1 | root@mint:~# lshw
2 | mint
3 | description: Desktop Computer
4 | product: MS-7978 (Default string)
5 | vendor: MSI
6 | version: 2.0
7 | serial: Default string
8 | width: 64 bits
9 | capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
10 | configuration: boot=normal chassis=desktop family=Default string sku=Default string uuid=00000000-0000-0000-0000-4CCC6A66EB14
11 | *-core
12 | description: Motherboard
13 | product: Z170A GAMING M3 (MS-7978)
14 | vendor: MSI
15 | physical id: 0
16 | version: 2.0
17 | serial: G816310464
18 | slot: Default string
19 | *-firmware
20 | description: BIOS
21 | vendor: American Megatrends Inc.
22 | physical id: 0
23 | version: A.70
24 | date: 07/24/2016
25 | size: 64KiB
26 | capacity: 16MiB
27 | capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
28 | *-cache:0
29 | description: L1 cache
30 | physical id: 3c
31 | slot: L1 Cache
32 | size: 128KiB
33 | capacity: 128KiB
34 | capabilities: synchronous internal write-back data
35 | configuration: level=1
36 | *-cache:1
37 | description: L1 cache
38 | physical id: 3d
39 | slot: L1 Cache
40 | size: 128KiB
41 | capacity: 128KiB
42 | capabilities: synchronous internal write-back instruction
43 | configuration: level=1
44 | *-cache:2
45 | description: L2 cache
46 | physical id: 3e
47 | slot: L2 Cache
48 | size: 1MiB
49 | capacity: 1MiB
50 | capabilities: synchronous internal write-back unified
51 | configuration: level=2
52 | *-cache:3
53 | description: L3 cache
54 | physical id: 3f
55 | slot: L3 Cache
56 | size: 8MiB
57 | capacity: 8MiB
58 | capabilities: synchronous internal write-back unified
59 | configuration: level=3
60 | *-cpu
61 | description: CPU
62 | product: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
63 | vendor: Intel Corp.
64 | physical id: 40
65 | bus info: cpu@0
66 | version: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
67 | serial: To Be Filled By O.E.M.
68 | slot: U3E1
69 | size: 3679MHz
70 | capacity: 4200MHz
71 | width: 64 bits
72 | clock: 100MHz
73 | capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
74 | configuration: cores=4 enabledcores=4 threads=8
75 | *-memory
76 | description: System Memory
77 | physical id: 41
78 | slot: System board or motherboard
79 | size: 16GiB
80 | *-bank:0
81 | description: [empty]
82 | physical id: 0
83 | slot: ChannelA-DIMM0
84 | *-bank:1
85 | description: DIMM DDR4 Synchronous 2400 MHz (0.4 ns)
86 | product: 8ATF1G64AZ-2G3B1
87 | vendor: Micron
88 | physical id: 1
89 | serial: 120765C4
90 | slot: ChannelA-DIMM1
91 | size: 8GiB
92 | width: 64 bits
93 | clock: 2400MHz (0.4ns)
94 | *-bank:2
95 | description: [empty]
96 | physical id: 2
97 | slot: ChannelB-DIMM0
98 | *-bank:3
99 | description: DIMM DDR4 Synchronous 2400 MHz (0.4 ns)
100 | product: 8ATF1G64AZ-2G3B1
101 | vendor: Micron
102 | physical id: 3
103 | serial: 1207640D
104 | slot: ChannelB-DIMM1
105 | size: 8GiB
106 | width: 64 bits
107 | clock: 2400MHz (0.4ns)
108 | *-pci
109 | description: Host bridge
110 | product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
111 | vendor: Intel Corporation
112 | physical id: 100
113 | bus info: pci@0000:00:00.0
114 | version: 07
115 | width: 32 bits
116 | clock: 33MHz
117 | configuration: driver=skl_uncore
118 | resources: irq:0
119 | *-display
120 | description: VGA compatible controller
121 | product: HD Graphics 530
122 | vendor: Intel Corporation
123 | physical id: 2
124 | bus info: pci@0000:00:02.0
125 | version: 06
126 | width: 64 bits
127 | clock: 33MHz
128 | capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
129 | configuration: driver=i915 latency=0
130 | resources: irq:135 memory:de000000-deffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff
131 | *-generic:0 UNCLAIMED
132 | description: System peripheral
