1 | /*
2 | Victron1 MPPT 12 V
3 | Victron2 MPPT 24 V
4 | Victron3 BMV 24 V
5 |
6 | D5ED V_MPPT un16 0.01 V
7 | D7ED I_MPPT un16 0.1 A
8 | BBED VPV_MPPT un16 0.01 V
9 | BCED PPV_MPPT un32 0.01 W
10 | 0102 CS_MPPT un8
11 | D3ED H20_MPPT un16 0.01 KWH
12 |
13 | 8DED V_BMV un16 0.01 V
14 | 8CED I_BMV un32 0.001 A
15 | 8EED P_BMV un16 1 W
16 | 1003 H17_BMV un32 0.01 KWH
17 | 1103 H18_BMV un32 0.01 KWH
18 | 0603 H7_BMV un32 0.01 V
19 | 0703 H8_BMV un32 0.01 V
20 | FF0F SOC_BMV un16 0.01 %
21 |
22 | Checksum:
23 | :70010003E<LF> -> Command; checksum 0x55 – 0x7 – 0x0 – 0x10 – 0x0 = 0x3E
24 | :7001000C80076<LF> -> Response; checksum 0x55 – 0x7 – 0x0 – 0x10 – 0x0 – 0xC8 – 0x0 = 0x76
25 | */
26 |
27 | #include <Wire.h>
28 | #include <stdio.h>
29 | #include <stdlib.h>
30 |
31 | #include <LiquidCrystal_I2C.h>
32 | LiquidCrystal_I2C lcd(0x27, 20, 4);
33 |
34 | #include <Adafruit_Sensor.h>
35 | #include <Adafruit_BME280.h>
36 | Adafruit_BME280 bme;
37 |
38 | #include <RunningMedian.h>
39 | RunningMedian samples1 = RunningMedian(11);
40 | RunningMedian samples2 = RunningMedian(11);
41 |
42 | int interruptPin = 3;
43 | int counter;
44 | int Status;
45 |
46 | #include <SoftwareSerial.h>
47 | SoftwareSerial Serial_SIM900(52, 53); // RX, TX
48 |
49 | const int vicbuf = 25;
50 | const int sim900buf = 180;
51 | char vic1_ser[vicbuf];
52 | char vic2_ser[vicbuf];
53 | char vic3_ser[vicbuf];
54 | char sim900_ser[sim900buf];
55 |
56 | float vic1_v_mppt;
57 | float vic1_i_mppt;
58 | float vic1_vpv_mppt;
59 | long vic1_ppv_mppt;
60 | long vic1_cs_mppt;
61 | long vic1_h20_mppt;
62 |
63 | float vic2_v_mppt;
64 | float vic2_i_mppt;
65 | float vic2_vpv_mppt;
66 | long vic2_ppv_mppt;
67 | long vic2_cs_mppt;
68 | long vic2_h20_mppt;
69 | long vic2_v_mppt_r;
70 |
71 | float vic3_v_bmv;
72 | float vic3_i_bmv;
73 | long vic3_p_bmv;
74 | float vic3_h17_bmv;
75 | float vic3_h18_bmv;
76 | float vic3_h7_bmv;
77 | float vic3_h8_bmv;
78 | float vic3_soc_bmv;
79 |
80 | long ergebniss;
81 |
82 | float temperatur;
83 | float luftfeuchtigkeit;
84 | float luftdruck;
85 |
86 | int ina226_addr = 0x40;
87 | int shunt;
88 | int shunt_logger;
89 | int p_map;
90 | int p_ueber;
91 | volatile int regel;
92 | int schalter;
93 | int error;
94 | int error_counter;
95 |
96 | int zaehler;
97 | int messung_1;
98 | int messung_2;
99 | int mess;
100 |
101 | int status_absorption;
102 | int status_float;
103 | int up_down;
104 |
105 | int ledPin = LED_BUILTIN;
106 | int sim900_pin = 9;
107 |
108 | int K1 = 59;
109 | int K2 = 58;
110 | int K3 = 57;
111 | int K4 = 56;
112 |
113 | byte status_K1 = HIGH;
114 | byte status_K2 = HIGH;
115 | byte status_K3 = HIGH;
116 | byte status_K4 = HIGH;
117 |
118 | int p_K1 = 5; //<<<<----p AN K1 FESTLEGEN
