1 | $regfile = "m128def.dat"
2 | $crystal = 10000000
3 | $hwstack = 40
4 | $swstack = 16
5 | $framesize = 32
6 | $baud = 9600
7 |
8 |
9 | Dim Kalman_dt As Single
10 | Dim Kalman_gyro_sensor As Single
11 | Dim Kalman_adxl_sensor As Single
12 | Dim Neigungswinkel As Single
13 | Dim Buf_ad_gyro As Integer
14 | Dim Buf_ad_adxl As Integer
15 | Dim Ad_gyro As Integer
16 | Dim Ad_adxl As Integer
17 | Dim Gyro_zero As Integer
18 | Dim Adxl_zero As Integer
19 |
20 | Dim Gyro1dkalman_x_angle As Single
21 | Dim Gyro1dkalman_x_bias As Single
22 | Dim Gyro1dkalman_p_00 As Single
23 | Dim Gyro1dkalman_p_01 As Single
24 | Dim Gyro1dkalman_p_10 As Single
25 | Dim Gyro1dkalman_p_11 As Single
26 | Dim Gyro1dkalman_q_angle As Single
27 | Dim Gyro1dkalman_q_gyro As Single
28 | Dim Gyro1dkalman_r_angle As Single
29 |
30 | Dim Wert As Single
31 |
32 | Dim Y As Single
33 | Dim S As Single
34 | Dim K_0 As Single
35 | Dim K_1 As Single
36 |
37 | Dim Temp As Single
38 | Dim Temp1 As Single
39 | Dim Ausgabe As String * 4
40 |
41 |
42 | Declare Sub Init_gyro1dkalman(byval Q_angle As Single , Byval Q_gyro As Single , Byval R_angle As Single)
43 | Declare Sub Ars_predict(byval Dotangle As Single , Byval Dt As Single)
44 | Declare Function Ars_update(byval Angle_m As Single) As Single
45 | Declare Function Kalman_filter_auswertung(gyro As Single , Adxl As Single , Dt As Single) As Single
46 |
47 |
48 | Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portc.1 , Rs = Portc.0
49 | Config Lcd = 16 * 2
50 | Cls
51 |
52 |
53 | Config Adc = Single , Prescaler = 128 , Reference = Off
54 | Start Adc
55 |
56 |
57 | 'Init
58 | Call Init_gyro1dkalman(0.0001 , 0.0003 , 0.3) 'Kalman Filter
59 | Kalman_dt = 0.0157 'time passed in s since last call
60 |
61 | Gyro_zero = Getadc(5)
62 | Adxl_zero = Getadc(2)
63 |
64 |
65 | Do 'Endlosschleife
66 |
67 | Ad_gyro = Getadc(5)
68 | Ad_adxl = Getadc(2)
69 |
70 | Buf_ad_gyro = Ad_gyro - Gyro_zero
71 | Buf_ad_adxl = Ad_adxl - Adxl_zero
72 |
73 | Kalman_gyro_sensor = Buf_ad_gyro * 1.4634135 ' /1025*3.0V/0.002
74 | Kalman_adxl_sensor = Buf_ad_adxl * 1.5139 ' /1025*3.0V/0.0019333 0,348V for 180° = 1,9333mV per °
75 |
76 | Neigungswinkel = Kalman_filter_auswertung(kalman_gyro_sensor , Kalman_adxl_sensor , Kalman_dt)
77 | Ausgabe = Fusing(neigungswinkel , "##.###")
78 |
79 | Cls
80 | Lcd Ausgabe
81 | Waitms 150
82 |
83 | Loop
84 |
85 | End
86 |
87 |
88 |
89 | '#############################################################################
90 |
91 | '######################## Kalman Filter - Datei ##############################
92 |
93 | 'struct Gyro1DKalman
94 |
95 | '* These variables represent our state matrix x
96 |
97 |
98 | 'End Structure
99 |
100 | '#######################################################################
101 |
102 | '***********************************************************************
103 | '* *
104 | '* This file contains the code for the kalman filter that uses the *
105 | '* sensor data as inputs. *
106 | '* *
107 | '***********************************************************************
108 | '* *
109 | '* Author: Tom Pycke *
110 | '* Filename: ars.c *
111 | '* Date: 17/10/2007 *
112 | '* File Version: 1.00 *
113 | '* *
114 | '***********************************************************************
115 | '* *
116 | '* Comments: *
117 | '* To help others to understand the kalman filter, I used one of *
118 | '* the most accessible sources with information on it: *
119 | '* http://en.wikipedia.org/wiki/Kalman_filter *
120 | '* The code is split into 2 parts: a Predict function and an *
121 | '* Update function, just as the wikipedia page does. *
122 | '* The model I used in the kalman filter is the following: *
123 | '* Our gyroscope measures the turnrate in degrees per second. This *
124 | '* is the derivative of the angle, called dotAngle. The bias is the *
125 | '* output of our gyro when the rotationrate is 0 degrees per second *
126 | '* (not rotating). Because of drift it changes over time. *