133 | product: Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
134 | vendor: Intel Corporation
135 | physical id: 8
136 | bus info: pci@0000:00:08.0
137 | version: 00
138 | width: 64 bits
139 | clock: 33MHz
140 | capabilities: msi pm cap_list
141 | configuration: latency=0
142 | resources: memory:df232000-df232fff
143 | *-usb
144 | description: USB controller
145 | product: 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
146 | vendor: Intel Corporation
147 | physical id: 14
148 | bus info: pci@0000:00:14.0
149 | version: 31
150 | width: 64 bits
151 | clock: 33MHz
152 | capabilities: pm msi xhci bus_master cap_list
153 | configuration: driver=xhci_hcd latency=0
154 | resources: irq:125 memory:df210000-df21ffff
155 | *-usbhost:0
156 | product: xHCI Host Controller
157 | vendor: Linux 5.4.0-26-generic xhci-hcd
158 | physical id: 0
159 | bus info: usb@1
160 | logical name: usb1
161 | version: 5.04
162 | capabilities: usb-2.00
163 | configuration: driver=hub slots=16 speed=480Mbit/s
164 | *-usb:0
165 | description: Keyboard
166 | product: USB-compliant keyboard
167 | vendor: MosArt Semiconductor Corp.
168 | physical id: 1
169 | bus info: usb@1:1
170 | version: 1.00
171 | capabilities: usb-1.10
172 | configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
173 | *-usb:1
174 | description: Mouse
175 | product: USB Optical Mouse
176 | vendor: PixArt
177 | physical id: 2
178 | bus info: usb@1:2
179 | version: 1.00
180 | capabilities: usb-2.00
181 | configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
182 | *-usb:2
183 | description: Mass storage device
184 | product: U3 Cruzer Micro
185 | vendor: SanDisk
186 | physical id: a
187 | bus info: usb@1:a
188 | version: 2.00
189 | serial: 355012191FD115D0
190 | capabilities: usb-2.00 scsi
191 | configuration: driver=usb-storage maxpower=200mA speed=480Mbit/s
192 | *-usbhost:1
193 | product: xHCI Host Controller
194 | vendor: Linux 5.4.0-26-generic xhci-hcd
195 | physical id: 1
196 | bus info: usb@2
197 | logical name: usb2
198 | version: 5.04
199 | capabilities: usb-3.00
200 | configuration: driver=hub slots=10 speed=5000Mbit/s
201 | *-generic:1
202 | description: Signal processing controller
203 | product: 100 Series/C230 Series Chipset Family Thermal Subsystem
204 | vendor: Intel Corporation
205 | physical id: 14.2
206 | bus info: pci@0000:00:14.2
207 | version: 31
208 | width: 64 bits
209 | clock: 33MHz
210 | capabilities: pm msi cap_list
211 | configuration: driver=intel_pch_thermal latency=0
212 | resources: irq:18 memory:df231000-df231fff
213 | *-generic:2
214 | description: Signal processing controller
215 | product: 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0
216 | vendor: Intel Corporation
217 | physical id: 15
218 | bus info: pci@0000:00:15.0
219 | version: 31
220 | width: 64 bits
221 | clock: 33MHz
222 | capabilities: pm bus_master cap_list
223 | configuration: driver=intel-lpss latency=0
224 | resources: irq:16 memory:df230000-df230fff
225 | *-generic:3
226 | description: Signal processing controller
227 | product: 100 Series/C230 Series Chipset Family Serial IO I2C Controller #1
228 | vendor: Intel Corporation
229 | physical id: 15.1
230 | bus info: pci@0000:00:15.1
231 | version: 31
232 | width: 64 bits
233 | clock: 33MHz
234 | capabilities: pm bus_master cap_list
235 | configuration: driver=intel-lpss latency=0
236 | resources: irq:17 memory:df22f000-df22ffff
237 | *-communication
238 | description: Communication controller
239 | product: 100 Series/C230 Series Chipset Family MEI Controller #1
240 | vendor: Intel Corporation
241 | physical id: 16
242 | bus info: pci@0000:00:16.0
243 | version: 31
244 | width: 64 bits
245 | clock: 33MHz
246 | capabilities: pm msi bus_master cap_list