119 | int p_K2 = 10; //<<<<----p AN K2 FESTLEGEN
120 | int p_K3 = 15; //<<<<----p AN K3 FESTLEGEN
121 | int p_K4 = 20; //<<<<----p AN K4 FESTLEGEN
122 |
123 | byte lcd_char_up_down[8] = {B00100, B01110, B10101, B00100, B10101, B01110, B00100, B00000};
124 | byte lcd_char_up[8] = {B00100, B01110, B10101, B00100, B00100, B00100, B00100, B00000};
125 | byte lcd_char_down[8] = {B00100, B00100, B00100, B00100, B10101, B01110, B00100, B00000};
126 | //****************
127 | void setup()
128 | {
129 | Serial.begin (19200); //USB
130 | Serial1.begin(19200); //Victron1_MPPT 12 Volt
131 | Serial2.begin(19200); //Victron2_MPPT 24 Volt
132 | Serial3.begin(19200); //Victron3_BMV 24 Volt
133 | Serial_SIM900.begin(19200); //SIM900
134 |
135 | Wire.begin();
136 | Wire.setClock(400000L);
137 |
138 | //writeRegister(0x00, 0x4E35);
139 | writeRegister(0x00, 0x4E3D);
140 |
141 | lcd.init();
142 | lcd.backlight();
143 | lcd.clear();
144 | fest_display();
145 |
146 | bme.begin(0x76);
147 |
148 | pinMode(sim900_pin, OUTPUT);
149 | digitalWrite(sim900_pin, LOW);
150 | pinMode(ledPin, OUTPUT);
151 | digitalWrite(ledPin, LOW);
152 |
153 | pinMode(K1, OUTPUT);
154 | pinMode(K2, OUTPUT);
155 | pinMode(K3, OUTPUT);
156 | pinMode(K4, OUTPUT);
157 | relais();
158 |
159 | lcd.createChar(0, lcd_char_up_down);
160 | lcd.createChar(1, lcd_char_up);
161 | lcd.createChar(2, lcd_char_down);
162 |
163 | pinMode(interruptPin, INPUT);
164 | attachInterrupt(digitalPinToInterrupt(interruptPin), nulldurchgang, RISING);
165 | DDRA |= (1 << PA0);
166 | }
167 | //****************
168 | void loop()
169 | {
170 | //Serial.print("Ram frei: "); Serial.println(freeRam()); //4014
171 |
172 | vic1_serial();
173 | vic2_serial();
174 | vic3_serial();
175 | sim900_error();
176 |
177 | time1();
178 | time2();
179 | time3();
180 | time4();
181 | }
182 | //****************
183 | int freeRam()
184 | {
185 | extern int __heap_start, *__brkval;
186 | int v;
187 | return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
188 | }
189 | //****************
190 | void time1()
191 | {
192 | static unsigned long prev_millis;
193 | if (millis() - prev_millis > 500)
194 | {
195 | vic2_anfragen();
196 | vic2_display();
197 | ina_226();
198 | ueberschuss();
199 | ueberschuss_display();
200 | prev_millis = millis();
201 | }
202 | }
203 | void time2()
204 | {
205 | static unsigned long prev_millis;
206 | if (millis() - prev_millis > 750)
207 | {
208 | vic1_anfragen();
209 | vic1_display();
210 | vic3_anfragen();
211 | vic3_display();
212 | prev_millis = millis();
213 | }
214 | }
215 | void time3()
216 | {
217 | static unsigned long prev_millis;
218 | if (millis() - prev_millis > 1000)
219 | {
220 | thingspeak();
221 | bme280();
222 | bme280_display();
