1 | //Main*****************
2 | #include <lvgl.h>
3 | #include "Arduino.h"
4 | #include "display.h"
5 | #include "lv_example_meter.h"
6 |
7 | Display screen;
8 |
9 | void setup() {
10 | Serial.begin(9600);
11 |
12 | /* Nastroiki displaja i touch */
13 | screen.init();
14 | screen.calibrovkatouch();
15 |
16 | /* Test bibleoteki lvgl version */
17 | String LVGL_Arduino = "Hello Arduino! ";
18 | LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
19 | Serial.println(LVGL_Arduino);
20 | Serial.println("I am LVGL_Arduino");
21 | Serial.println("Setup done");
22 |
23 | /* Podprograma Meter */
24 |
25 | lv_example_meter_2();
26 | }
27 |
28 | void loop() {
29 | screen.routine();
30 | delay(5);
31 |
32 | }
33 | //LV EXAMPEL.H********************
34 | #ifndef __LV_EXAMPLE_METER_H
35 | #define __LV_EXAMPLE_METER_H
36 |
37 | void lv_example_meter_1(void);
38 | void lv_example_meter_2(void);
39 | void lv_example_meter_3(void);
40 | void lv_example_meter_4(void);
41 |
42 | #endif
43 |
44 | //LV EXAMPEL.CPP***************
45 | #include "lvgl.h"
46 | #include "lv_example_meter.h"
47 | /*************** Example 2 ****************************/
48 | static void set_value_2(void * indic, int32_t v)
49 | {
50 | lv_meter_set_indicator_end_value(meter, (lv_meter_indicator_t*)indic, v);
51 | }
52 | /**
53 | * A meter with multiple arcs
54 | */
55 | void lv_example_meter_2(void)
56 | {
57 | meter = lv_meter_create(lv_scr_act());
58 | lv_obj_center(meter);
59 | lv_obj_set_size(meter, 200, 200);
60 |
61 | /Remove the circle from the middle/
62 | lv_obj_remove_style(meter, NULL, LV_PART_INDICATOR);
63 |
64 | /Add a scale first/
65 | lv_meter_scale_t * scale = lv_meter_add_scale(meter);
66 | lv_meter_set_scale_ticks(meter, scale, 11, 2, 10, lv_palette_main(LV_PALETTE_GREY));
67 | lv_meter_set_scale_major_ticks(meter, scale, 1, 2, 30, lv_color_hex3(0xeee), 15);
68 | lv_meter_set_scale_range(meter, scale, 0, 50, 270, 90);
69 |
70 | /Add a three arc indicator/
71 | lv_meter_indicator_t * indic1 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_RED), 0);
72 | lv_meter_indicator_t * indic2 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_GREEN), -10);
73 | lv_meter_indicator_t * indic3 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_BLUE), -20);
74 |
75 | /Create an animation to set the value/
76 | lv_anim_t a;
77 | lv_anim_init(&a);
78 | lv_anim_set_exec_cb(&a, set_value_2);
79 | lv_anim_set_values(&a, 0, 100);
80 | lv_anim_set_repeat_delay(&a, 100);
81 | lv_anim_set_playback_delay(&a, 100);
82 | lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
83 |
84 | lv_anim_set_time(&a, 2000);
85 | lv_anim_set_playback_time(&a, 500);
86 | lv_anim_set_var(&a, indic1);
87 | lv_anim_start(&a);
88 |
89 | lv_anim_set_time(&a, 1000);
90 | lv_anim_set_playback_time(&a, 1000);
91 | lv_anim_set_var(&a, indic2);
92 | lv_anim_start(&a);
93 |
94 | lv_anim_set_time(&a, 1000);
95 | lv_anim_set_playback_time(&a, 2000);
96 | lv_anim_set_var(&a, indic3);
97 | lv_anim_start(&a);
98 | }