247 | configuration: driver=mei_me latency=0
248 | resources: irq:136 memory:df22e000-df22efff
249 | *-sata
250 | description: SATA controller
251 | product: Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode]
252 | vendor: Intel Corporation
253 | physical id: 17
254 | bus info: pci@0000:00:17.0
255 | logical name: scsi1
256 | version: 31
257 | width: 32 bits
258 | clock: 66MHz
259 | capabilities: sata msi pm ahci_1.0 bus_master cap_list emulated
260 | configuration: driver=ahci latency=0
261 | resources: irq:134 memory:df228000-df229fff memory:df22d000-df22d0ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:df22c000-df22c7ff
262 | *-cdrom
263 | description: DVD-RAM writer
264 | product: BDDVDRW CH12NS40
265 | vendor: HL-DT-ST
266 | physical id: 0.0.0
267 | bus info: scsi@1:0.0.0
268 | logical name: /dev/cdrom
269 | logical name: /dev/cdrw
270 | logical name: /dev/dvd
271 | logical name: /dev/dvdrw
272 | logical name: /dev/sr0
273 | version: 1.00
274 | capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
275 | configuration: ansiversion=5 status=nodisc
276 | *-pci:0
277 | description: PCI bridge
278 | product: 100 Series/C230 Series Chipset Family PCI Express Root Port #1
279 | vendor: Intel Corporation
280 | physical id: 1c
281 | bus info: pci@0000:00:1c.0
282 | version: f1
283 | width: 32 bits
284 | clock: 33MHz
285 | capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
286 | configuration: driver=pcieport
287 | resources: irq:120
288 | *-pci:1
289 | description: PCI bridge
290 | product: 100 Series/C230 Series Chipset Family PCI Express Root Port #3
291 | vendor: Intel Corporation
292 | physical id: 1c.2
293 | bus info: pci@0000:00:1c.2
294 | version: f1
295 | width: 32 bits
296 | clock: 33MHz
297 | capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
298 | configuration: driver=pcieport
299 | resources: irq:121 memory:df100000-df1fffff
300 | *-usb
301 | description: USB controller
302 | product: ASM1142 USB 3.1 Host Controller
303 | vendor: ASMedia Technology Inc.
304 | physical id: 0
305 | bus info: pci@0000:02:00.0
306 | version: 00
307 | width: 64 bits
308 | clock: 33MHz
309 | capabilities: msi msix pm pciexpress xhci bus_master cap_list
310 | configuration: driver=xhci_hcd latency=0
311 | resources: irq:18 memory:df100000-df107fff
312 | *-usbhost:0
313 | product: xHCI Host Controller
314 | vendor: Linux 5.4.0-26-generic xhci-hcd
315 | physical id: 0
316 | bus info: usb@3
317 | logical name: usb3
318 | version: 5.04
319 | capabilities: usb-2.00
320 | configuration: driver=hub slots=2 speed=480Mbit/s
321 | *-usbhost:1
322 | product: xHCI Host Controller
323 | vendor: Linux 5.4.0-26-generic xhci-hcd
324 | physical id: 1
325 | bus info: usb@4
326 | logical name: usb4
327 | version: 5.04
328 | capabilities: usb-3.10
329 | configuration: driver=hub slots=2 speed=10000Mbit/s
330 | *-pci:2
331 | description: PCI bridge
332 | product: 100 Series/C230 Series Chipset Family PCI Express Root Port #9
333 | vendor: Intel Corporation
334 | physical id: 1d
335 | bus info: pci@0000:00:1d.0
336 | version: f1
337 | width: 32 bits
338 | clock: 33MHz
339 | capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
340 | configuration: driver=pcieport
341 | resources: irq:122
342 | *-pci:3
343 | description: PCI bridge
344 | product: 100 Series/C230 Series Chipset Family PCI Express Root Port #11
345 | vendor: Intel Corporation
346 | physical id: 1d.2
347 | bus info: pci@0000:00:1d.2
348 | version: f1
349 | width: 32 bits
350 | clock: 33MHz
351 | capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
352 | configuration: driver=pcieport
353 | resources: irq:123
354 | *-pci
355 | description: PCI bridge
356 | product: ASM1083/1085 PCIe to PCI Bridge
357 | vendor: ASMedia Technology Inc.