127 | '* So mathematically we just integrate the gyro (dt is timespan *
128 | '* since last integration): *
129 | '* angle = angle + (dotAngle - bias) * dt *
130 | '* When we include the bias in our model, the kalman filter will *
131 | '* try to estimate the bias, thanks to our last input: the measured *
132 | '* angle. This is just an estimate and comes from the accelerometer. *
133 | '* So the state used in our filter had 2 dimensions: [ angle, bias ] *
134 | '* Jump to the functions to read more about the actual *
135 | '* implementation. *
136 | '* *
137 | '***********************************************************************
138 |
139 | Sub Init_gyro1dkalman(byval Q_angle As Single , Byval Q_gyro As Single , Byval R_angle As Single)
140 | Gyro1dkalman_q_angle = Q_angle
141 | Gyro1dkalman_q_gyro = Q_gyro
142 | Gyro1dkalman_r_angle = R_angle
143 | End Sub
144 |
145 |
146 | Sub Ars_predict(byval Dotangle As Single , Byval Dt As Single)
147 |
148 | 'Gyro1dkalman_x_angle = Gyro1dkalman_x_angle +(dt *(dotangle - Gyro1dkalman_x_bias))
149 | Temp = Dotangle - Gyro1dkalman_x_bias
150 | Temp = Temp * Dt
151 | Gyro1dkalman_x_angle = Gyro1dkalman_x_angle + Temp
152 |
153 |
154 | 'Gyro1dkalman_p_00 = Gyro1dkalman_p_00 +( -dt *(gyro1dkalman_p_10 + Gyro1dkalman_p_01) + Gyro1dkalman_q_angle * Dt)
155 | Temp = -dt
156 | Temp1 = Gyro1dkalman_p_10 + Gyro1dkalman_p_01
157 | Temp = Temp * Temp1
158 | Temp1 = Gyro1dkalman_q_angle * Dt
159 | Temp = Temp + Temp1
160 | Gyro1dkalman_p_00 = Gyro1dkalman_p_00 + Temp
161 |
162 |
163 | 'Gyro1dkalman_p_01 = Gyro1dkalman_p_01 +( -dt * Gyro1dkalman_p_11)
164 | Temp = -dt
165 | Temp = Temp * Gyro1dkalman_p_11
166 | Gyro1dkalman_p_01 = Gyro1dkalman_p_01 + Temp
167 |
168 |
169 | 'Gyro1dkalman_p_10 = Gyro1dkalman_p_10 +( -dt * Gyro1dkalman_p_11)
170 | Temp = -dt
171 | Temp = Temp * Gyro1dkalman_p_11
172 | Gyro1dkalman_p_10 = Gyro1dkalman_p_10 + Temp
173 |
174 |
175 |
176 | 'Gyro1dkalman_p_11 = Gyro1dkalman_p_11 +( + Gyro1dkalman_q_gyro * Dt)
177 | Temp = Gyro1dkalman_q_gyro * Dt
178 | Gyro1dkalman_p_11 = Gyro1dkalman_p_11 + Temp
179 |
180 |
181 |
182 | End Sub
183 |
184 |
185 | Function Ars_update(byval Angle_m As Single) As Single
186 |
187 | Y = Angle_m - Gyro1dkalman_x_angle
188 | S = Gyro1dkalman_p_00 + Gyro1dkalman_r_angle
189 | K_0 = Gyro1dkalman_p_00 / S
190 | K_1 = Gyro1dkalman_p_10 / S
191 |
192 | 'Gyro1dkalman_x_angle = Gyro1dkalman_x_angle +(k_0 * Y)
193 | Temp = K_0 * Y
194 | Gyro1dkalman_x_angle = Gyro1dkalman_x_angle + Temp
195 |
196 | 'Gyro1dkalman_x_bias = Gyro1dkalman_x_bias +(k_1 * Y)
197 | Temp = K_1 * Y
198 | Gyro1dkalman_x_bias = Gyro1dkalman_x_bias + Temp
199 |
200 | 'Gyro1dkalman_p_00 = Gyro1dkalman_p_00 -(k_0 * Gyro1dkalman_p_00)
201 | Temp = K_0 * Gyro1dkalman_p_00
202 | Gyro1dkalman_p_00 = Gyro1dkalman_p_00 - Temp
203 |
204 |
205 | 'Gyro1dkalman_p_01 = Gyro1dkalman_p_01 -(k_0 * Gyro1dkalman_p_01)
206 | Temp = K_0 * Gyro1dkalman_p_01
207 | Gyro1dkalman_p_01 = Gyro1dkalman_p_01 - Temp
208 |
209 | 'Gyro1dkalman_p_10 = Gyro1dkalman_p_10 -(k_1 * Gyro1dkalman_p_00)
210 | Temp = K_1 * Gyro1dkalman_p_00
211 | Gyro1dkalman_p_10 = Gyro1dkalman_p_10 - Temp
212 |
213 | 'Gyro1dkalman_p_11 = Gyro1dkalman_p_11 -(k_1 * Gyro1dkalman_p_01)
214 | Temp = K_1 * Gyro1dkalman_p_01
215 | Gyro1dkalman_p_11 = Gyro1dkalman_p_11 - Temp
216 |
217 | Return Gyro1dkalman_x_angle 'was mache ich hiermit???
218 |
219 | End Function
220 |
221 | Function Kalman_filter_auswertung(gyro As Single , Adxl As Single , Dt As Single) As Single
222 | '----------------Kalman Filter----------------------------------
223 | 'ars_predict(Kalman_gyro_sensor, Kalman_dt) 'Kalman predict
224 | 'Neigungswinkel_Filter = ars_update(Kalman_adxl_sensor)
225 | '---------------------------------------------------------------
226 |
227 | Call Ars_predict(gyro , Dt) 'Kalman predict
228 | Wert = Ars_update(adxl)
229 |
230 | Return Wert 'und damit???
231 | End Function