223 | prev_millis = millis();
224 | }
225 | }
226 | void time4()
227 | {
228 | static unsigned long prev_millis;
229 | if (millis() - prev_millis > 300000)
230 | {
231 | lcd.clear();
232 | fest_display();
233 | prev_millis = millis();
234 | }
235 | }
236 | //****************
237 | void vic1_anfragen()
238 | {
239 | Serial1.println(F(":7D3ED008E"));
240 | }
241 | //****************
242 | void vic2_anfragen()
243 | {
244 | Serial2.println(F(":7D3ED008E"));
245 | }
246 | //****************
247 | void vic3_anfragen()
248 | {
249 | Serial3.println(F(":78DED00D4"));
250 | Serial3.println(F(":78CED00D5"));
251 | Serial3.println(F(":78EED00D3"));
252 | Serial3.println(F(":71003003B"));
253 | Serial3.println(F(":71103003A"));
254 | Serial3.println(F(":706030045"));
255 | Serial3.println(F(":707030044"));
256 | Serial3.println(F(":7FF0F0040"));
257 | }
258 | //****************
259 | void vic1_serial()
260 | {
261 | static byte index;
262 | while (Serial1.available())
263 | {
264 | char c = Serial1.read();
265 | if (c == '\n' && index > 0)
266 | {
267 | vic1_ser[index] = '\0';
268 | index = 0;
269 | if (((strncmp(vic1_ser, ":7", 2) == 0) || (strncmp(vic1_ser, ":A", 2) == 0)) && (strncmp(vic1_ser, "Checksum", 8) != 0))
270 | {
271 | vic1_auswerten();
272 | }
273 | }
274 | else if (index < vicbuf - 1)
275 | {
276 | vic1_ser[index++] = c;
277 | }
278 | }
279 | }
280 | //****************
281 | void vic2_serial()
282 | {
283 | static byte index;
284 | while (Serial2.available())
285 | {
286 | char c = Serial2.read();
287 | if (c == '\n' && index > 0)
288 | {
289 | vic2_ser[index] = '\0';
290 | index = 0;
291 | //Serial.println(vic2_ser);
292 | if (((strncmp(vic2_ser, ":7", 2) == 0) || (strncmp(vic2_ser, ":A", 2) == 0)) && (strncmp(vic2_ser, "Checksum", 8) != 0))
293 | {
294 | vic2_auswerten();
295 | }
296 | }
297 | else if (index < vicbuf - 1)
298 | {
299 | vic2_ser[index++] = c;
300 | }
301 | }
302 | }
303 | //****************
304 | void vic3_serial()
305 | {
306 | static byte index;
307 | while (Serial3.available())
308 | {
309 | char c = Serial3.read();
310 | if (c == '\n' && index > 0)
311 | {
312 | vic3_ser[index] = '\0';
313 | index = 0;
314 | vic3_auswerten();
315 | }
316 | else if (index < vicbuf - 1)
317 | {
318 | vic3_ser[index++] = c;
319 | }
320 | }
321 | }
322 | //********************
323 | void sim900_error()
324 | {
325 | static byte index;
326 | while (Serial_SIM900.available())
327 | {
328 | char c = Serial_SIM900.read();
329 | if (c == '\r' && index > 0)
330 | {
331 | sim900_ser[index] = '\0';
332 | index = 0;
333 | if (strncmp(sim900_ser, "\nERROR", 6) == 0)
334 | {
335 | error++;
336 | error_counter++;
337 | }
338 | }
339 | else if (index < sim900buf - 1)
340 | {
