1 | Arduino: 1.8.9 (Windows 7), Board: "ATmega4809, 48 pin standard, Reset, BOD
2 | 2.6V, Internal 16 MHz, Optiboot (UART3 default pins)"
3 |
4 | avrdude: Version 6.3-20171130
5 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
6 | Copyright (c) 2007-2014 Joerg Wunsch
7 |
8 | System wide configuration file is "C:\Program Files (x86)\Arduino
9 | \hardware\MegaCoreX-master\megaavr/avrdude.conf"
10 |
11 | Using Port : COM4
12 | Using Programmer : jtag2updi
13 | JTAG ICE mkII sign-on message:
14 | Communications protocol version: 1
15 | M_MCU:
16 | boot-loader FW version: 1
17 | firmware version: 6.00
18 | hardware version: 1
19 | S_MCU:
20 | boot-loader FW version: 1
21 | firmware version: 6.00
22 | hardware version: 1
23 | Serial number: 00:00:00:00:00:00
24 | Device ID: JTAGICE mkII
25 | AVR Part : ATmega4809
26 | Chip Erase delay : 0 us
27 | PAGEL : P00
28 | BS2 : P00
29 | RESET disposition : dedicated
30 | RETRY pulse : SCK
31 | serial program mode : yes
32 | parallel program mode : yes
33 | Timeout : 0
34 | StabDelay : 0
35 | CmdexeDelay : 0
36 | SyncLoops : 0
37 | ByteDelay : 0
38 | PollIndex : 0
39 | PollValue : 0x00
40 | Memory Detail :
41 |
42 | Block Poll Page
43 | Polled
44 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW
45 | MaxW ReadBack
46 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ -----
47 | ----- ---------
48 | signature 0 0 0 0 no 3 0 0 0
49 | 0 0x00 0x00
50 | prodsig 0 0 0 0 no 61 61 0 0
51 | 0 0x00 0x00
52 | fuses 0 0 0 0 no 9 0 0 0
53 | 0 0x00 0x00
54 | fuse0 0 0 0 0 no 1 0 0 0
55 | 0 0x00 0x00
56 | fuse1 0 0 0 0 no 1 0 0 0
57 | 0 0x00 0x00
58 | fuse2 0 0 0 0 no 1 0 0 0
59 | 0 0x00 0x00
60 | fuse4 0 0 0 0 no 1 0 0 0
61 | 0 0x00 0x00
62 | fuse5 0 0 0 0 no 1 0 0 0
63 | 0 0x00 0x00
64 | fuse6 0 0 0 0 no 1 0 0 0
65 | 0 0x00 0x00
66 | fuse7 0 0 0 0 no 1 0 0 0
67 | 0 0x00 0x00
68 | fuse8 0 0 0 0 no 1 0 0 0
69 | 0 0x00 0x00
70 | lock 0 0 0 0 no 1 0 0 0
71 | 0 0x00 0x00
72 | data 0 0 0 0 no 0 0 0 0
73 | 0 0x00 0x00
74 | usersig 0 0 0 0 no 64 64 0 0
75 | 0 0x00 0x00
76 | flash 0 0 0 0 no 49152 128 0 0
77 | 0 0x00 0x00
78 | eeprom 0 0 0 0 no 256 64 0 0
79 | 0 0x00 0x00
80 |
81 | Programmer Type : JTAGMKII_PDI
82 | Description : JTAGv2 to UPDI bridge
83 | M_MCU hardware version: 1
84 | M_MCU firmware version: 6.00
85 | S_MCU hardware version: 1
86 | S_MCU firmware version: 6.00
87 | Serial number: 00:00:00:00:00:00
88 | Fehler beim Brennen des Bootloaders.
89 | Vtarget : 5.0 V
90 |
91 | avrdude: jtagmkII_initialize(): part ATmega4809 has no PDI interface
92 | avrdude: initialization failed, rc=-1
93 | Double check connections and try again, or use -F to override
94 | this check.
95 |
96 | avrdude: jtagmkII_close(): bad response to sign-off command:
97 | RSP_ILLEGAL_MCU_STATE
98 |
99 | avrdude done. Thank you.
