1 | /**
2 | ******************************************************************************
3 | * @file SPI/DMA/main.c
4 | * @author MCD Application Team
5 | * @version V3.5.0
6 | * @date 08-April-2011
7 | * @brief Main program body
8 | ******************************************************************************
9 | * @attention
10 | *
11 | * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
12 | * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
13 | * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
14 | * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
15 | * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
16 | * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
17 | *
18 | * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
19 | ******************************************************************************
20 | */
21 |
22 | /* Includes ------------------------------------------------------------------*/
23 | #include "stm32f10x.h"
24 | #include "platform_config.h"
25 |
26 |
27 | /** @addtogroup STM32F10x_StdPeriph_Examples
28 | * @{
29 | */
30 |
31 | /** @addtogroup SPI_DMA
32 | * @{
33 | */
34 |
35 | /* Private typedef -----------------------------------------------------------*/
36 | typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
37 |
38 | /* Private define ------------------------------------------------------------*/
39 | #define BufferSize 32
40 |
41 | /* Private macro -------------------------------------------------------------*/
42 | /* Private variables ---------------------------------------------------------*/
43 | SPI_InitTypeDef SPI_InitStructure;
44 | DMA_InitTypeDef DMA_InitStructure;
45 | GPIO_InitTypeDef GPIO_InitStructure;
46 |
47 | uint8_t SPI_MASTER_Buffer_Tx[BufferSize] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06,
48 | 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C,
49 | 0x0D, 0x0E, 0x0F, 0x10, 0x11, 0x12,
50 | 0x13, 0x14, 0x15, 0x16, 0x17, 0x18,
51 | 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E,
52 | 0x1F, 0x20};
53 | uint8_t SPI_SLAVE_Buffer_Rx[BufferSize];
54 | __IO uint8_t TxIdx = 0;
55 | volatile TestStatus TransferStatus = FAILED;
56 |
57 |
58 | /* Private function prototypes -----------------------------------------------*/
59 | void RCC_Configuration(void);
60 | void GPIO_Configuration(void);
61 | TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
62 |
63 | /* Private functions ---------------------------------------------------------*/
64 |
65 | /**
66 | * @brief Main program
67 | * @param None
68 | * @retval None
69 | */
70 | int main(void)
71 | {
72 | /*!< At this stage the microcontroller clock setting is already configured,
73 | this is done through SystemInit() function which is called from startup
74 | file (startup_stm32f10x_xx.s) before to branch to application main.
75 | To reconfigure the default setting of SystemInit() function, refer to
76 | system_stm32f10x.c file
77 | */
78 |
79 | /* System clocks configuration ---------------------------------------------*/
80 | RCC_Configuration();
81 |
82 | /* GPIO configuration ------------------------------------------------------*/
83 | GPIO_Configuration();
84 |
85 | /* SPI_SLAVE_Rx_DMA_Channel configuration ---------------------------------------------*/
86 | DMA_DeInit(SPI_SLAVE_Rx_DMA_Channel);
87 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPI_SLAVE_DR_Base;
88 | DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SPI_SLAVE_Buffer_Rx;
89 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
90 | DMA_InitStructure.DMA_BufferSize = BufferSize;
91 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
92 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
93 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
94 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
95 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
96 | DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
97 | DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
98 | DMA_Init(SPI_SLAVE_Rx_DMA_Channel, &DMA_InitStructure);
99 |
100 | /* SPI_MASTER configuration ------------------------------------------------------*/
101 | SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
102 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
103 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
104 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
105 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
106 | SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
107 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
108 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
109 | SPI_InitStructure.SPI_CRCPolynomial = 7;
110 | SPI_Init(SPI_MASTER, &SPI_InitStructure);
111 |
112 | /* SPI_SLAVE configuration ------------------------------------------------------*/
113 | SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Rx;
114 | SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
115 | SPI_Init(SPI_SLAVE, &SPI_InitStructure);
116 |
117 | /* Enable SPI_MASTER NSS output for master mode */
118 | SPI_SSOutputCmd(SPI_MASTER, ENABLE);
119 |
120 | /* Enable SPI_SLAVE Rx request */
121 | SPI_I2S_DMACmd(SPI_SLAVE, SPI_I2S_DMAReq_Rx, ENABLE);
122 |
123 | /* Enable SPI_SLAVE */
124 | SPI_Cmd(SPI_SLAVE, ENABLE);
125 | /* Enable SPI_MASTER */
126 | SPI_Cmd(SPI_MASTER, ENABLE);
127 |
128 | /* Enable DMA1 Channel4 */
129 | DMA_Cmd(SPI_SLAVE_Rx_DMA_Channel, ENABLE);
130 |
131 | /* Transfer procedure */
132 | while (TxIdx < BufferSize)
133 | {
134 | /* Wait for SPI_MASTER Tx buffer empty */
135 | while (SPI_I2S_GetFlagStatus(SPI_MASTER, SPI_I2S_FLAG_TXE) == RESET);
136 | /* Send SPI_MASTER data */
137 | SPI_I2S_SendData(SPI_MASTER, SPI_MASTER_Buffer_Tx[TxIdx++]);
138 | }
139 |
140 | /* Wait for DMA1 channel4 transfer complete */
141 | while (!DMA_GetFlagStatus(SPI_SLAVE_Rx_DMA_FLAG));
142 |
143 | /* Check the correctness of written data */
144 | TransferStatus = Buffercmp(SPI_SLAVE_Buffer_Rx, SPI_MASTER_Buffer_Tx, BufferSize);
145 | /* TransferStatus = PASSED, if the transmitted and received data
146 | are equal */
147 | /* TransferStatus = FAILED, if the transmitted and received data
148 | are different */
149 |
150 | while (1)
151 | {}
152 | }
153 |
154 | /**
155 | * @brief Configures the different system clocks.