341 | sim900_ser[index++] = c;
342 | }
343 | }
344 | }
345 | //********************
346 | void vic1_auswerten()
347 | {
348 | if (strncmp(vic1_ser, ":AD5ED00", 8) == 0)
349 | {
350 | char str[5] = "";
351 | char sub3[3] = "";
352 | strncpy(sub3, &vic1_ser[12], 2);
353 | sub3[2] = '\0';
354 | hextodec(sub3);
355 | int checksum = ergebniss;
356 | char sub2[3] = "";
357 | strncpy(sub2, &vic1_ser[10], 2);
358 | sub2[2] = '\0';
359 | hextodec(sub2);
360 | int b = ergebniss;
361 | strcpy (str, sub2);
362 | char sub1[3] = "";
363 | strncpy(sub1, &vic1_ser[8], 2);
364 | sub1[2] = '\0';
365 | hextodec(sub1);
366 | int a = ergebniss;
367 | strcat (str, sub1);
368 | byte xxx = -375 - a - b;
369 | if (xxx == checksum)
370 | {
371 | hextodec(str);
372 | vic1_v_mppt = ergebniss / 100.0;
373 | }
374 | return;
375 | }
376 | if (strncmp(vic1_ser, ":AD7ED00", 8) == 0)
377 | {
378 | char str[5] = "";
379 | char sub3[3] = "";
380 | strncpy(sub3, &vic1_ser[12], 2);
381 | sub3[2] = '\0';
382 | hextodec(sub3);
383 | int checksum = ergebniss;
384 | char sub2[3] = "";
385 | strncpy(sub2, &vic1_ser[10], 2);
386 | sub2[2] = '\0';
387 | hextodec(sub2);
388 | int b = ergebniss;
389 | strcpy (str, sub2);
390 | char sub1[3] = "";
391 | strncpy(sub1, &vic1_ser[8], 2);
392 | sub1[2] = '\0';
393 | hextodec(sub1);
394 | int a = ergebniss;
395 | strcat (str, sub1);
396 | byte xxx = -377 - a - b;
397 | if (xxx == checksum)
398 | {
399 | hextodec(str);
400 | vic1_i_mppt = ergebniss / 10.0;
401 | }
402 | return;
403 | }
404 | if (strncmp(vic1_ser, ":ABBED00", 8) == 0)
405 | {
406 | char str[5] = "";
407 | char sub3[3] = "";
408 | strncpy(sub3, &vic1_ser[12], 2);
409 | sub3[2] = '\0';
410 | hextodec(sub3);
411 | int checksum = ergebniss;
412 | char sub2[3] = "";
413 | strncpy(sub2, &vic1_ser[10], 2);
414 | sub2[2] = '\0';
415 | hextodec(sub2);
416 | int b = ergebniss;
417 | strcpy (str, sub2);
418 | char sub1[3] = "";
419 | strncpy(sub1, &vic1_ser[8], 2);
420 | sub1[2] = '\0';
421 | hextodec(sub1);
422 | int a = ergebniss;
423 | strcat (str, sub1);
424 | byte xxx = -349 - a - b;
425 | if (xxx == checksum)
426 | {
427 | hextodec(str);
428 | vic1_vpv_mppt = ergebniss / 100.0;
429 | }
430 | return;
431 | }
432 | if (strncmp(vic1_ser, ":ABCED00", 8) == 0)
433 | {
434 | char str[9] = "";
435 | char sub5[3] = "";
436 | strncpy(sub5, &vic1_ser[16], 2);
437 | sub5[2] = '\0';
438 | hextodec(sub5);
439 | int checksum = ergebniss;
440 | char sub4[3] = "";
441 | strncpy(sub4, &vic1_ser[14], 2);
442 | sub4[2] = '\0';
443 | hextodec(sub4);
444 | int d = ergebniss;
445 | strcpy (str, sub4);
446 | char sub3[3] = "";
447 | strncpy(sub3, &vic1_ser[12], 2);
448 | sub3[2] = '\0';
449 | hextodec(sub3);
450 | int c = ergebniss;