358 | physical id: 0
359 | bus info: pci@0000:04:00.0
360 | version: 03
361 | width: 64 bits
362 | clock: 33MHz
363 | capabilities: pci msi pm pciexpress normal_decode bus_master cap_list
364 | resources: iomemory:202001f10-202001f0f
365 | *-pci:4
366 | description: PCI bridge
367 | product: 100 Series/C230 Series Chipset Family PCI Express Root Port #12
368 | vendor: Intel Corporation
369 | physical id: 1d.3
370 | bus info: pci@0000:00:1d.3
371 | version: f1
372 | width: 32 bits
373 | clock: 33MHz
374 | capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
375 | configuration: driver=pcieport
376 | resources: irq:124 ioport:e000(size=4096) memory:df000000-df0fffff
377 | *-network
378 | description: Ethernet interface
379 | product: Killer E2400 Gigabit Ethernet Controller
380 | vendor: Qualcomm Atheros
381 | physical id: 0
382 | bus info: pci@0000:06:00.0
383 | logical name: enp6s0
384 | version: 10
385 | serial: 4c:cc:6a:66:eb:14
386 | capacity: 1Gbit/s
387 | width: 64 bits
388 | clock: 33MHz
389 | capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
390 | configuration: autonegotiation=on broadcast=yes driver=alx latency=0 link=no multicast=yes port=twisted pair
391 | resources: irq:19 memory:df000000-df03ffff ioport:e000(size=128)
392 | *-generic:4
393 | description: Signal processing controller
394 | product: 100 Series/C230 Series Chipset Family Serial IO UART #0
395 | vendor: Intel Corporation
396 | physical id: 1e
397 | bus info: pci@0000:00:1e.0
398 | version: 31
399 | width: 64 bits
400 | clock: 33MHz
401 | capabilities: pm bus_master cap_list
402 | configuration: driver=intel-lpss latency=0
403 | resources: irq:20 memory:df22b000-df22bfff
404 | *-isa
405 | description: ISA bridge
406 | product: Z170 Chipset LPC/eSPI Controller
407 | vendor: Intel Corporation
408 | physical id: 1f
409 | bus info: pci@0000:00:1f.0
410 | version: 31
411 | width: 32 bits
412 | clock: 33MHz
413 | capabilities: isa bus_master
414 | configuration: latency=0
415 | *-memory UNCLAIMED
416 | description: Memory controller
417 | product: 100 Series/C230 Series Chipset Family Power Management Controller
418 | vendor: Intel Corporation
419 | physical id: 1f.2
420 | bus info: pci@0000:00:1f.2
421 | version: 31
422 | width: 32 bits
423 | clock: 33MHz (30.3ns)
424 | configuration: latency=0
425 | resources: memory:df224000-df227fff
426 | *-multimedia
427 | description: Audio device
428 | product: 100 Series/C230 Series Chipset Family HD Audio Controller
429 | vendor: Intel Corporation
430 | physical id: 1f.3
431 | bus info: pci@0000:00:1f.3
432 | version: 31
433 | width: 64 bits
434 | clock: 33MHz
435 | capabilities: pm msi bus_master cap_list
436 | configuration: driver=snd_hda_intel latency=32
437 | resources: irq:137 memory:df220000-df223fff memory:df200000-df20ffff
438 | *-serial
439 | description: SMBus
440 | product: 100 Series/C230 Series Chipset Family SMBus
441 | vendor: Intel Corporation
442 | physical id: 1f.4
443 | bus info: pci@0000:00:1f.4
444 | version: 31
445 | width: 64 bits
446 | clock: 33MHz
447 | configuration: driver=i801_smbus latency=0
448 | resources: irq:16 memory:df22a000-df22a0ff ioport:f040(size=32)
449 | *-pnp00:00
450 | product: PnP device PNP0c02
451 | physical id: 1
452 | capabilities: pnp
