Forum: Mikrocontroller und Digitale Elektronik ATMEGA4809 Curiosity Board - Serial in/out?
von Anselm 6. (anselm68)
Hallo Ihr,
ich scheitere kläglich daran die serielle Schnittstelle zu verwenden.
Verwendet habe ich den Beispielcode von Microchip, angepasst auf das
Curiosity Board. Hier liegt der CDC-Port auf USART3 PB0/PB1(laut
Dokumentation)
#define F_CPU 3333333UL
#define USART3_BAUD_RATE(BAUD_RATE) ((float)(F_CPU * 64 / (16 * (float)BAUD_RATE)) + 0.5)
#define MAX_COMMAND_LEN    8
#define INIT_DELAY      10  /* Delay to invalidate the after-reset noise on the PC0 pin (TX) */
#include <avr/io.h>
#include <stdio.h>
#include <string.h>
#include <util/delay.h>
void USART3_init(void);
void USART3_sendChar(char c);
void USART3_sendString(char *str);
char USART3_readChar(void);
void LED_on(void);
void LED_off(void);
void LED_init(void);
void executeCommand(char *command);
    USART3.BAUD = (uint16_t)USART3_BAUD_RATE(9600);
23
24
    USART3.CTRLB |= USART_RXEN_bm | USART_TXEN_bm;
25
26
  PORTB.DIR |= PIN0_bm;
27
  PORTB.DIR &= ~PIN1_bm;
28
29
30
31
32
    while (!(USART3.STATUS & USART_DREIF_bm))
33
34
35
36
    USART3.TXDATAL = c;
37
38
39
40
41
    for(size_t i = 0; i < strlen(str); i++)
42
43
        USART3_sendChar(str[i]);
44
45
46
47
48
49
    while (!(USART3.STATUS & USART_RXCIF_bm))
50
51
52
53
    return USART3.RXDATAL;
54
55
56
void LED_on(void)
57
58
    PORTF.OUT &= ~PIN5_bm;
59
60
61
void LED_off(void)
62
63
    PORTF.OUT |= PIN5_bm;
64
65
66
void LED_init(void)
67
68
    PORTF.DIR |= PIN5_bm;
69
  LED_off();
70
71
72
73
74
    if(strcmp(command, "ON") == 0)
75
76
        LED_on();
77
        USART3_sendString("OK, LED ON.\r\n");
78
79
    else if (strcmp(command, "OFF") == 0)
80
81
        LED_off();
82
        USART3_sendString("OK, LED OFF.\r\n");
83
84
    else
85
86
        USART3_sendString("Type ON/OFF to control the LED.\r\n");
87
88
89
90
int main(void)
91
92
    PORTF_DIR  &= ~PIN6_bm;
93
94
    char command[MAX_COMMAND_LEN];
95
    uint8_t index = 0;
96
    char c;
97
98
  /* This delay invalidates the initial noise on the TX line, after device reset. */
99
    _delay_ms(10);
100
101
    USART3_init();
102
    LED_init();
103
  LED_on();
104
105
    _delay_ms(1000);
106
    LED_off();
107
    _delay_ms(1000);
108
    while (1)
109
110
        if(!(PORTF.IN & PIN6_bm)){
111
            LED_on();
112
            _delay_ms(1000);
113
            LED_off();
114
115
        LED_on();
116
        _delay_ms(100);
117
        LED_off();
118
        _delay_ms(250);
119
/*        c = USART3_readChar();
120
        if(c != '\n' && c != '\r')
121
122
            command[index++] = c;
123
            if(index > MAX_COMMAND_LEN)
124
125
                index = 0;
126
127
128
129
        if(c == '\r')
130
131
            command[index] = '\0';
132
            index = 0;
133
            executeCommand(command);
134
135
136
137
Das lesen von Serialport blockiert weil er da pollt (auskommentiert).
Zum Testen habe ich die Ledsteuerung etwas geändert -> funktioniert ->
F_CPU ist auch richtig eingestellt.
Auf dem COM3 (am PC) kommt jedoch nichts an was ich sende.
Das Boad hat die Softwareversion:
Currently loaded versions:
Application version...........1.21.37 (0x01.0x15.0x25)
Tool pack version .............1.6.222
Was habe ich übersehen?
Anselm
von Volker B. (Firma: L-E-A) (vobs)
Wie sind denn COM3 und das Board verbunden?
Grüßle
Volker
von Gener Vter (Gast)
Bitte unbedingt den Source Code in einen Anhang stecken, die
Darstellung des programmtextes im laufenden Beitragstext ist
sehr störend und verhindert auch die Hilfsbereitschaft.
Zumal zur Zeit die Foren-Software eine anständige Darstellung
massiv behindert statt sie zu unterstützen.
Com3 geht via Debugschnittstelle als virtual comport raus.
Bei älteren Firmwareversionen gab es wohl schonmal Probleme mit diesem
ComPort.
Ich habe die derzeit aktuelleste aufgespielt (geschieht automatisch wenn
man MPX-Lab gestartet und das Board via USB angeschlossen hat).
Für die genervten hier der Code im Anhang. Ist auch besser lesbar, da
stimme ich zu.
Anselm
Nun ist das Board verstorben.
Ich hatte mit dem Oszilloskop PF5(LED-Ausgang) sowie den TX Port von
serial3 geprüft.
Am LED-Port waren eindeutige Pegel zu sehen.
Am Tx eher ein wenig Rauschen wie bei einem offenem Eingang des Oszis.
Mit angeschlossenem Oszi wollte ich eine neue Testsoftware aufspielen,
seit dem ist das Board TOT. Einen Kurzschluss im Messaufbau kann ich
sicher ausschliessen.
So muss ich warten bis ich die DIL-Version fürs Steckbrett habe.
Aber Danke fürs lesen :)
Ein schönes Wochenende Euch allen.
Anselm
von BlaBla (Gast)
Die scheinen ein wenig sensibel zu sein. Vielleicht weil jetzt Microchip
das Sagen hat und nicht mehr Atmel.  ;-)
Beitrag "zweites ATmega4809 Curiosity Nano Board tot"
von Veit D. (devil-elec)
wollte ich auch soeben verlinken.  :-)
Anselm, miss mal vor und nach der Sicherung ob Ub vorhanden ist. Wenn du
Glück hast ist auch nur die Sicherung durch.