451 | strcat (str, sub3);
452 | char sub2[3] = "";
453 | strncpy(sub2, &vic1_ser[10], 2);
454 | sub2[2] = '\0';
455 | hextodec(sub2);
456 | int b = ergebniss;
457 | strcat (str, sub2);
458 | char sub1[3] = "";
459 | strncpy(sub1, &vic1_ser[8], 2);
460 | sub1[2] = '\0';
461 | hextodec(sub1);
462 | int a = ergebniss;
463 | strcat (str, sub1);
464 | byte xxx = -350 - a - b - c - d;
465 | if (xxx == checksum)
466 | {
467 | hextodec(str);
468 | vic1_ppv_mppt = ergebniss / 100;
469 | }
470 | return;
471 | }
472 | if (strncmp(vic1_ser, ":A010200", 8) == 0)
473 | {
474 | char sub2[3] = "";
475 | strncpy(sub2, &vic1_ser[10], 2);
476 | sub2[2] = '\0';
477 | hextodec(sub2);
478 | int checksum = ergebniss;
479 | char sub1[3] = "";
480 | strncpy(sub1, &vic1_ser[8], 2);
481 | sub1[2] = '\0';
482 | hextodec(sub1);
483 | int a = ergebniss;
484 | byte xxx = 72 - a;
485 | if (xxx == checksum)
486 | {
487 | vic1_cs_mppt = ergebniss;
488 | }
489 | return;
490 | }
491 | if (strncmp(vic1_ser, ":7D3ED00", 8) == 0)
492 | {
493 | char str[5] = "";
494 | char sub3[3] = "";
495 | strncpy(sub3, &vic1_ser[12], 2);
496 | sub3[2] = '\0';
497 | hextodec(sub3);
498 | int checksum = ergebniss;
499 | char sub2[3] = "";
500 | strncpy(sub2, &vic1_ser[10], 2);
501 | sub2[2] = '\0';
502 | hextodec(sub2);
503 | int b = ergebniss;
504 | strcpy (str, sub2);
505 | char sub1[3] = "";
506 | strncpy(sub1, &vic1_ser[8], 2);
507 | sub1[2] = '\0';
508 | hextodec(sub1);
509 | int a = ergebniss;
510 | strcat (str, sub1);
511 | byte xxx = -370 - a - b;
512 | if (xxx == checksum)
513 | {
514 | hextodec(str);
515 | vic1_h20_mppt = ergebniss * 10;
516 | }
517 | return;
518 | }
519 | }
520 | //****************
521 | void vic2_auswerten()
522 | {
523 | if (strncmp(vic2_ser, ":AD5ED00", 8) == 0)
524 | {
525 | char str[5];
526 | char sub3[3] = "";
527 | strncpy(sub3, &vic2_ser[12], 2);
528 | sub3[2] = '\0';
529 | hextodec(sub3);
530 | int checksum = ergebniss;
531 | char sub2[3] = "";
532 | strncpy(sub2, &vic2_ser[10], 2);
533 | sub2[2] = '\0';
534 | hextodec(sub2);
535 | int b = ergebniss;
536 | strcpy (str, sub2);
537 | char sub1[3] = "";
538 | strncpy(sub1, &vic2_ser[8], 2);
539 | sub1[2] = '\0';
540 | hextodec(sub1);
541 | int a = ergebniss;
542 | strcat (str, sub1);
543 | byte xxx = -375 - a - b;
544 | if (xxx == checksum)
545 | {
546 | hextodec(str);
547 | vic2_v_mppt_r = ergebniss;
548 | vic2_v_mppt = ergebniss / 100.0;
549 | }
550 | return;
551 | }
552 | if (strncmp(vic2_ser, ":AD7ED00", 8) == 0)
553 | {
554 | char str[5];
555 | char sub3[3] = "";
556 | strncpy(sub3, &vic2_ser[12], 2);
557 | sub3[2] = '\0';
558 | hextodec(sub3);
559 | int checksum = ergebniss;
560 | char sub2[3] = "";
561 | strncpy(sub2, &vic2_ser[10], 2);
562 | sub2[2] = '\0';