453 | configuration: driver=system
454 | *-pnp00:01
455 | product: PnP device PNP0400
456 | physical id: 2
457 | capabilities: pnp
458 | configuration: driver=parport_pc
459 | *-pnp00:02
460 | product: PnP device PNP0303
461 | physical id: 3
462 | capabilities: pnp
463 | configuration: driver=i8042 kbd
464 | *-pnp00:03
465 | product: PnP device PNP0501
466 | physical id: 4
467 | capabilities: pnp
468 | configuration: driver=serial
469 | *-pnp00:04
470 | product: PnP device PNP0c02
471 | physical id: 5
472 | capabilities: pnp
473 | configuration: driver=system
474 | *-pnp00:05
475 | product: PnP device PNP0c02
476 | physical id: 6
477 | capabilities: pnp
478 | configuration: driver=system
479 | *-pnp00:06
480 | product: PnP device PNP0b00
481 | physical id: 7
482 | capabilities: pnp
483 | configuration: driver=rtc_cmos
484 | *-pnp00:07
485 | product: PnP device INT3f0d
486 | vendor: Interphase Corporation
487 | physical id: 8
488 | capabilities: pnp
489 | configuration: driver=system
490 | *-pnp00:08
491 | product: PnP device PNP0c02
492 | physical id: 9
493 | capabilities: pnp
494 | configuration: driver=system
495 | *-pnp00:09
496 | product: PnP device PNP0c02
497 | physical id: a
498 | capabilities: pnp
499 | configuration: driver=system
500 | *-pnp00:0a
501 | product: PnP device PNP0c02
502 | physical id: b
503 | capabilities: pnp
504 | configuration: driver=system
505 | *-pnp00:0b
506 | product: PnP device PNP0c02
507 | physical id: c
508 | capabilities: pnp
509 | configuration: driver=system
510 | *-scsi
511 | physical id: d
512 | bus info: usb@1:10
513 | logical name: scsi6
514 | capabilities: emulated scsi-host
515 | configuration: driver=usb-storage
516 | *-disk
517 | description: SCSI Disk
518 | product: U3 Cruzer Micro
519 | vendor: SanDisk
520 | physical id: 0.0.0
521 | bus info: scsi@6:0.0.0
522 | logical name: /dev/sda
523 | version: 8.02
524 | serial: u
525 | size: 3835MiB (4022MB)
526 | capabilities: removable
527 | configuration: logicalsectorsize=512 sectorsize=512
528 | *-medium
529 | physical id: 0
530 | logical name: /dev/sda
531 | size: 3835MiB (4022MB)
532 | capabilities: partitioned partitioned:dos
533 | configuration: signature=4089a39b
534 | *-volume:0
535 | description: Windows FAT volume
536 | vendor: mkfs.fat
537 | physical id: 2
538 | logical name: /dev/sda2
539 | version: FAT12
540 | serial: 1ac3-20ed
541 | size: 15EiB
542 | capabilities: primary boot fat initialized
543 | configuration: FATs=2 filesystem=fat
544 | *-volume:1
545 | description: EXT4 volume
546 | vendor: Linux
547 | physical id: 3
548 | logical name: /dev/sda3
549 | logical name: /var/log
550 | version: 1.0
551 | serial: 11f1c4fe-d377-42d8-acae-1f1d8226c882
552 | size: 1941MiB
553 | capacity: 1941MiB
554 | capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
555 | configuration: created=2023-06-25 10:47:22 filesystem=ext4 label=writable lastmountpoint=/root/var/log modified=2023-06-25 10:47:36 mount.fstype=ext4 mount.options=rw,relatime mounted=2023-06-25 10:47:36 state=mounted
556 | *-power UNCLAIMED
557 | description: To Be Filled By O.E.M.
558 | product: To Be Filled By O.E.M.
559 | vendor: To Be Filled By O.E.M.
560 | physical id: 1
561 | version: To Be Filled By O.E.M.
562 | serial: To Be Filled By O.E.M.
563 | capacity: 32768mWh
