt auch ans Fernsehprogramm,
direkt vor und nach dem Sandmännchen. Mir ist eine Pizza lieber, bei der
ich die Achtel in die Hand nehmen kann ohne dass die Spitze abknickt und
der Belag runter rutscht, und dazu muss der Teig halt warm werden, nicht
nur oberflächlich schwarz.
> Preis los wird ...
Ihren Wunschpreis erzielt wohl keine Pizza über längere Zeit, auch Dr.
Oetker schiebt gerade wieder Sonderangebote durch den Handel.
Wer viel Teig mag, ist mit Wagner BigCity gut bedient.
Jawohl, ich glaube, was der Pizzamann da gezeigt hat.
Dann bist Du mit Tk-Fertigpizza gut bedient, lange genug im
Umluftbackofen getrocknet. Da erinnert der Boden dann partiell an
Knäckebrot oder Pappe. Der Belag rutscht auch nicht weg, da er wenig
Gewicht hat.
Für mich darf der Boden gerne etwas weich sein, ich mag keinen Zwieback
mit Tomatensauce.
von Rbx (rcx)
Bei uns war das erst in den letzten Jahren beobachtbar. Eher abstoßend.
Mittlerweile gibt es auch auch so bestimmte Fertigpizzen bei
Lieferservicen oder ähnlichem - die finde ich gar nicht schlecht.
"früher" ist genauer übersetzt mit "vor über 30 Jahren".
Nach Braunschweig sind wir oft zu einer Pizzaausgabe am Bohlweg
gefahren. Die Pizza da war jetzt nicht herausragend, aber sie schmeckte,
sonst wäre das nicht so ein beliebter Motorradfahrertreff geworden.
Ich nehme (aktuell) meistens Dr.Oetker Speziale (vorzugsweise im
Sonderangebot) mit Schinken und Pilzen. So ähnlich war früher die
(hervorragende) Blechpizza bei uns, die so gut schmeckte, auch belegt.
Gerade eine dieser letzten Pizzaausgaben hatte mich ein wenig an die
Pizza von damals erinnert. Nicht unbedingt nahe dran, aber doch
irgendwie..
Dann kam die Fastenzeit, und dann ging die Thematik durch die Decke..
(Falafel wollte ich auch machen - bin ich aber gar nicht zu gekommen)
Kommt mir bekannt vor, ein paar Meter neben MeckDoof. Aber, wenn ich mal
dort war, eher, um Leute zu treffen. Du kennst noch den Gespannfahrer
Tetzlaff mit seiner Warnweste?
Natürlich nur im Sonderangebot, mein Gefrierschrank ist immer gut
gefüllt. Aktuell wurden zwei "Dr. Oekter Ofenfrische" eingelagert, aber
auch die "Wagner Big City" finde ich ganz gut.
von Rbx (rcx)
Eigentlich nicht. Wenn da was auffällig war, dann eher, unauffällige
ungetunte Kisten. Die Mehrheit war hoch aufgerüstet, bzw. -gepimt.
Ich selbst war auch nur gelegentlich da, z.B. wenn die Saison losging im
Frühjahr, als lohnenswertes erstes Fernziel.
Fertig_Pizza? igitt.
Wer Analogkäse und Separatorenfleisch mag, greift zu.
Ist ja schon interessant mit welchen Wortschöpfungen man den Kunden
täuscht.
Ich "bastele" sie mir lieber selbst, da kenne ich die Bestandteile.
Na Mahlzeit.
Nach einigen mehr oder weniger gelungenen Versuchen, einen brauchbaren
Pizzateig selber herzustellen, verwende ich nun Fertigteig aus dem
Kühlregal, belege aber selber, meist verschieden auf den
Kuchenblechsektoren. Nicht haushoch, sondern einfache Varianten wie
Tomate/Mozzarella, (frische!) Champignons/verschiedene Käse oder
Parmaschinken/Gorgonzola (kulinarisch interessant sogar mit Kochschinken
als Banausenalternative).
Geht trotzdem schnell und Wagner und Dr. Oetker können einpacken.
Gebe aber gerne zu, dass die "Ofenfrische" im Greek-Style, also mit
Gyros etc. lecker ist.
Was macht man eigentlich mit der weissen Kugel wenn man den Mozzarella
ausgetrunken hat?
von Horst S. (fahnder99)
Eigentlich schade dass nie aufgelöst wurde, denn auch bei mir flog mit
G3 schon die Sicherung, und zwar die Haupt gleich mit.
Nun bin ich dazu übergegangen, den Kühlschrank bei Backen auszustöpseln.
Komisch, aber klappt.
von H. H. (Gast)
Du backst im Kühlschrank?
von Dergute W. (derguteweka)
Altes deutsches Liedgut:
1. Strophe: Meine Oma faehrt im Huehnerstall Motorrad...
2. Strophe: Meine Oma backt im Kuehlschrank eine Torte...
scnr,
WK
Backofen und Kühlschrank hängen also an der selben Phase?
von Nevs (noname_user)
So langsam verkommt das Forum hier zu ner Art Schnatterplattform für
gelangweilte nicht Weiber sondern Kerle? Könnt ihr nicht mal beim Thema
bleiben? Ist ja schlimm hier geworden, für sowas gibt es
Chat-Communitys.
> Chat-Communitys.
dann hau doch ab
