Hi, ich suche mir bereits einen Wolf und kann dieses File nicht finden. Weiß jemand wo man es bekommen kann?
libm.a gehört zu deiner toolchain und ist wohl in dessen Ordnern zu finden.
1 | /usr/lib/libm.a |
2 | /usr/lib/musl/lib/libm.a |
3 | /usr/x86_64-w64-mingw32/lib/libm.a |
4 | /usr/lib32/libm.a |
5 | /usr/i686-w64-mingw32/lib/libm.a |
6 | /usr/arm-none-eabi/lib/libm.a |
7 | /usr/arm-none-eabi/lib/thumb/v7-m/nofp/libm.a |
8 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+mve/hard/libm.a |
9 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti+mve/bp/hard/libm.a |
10 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti+fp/bp/softfp/libm.a |
11 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti+fp/bp/hard/libm.a |
12 | /usr/arm-none-eabi/lib/thumb/v8-m.base/nofp/libm.a |
13 | /usr/arm-none-eabi/lib/thumb/nofp/libm.a |
14 | /usr/arm-none-eabi/lib/thumb/v8-m.main/nofp/libm.a |
15 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti/bp/nofp/libm.a |
16 | /usr/arm-none-eabi/lib/thumb/v7e-m/nofp/libm.a |
17 | /usr/arm-none-eabi/lib/thumb/v6-m/nofp/libm.a |
18 | /usr/arm-none-eabi/lib/thumb/v7-r+fp.sp/softfp/libm.a |
19 | /usr/arm-none-eabi/lib/thumb/v7-r+fp.sp/hard/libm.a |
20 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti+dp/bp/softfp/libm.a |
21 | /usr/arm-none-eabi/lib/thumb/v8.1-m.main+pacbti+dp/bp/hard/libm.a |
22 | /usr/arm-none-eabi/lib/thumb/v8-m.main+fp/softfp/libm.a |
23 | /usr/arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libm.a |
24 | /usr/arm-none-eabi/lib/thumb/v7/nofp/libm.a |
25 | /usr/arm-none-eabi/lib/thumb/v7+fp/softfp/libm.a |
26 | /usr/arm-none-eabi/lib/thumb/v7+fp/hard/libm.a |
27 | /usr/arm-none-eabi/lib/thumb/v7e-m+dp/softfp/libm.a |
28 | /usr/arm-none-eabi/lib/thumb/v7e-m+dp/hard/libm.a |
29 | /usr/arm-none-eabi/lib/thumb/v7e-m+fp/softfp/libm.a |
30 | /usr/arm-none-eabi/lib/thumb/v7e-m+fp/hard/libm.a |
31 | /usr/arm-none-eabi/lib/thumb/v8-m.main+dp/softfp/libm.a |
32 | /usr/arm-none-eabi/lib/thumb/v8-m.main+dp/hard/libm.a |
33 | /usr/arm-none-eabi/lib/arm/v5te/softfp/libm.a |
34 | /usr/arm-none-eabi/lib/arm/v5te/hard/libm.a |
Kaj G. schrieb: > libm.a heißt anders als m.lib Compiler, deren Linker Libraries *.lib nennen, nutzen nicht die lib*.a-Schreibweise, also kann das was komplett anderes sein. Da der Threadstarter extrem präzise beschrieben hat, mit welchem Compiler bei welcher Anwendung sein Problem auftritt, bin ich mir ganz sicher, daß die beigefügte Datei nicht weiterhelfen wird. Aber wer weiß?
Harald K. schrieb: > Kaj G. schrieb: >> libm.a > > heißt anders als m.lib > > Compiler, deren Linker Libraries *.lib nennen, nutzen nicht die > lib*.a-Schreibweise, also kann das was komplett anderes sein. > > Da der Threadstarter extrem präzise beschrieben hat, mit welchem > Compiler bei welcher Anwendung sein Problem auftritt, bin ich mir ganz > sicher, daß die beigefügte Datei nicht weiterhelfen wird. > > Aber wer weiß? Ist das dein Versuch krampfhaft lustig zu sein?
Moin, Esmu P. schrieb: > Ist das dein Versuch krampfhaft lustig zu sein? Ich bin hin und her gerissen: Wieviel lustiger ist dieses File im Vergleich zur Bloedheit des Eingangspost? Ich glaube: Ziemlich viel. (Obwohl: ASCII-Pr0n waere noch lustiger gewesen) Was verursacht denn das Fehlen dieses Files auf deinem Rechner? Mangelhaftes Verhalten nach Windowsupdates? Blaehungen? Starke Monatsblutungen? Frage fuer einen Freund. scnr, WK
Esmu P. schrieb: > Ist das dein Versuch krampfhaft lustig zu sein? Vielleicht solltest Du einfach mal mehr Kontext liefern. Vielleicht brauchst Du die auch gar nicht, sondern wird nur irgendwo sinnloserweise referenziert, obwohl gar nicht nötig, wie man in Google an diversen Stellen lesen kann ...
Bei der NASA gab es mal eine m.lib für das Command Modul der Mondlandekapsel, ob er wohl das sucht ?
Rüdiger B. schrieb: > https://answers.ros.org/question/392236/link-fatal-error-lnk1104-cannot-open-file-mlib/ Da muß ich mich jetzt einmal durchkämpfen... Vielleicht geht es so...
Rüdiger B. schrieb: > Bei der NASA gab es mal eine m.lib für das Command Modul der > Mondlandekapsel, ob er wohl das sucht ? Vielleicht ist es auch das klassische troff mm Makropaket :) Obwohl troff Makros haben glaube ich nicht die Endung .lib. Aber egal, so wenig Mühe sich der Fragesteller mit seiner Frage gibt, so wenig wichtig kann für ihn die Antwort sein.
Hannes J. schrieb: > so wenig Mühe sich der Fragesteller mit seiner Frage gibt, so > wenig wichtig kann für ihn die Antwort sein. Das ist "Esmu", das ist so.
