1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.Numeric_std.ALL;
4 |
5 | entity Sinc_filt is
6 | generic (
7 | DECIMATOR_M_BIT_SIZE : natural := 8); -- M = 2^DECIMATOR_M_BIT_SIZE
8 | Port ( Mclk : in STD_LOGIC;
9 | Mdata : in STD_LOGIC;
10 | rst : in STD_LOGIC;
11 | DataRate_clk : out STD_LOGIC; -- in fifo abspeichern
12 | DataOut : out STD_LOGIC_VECTOR (15 downto 0));
13 | end Sinc_filt;
14 |
15 | architecture Behavioral of Sinc_filt is
16 |
17 | constant DATA_BIT_SIZE : natural := 3*DECIMATOR_M_BIT_SIZE + 1; -- intern DatenBus Sinc3
18 |
19 | ----------------------------------------------------------------------------------
20 | -- signal
21 | ----------------------------------------------------------------------------------
22 |
23 | -- integrator @ Mclk
24 | signal acc1 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
25 | signal acc2 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
26 | signal acc3 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
27 |
28 | -- diffirentiator @ Mclk/DECIMATOR_M
29 | signal diff_clk : std_logic := '0';
30 |
31 | signal diff1 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
32 | signal diff2 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
33 | signal diff3 : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
34 | signal acc3_d : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
35 | signal diff1_d : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
36 | signal diff2_d : signed (DATA_BIT_SIZE - 1 downto 0) := (others => '0');
37 |
38 | -- clk divider ->> Mclk/DECIMATOR_M
39 | signal clk_div_cnt : std_logic_vector(DECIMATOR_M_BIT_SIZE-1 downto 0) := (others => '0');
40 |
41 | begin
42 |
43 | ----------------------------------------------------------------------------------
44 | -- Integrator @ Mclk
45 | ----------------------------------------------------------------------------------
46 | Integ_pro: process
47 | begin
48 | wait until rising_edge(Mclk); -- falling Mclk ->> data valid
49 |
50 | if rst = '1' then
51 | acc1 <= (others => '0');
52 | acc2 <= (others => '0');
53 | acc3 <= (others => '0');
54 | else
55 | if Mdata = '1' then
56 | acc1 <= acc1 + x"1";
57 | end if;
58 | acc2 <= acc2 + acc1;
59 | acc3 <= acc3 + acc2;
60 | end if;
61 | end process Integ_pro;
62 |
63 | ----------------------------------------------------------------------------------
64 | -- clk divider @ Mclk --> Mclk/DECIMATOR_M
65 | ----------------------------------------------------------------------------------
66 | clk_div_pro: process
67 | begin
68 | wait until rising_edge(Mclk);
69 | if rst = '1' then
70 | clk_div_cnt <= (others => '0');
71 | else
72 | clk_div_cnt <= std_logic_vector(unsigned(clk_div_cnt) + x"1");
73 | end if;
74 | end process clk_div_pro;
75 |
76 | -- wired
77 | diff_clk <= clk_div_cnt(DECIMATOR_M_BIT_SIZE-1); -- MSB
78 | DataRate_clk <= diff_clk;
79 |
80 | ----------------------------------------------------------------------------------
81 | -- differenciator @ falling diff_clk
82 | ----------------------------------------------------------------------------------
83 | Diff_pro: process
84 | begin
85 | wait until falling_edge(diff_clk); -- Falling Edge!
86 |
87 | if rst = '1' then
88 | diff1 <= (others => '0');
89 | diff2 <= (others => '0');
90 | diff3 <= (others => '0');
91 | acc3_d <= (others => '0');
92 | diff1_d <= (others => '0');
93 | diff2_d <= (others => '0');
94 | else
95 | diff1 <= acc3 - acc3_d;
96 | diff2 <= diff1 - diff1_d;
97 | diff3 <= diff2 - diff2_d;
98 |
99 | acc3_d <= acc3;
100 | diff1_d <= diff1;
101 | diff2_d <= diff2;
102 | end if;
103 | end process Diff_pro;
104 |
105 |
106 | ----------------------------------------------------------------------------------
107 | -- 16- bit DataOutput
108 | ----------------------------------------------------------------------------------
109 |
110 | DataOut <= std_logic_vector(diff3(DATA_BIT_SIZE-1 downto DATA_BIT_SIZE-16)); -- 16-Bit DataOut
111 |
112 | end Behavioral;
