Hello, I´m currently working with the impedance converter AD5933. I´m having some problems to compare the data that I get from the AD5933 with a LRC meter. I start my measurement by configurating my frequency start, the increment and number of increments. In my case I´m running frequency sweep with a range from 1kHz to 100kHz. I started by calculating the gain factor with a know impedance, and then I start my measurement. I get the real and the imaginary data from the register specify at the datasheet, then I calculate the magnitude and the impedance also with the formulas that are in the datasheet. However when I want to compare the impedance that I get with a LCR meter, the data is different and I don´t really know why. I have done some examples as explained in the datasheet but I don´t know if there is any detail that I´m missing. To double check my data I also got the resistive and reactive from my impedance convertor and the phase (as specify in the datasheet) but I have not yet have any success. Have someone had something similar? Thanks Daphne
Daphne schrieb: > However when I want to compare the impedance that I get with a LCR > meter, the data is different and I don´t really know why. Have you ever tested the readings with a pure ohmic resistor?
>However when I want to compare the impedance that I get with a LCR >meter, the data is different and I don´t really know why. Can you show a graph which compares the two impedance curves and phase curves? What device under test do you use? It could be a could idea to use a well known circuit like a LCR resonance circuit to test the measurement setup and compare it to the reference LCR meter.
Yes, I have try to read just ohmic resistance and I get the values right, I try with different resistances and I had no problem, however when I add a capacitor in parallel and then I run a frequency sweep and try the same with the LRC meter the results are not matching any more.
so from the datasheet (https://www.analog.com/media/en/technical-documentation/data-sheets/AD5933.pdf) I´m following the "measuring the phase across an impedance" section. The first step says that I should add a know impedance between the Vin and Vout, in my case I´m using a 200K resistor. From this value I should get the impedance phase of the system, my result is the chart attach. Once this step is done, it says in the datasheet that I should use an unknow impedance and also run a frequency sweep. Once I have those values I need to get the Impedance phase from the "unknow impedance", and to do so rest the impedance from the unknow resistance - phase from the system. I did this calculation and my results are the charts label "Unknow impedance phase". Once that part was done I compare with my LRC meter and the results were not that far from each other. However!! I run the same measurement with a capacitor, in this case a 4.3nF and did the same procedure and in the datasheet it says that the difference between capacitor to resistance should be -90. But I don´t get those results and the data that I obtain from the impedance converter AD5933 is not matching with the data from the LRC meter. I have check my calculations and the data but I have not been success on finding the error. Maybe if you see something that I´m not seeing you could please let me know :) Thanks! Daphne
>However!! I run the same measurement with a capacitor, in this case a >4.3nF and did the same procedure and in the datasheet it says that the >difference between capacitor to resistance should be -90 -90 .. what unit?
Do you understand what phase means? It is important to not confuse the phase angle given in degrees and the phase angle given in radiants.