156 | * @param None
157 | * @retval None
158 | */
159 | void RCC_Configuration(void)
160 | {
161 | /* PCLK2 = HCLK/2 */
162 | RCC_PCLK2Config(RCC_HCLK_Div2);
163 |
164 | /* Enable peripheral clocks --------------------------------------------------*/
165 | /* Enable SPI_SLAVE DMA clock */
166 | RCC_AHBPeriphClockCmd(SPI_SLAVE_DMA_CLK, ENABLE);
167 |
168 | #ifdef USE_STM3210C_EVAL
169 | /* Enable GPIO clock for SPI_MASTER and SPI_SLAVE */
170 | RCC_APB2PeriphClockCmd(SPI_MASTER_GPIO_CLK | SPI_SLAVE_GPIO_CLK |
171 | RCC_APB2Periph_AFIO, ENABLE);
172 |
173 | /* Enable SPI_MASTER Periph clock */
174 | RCC_APB1PeriphClockCmd(SPI_MASTER_CLK, ENABLE);
175 |
176 | #else
177 | /* Enable SPI_MASTER clock and GPIO clock for SPI_MASTER and SPI_SLAVE */
178 | RCC_APB2PeriphClockCmd(SPI_MASTER_GPIO_CLK | SPI_SLAVE_GPIO_CLK |
179 | SPI_MASTER_CLK, ENABLE);
180 | #endif
181 | /* Enable SPI_SLAVE Periph clock */
182 | RCC_APB1PeriphClockCmd(SPI_SLAVE_CLK, ENABLE);
183 | }
184 |
185 | /**
186 | * @brief Configures the different GPIO ports.
187 | * @param None
188 | * @retval None
189 | */
190 | void GPIO_Configuration(void)
191 | {
192 | GPIO_InitTypeDef GPIO_InitStructure;
193 |
194 | #ifdef USE_STM3210C_EVAL
195 | /* Enable SPI3 Pins Software Remapping */
196 | GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE);
197 |
198 | /* Configure SPI_MASTER pins: SCK and MOSI */
199 | GPIO_InitStructure.GPIO_Pin = SPI_MASTER_PIN_SCK | SPI_MASTER_PIN_MOSI;
200 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
201 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
202 | GPIO_Init(SPI_MASTER_GPIO, &GPIO_InitStructure);
203 |
204 | /* Configure SPI_MASTER NSS pin */
205 | GPIO_InitStructure.GPIO_Pin = SPI_MASTER_PIN_NSS;
206 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
207 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
208 | GPIO_Init(SPI_MASTER_GPIO_NSS, &GPIO_InitStructure);
209 |
210 | #else
211 | /* Configure SPI_MASTER pins: NSS, SCK and MOSI */
212 | GPIO_InitStructure.GPIO_Pin = SPI_MASTER_PIN_NSS | SPI_MASTER_PIN_SCK | SPI_MASTER_PIN_MOSI;
213 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
214 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
215 | GPIO_Init(SPI_MASTER_GPIO, &GPIO_InitStructure);
216 | #endif
217 |
218 | /* Configure SPI_SLAVE pins: NSS, SCK and MISO*/
219 | GPIO_InitStructure.GPIO_Pin = SPI_SLAVE_PIN_NSS | SPI_SLAVE_PIN_SCK;
220 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
221 | GPIO_Init(SPI_SLAVE_GPIO, &GPIO_InitStructure);
222 |
223 | GPIO_InitStructure.GPIO_Pin = SPI_SLAVE_PIN_MISO;
224 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
225 | GPIO_Init(SPI_SLAVE_GPIO, &GPIO_InitStructure);
226 |
227 | }
228 |
229 | /**
230 | * @brief Compares two buffers.
231 | * @param pBuffer1, pBuffer2: buffers to be compared.
232 | * @param BufferLength: buffer's length
233 | * @retval PASSED: pBuffer1 identical to pBuffer2
234 | * FAILED: pBuffer1 differs from pBuffer2
235 | */
236 | TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength)
237 | {
238 | while (BufferLength--)
239 | {
240 | if (*pBuffer1 != *pBuffer2)
241 | {
242 | return FAILED;
243 | }
244 |
245 | pBuffer1++;
246 | pBuffer2++;
247 | }
248 |
249 | return PASSED;
250 | }
251 |
252 | #ifdef USE_FULL_ASSERT
253 |
254 | /**
255 | * @brief Reports the name of the source file and the source line number
256 | * where the assert_param error has occurred.
257 | * @param file: pointer to the source file name
258 | * @param line: assert_param error line source number
259 | * @retval None
260 | */
261 | void assert_failed(uint8_t* file, uint32_t line)
262 | {
263 | /* User can add his own implementation to report the file name and line number,
264 | ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
265 |
266 | /* Infinite loop */
267 | while (1)
268 | {}
269 | }
270 |
271 | #endif
272 |
273 | /**
274 | * @}
275 | */
276 |
277 | /**
278 | * @}
279 | */
280 |
281 | /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