563 | hextodec(sub2);
564 | int b = ergebniss;
565 | strcpy (str, sub2);
566 | char sub1[3] = "";
567 | strncpy(sub1, &vic2_ser[8], 2);
568 | sub1[2] = '\0';
569 | hextodec(sub1);
570 | int a = ergebniss;
571 | strcat (str, sub1);
572 | byte xxx = -377 - a - b;
573 | if (xxx == checksum)
574 | {
575 | hextodec(str);
576 | vic2_i_mppt = ergebniss / 10.0;
577 | }
578 | return;
579 | }
580 | if (strncmp(vic2_ser, ":ABBED00", 8) == 0)
581 | {
582 | char str[5];
583 | char sub3[3] = "";
584 | strncpy(sub3, &vic2_ser[12], 2);
585 | sub3[2] = '\0';
586 | hextodec(sub3);
587 | int checksum = ergebniss;
588 | char sub2[3] = "";
589 | strncpy(sub2, &vic2_ser[10], 2);
590 | sub2[2] = '\0';
591 | hextodec(sub2);
592 | int b = ergebniss;
593 | strcpy (str, sub2);
594 | char sub1[3] = "";
595 | strncpy(sub1, &vic2_ser[8], 2);
596 | sub1[2] = '\0';
597 | hextodec(sub1);
598 | int a = ergebniss;
599 | strcat (str, sub1);
600 | byte xxx = -349 - a - b;
601 | if (xxx == checksum)
602 | {
603 | hextodec(str);
604 | vic2_vpv_mppt = ergebniss / 100.0;
605 | }
606 | return;
607 | }
608 | if (strncmp(vic2_ser, ":ABCED00", 8) == 0)
609 | {
610 | digitalWrite(ledPin, HIGH);
611 | char str[9];
612 | char sub5[3] = "";
613 | strncpy(sub5, &vic2_ser[16], 2);
614 | sub5[2] = '\0';
615 | hextodec(sub5);
616 | int checksum = ergebniss;
617 | char sub4[3] = "";
618 | strncpy(sub4, &vic2_ser[14], 2);
619 | sub4[2] = '\0';
620 | hextodec(sub4);
621 | int d = ergebniss;
622 | strcpy (str, sub4);
623 | char sub3[3] = "";
624 | strncpy(sub3, &vic2_ser[12], 2);
625 | sub3[2] = '\0';
626 | hextodec(sub3);
627 | int c = ergebniss;
628 | strcat (str, sub3);
629 | char sub2[3] = "";
630 | strncpy(sub2, &vic2_ser[10], 2);
631 | sub2[2] = '\0';
632 | hextodec(sub2);
633 | int b = ergebniss;
634 | strcat (str, sub2);
635 | char sub1[3] = "";
636 | strncpy(sub1, &vic2_ser[8], 2);
637 | sub1[2] = '\0';
638 | hextodec(sub1);
639 | int a = ergebniss;
640 | strcat (str, sub1);
641 | byte xxx = -350 - a - b - c - d;
642 | if (xxx == checksum)
643 | {
644 | hextodec(str);
645 | vic2_ppv_mppt = ergebniss / 100;
646 | }
647 | digitalWrite(ledPin, LOW);
648 | return;
649 | }
650 | if (strncmp(vic2_ser, ":A010200", 8) == 0)
651 | {
652 | char sub2[3] = "";
653 | strncpy(sub2, &vic2_ser[10], 2);
654 | sub2[2] = '\0';
655 | hextodec(sub2);
656 | int checksum = ergebniss;
657 | char sub1[3] = "";
658 | strncpy(sub1, &vic2_ser[8], 2);
659 | sub1[2] = '\0';
660 | hextodec(sub1);
661 | int a = ergebniss;
662 | byte xxx = 72 - a;
663 | if (xxx == checksum)
664 | {
665 | vic2_cs_mppt = ergebniss;
666 | }
667 | return;
668 | }
669 | if (strncmp(vic2_ser, ":7D3ED00", 8) == 0)
670 | {
671 | char str[5];
672 | char sub3[3] = "";
673 | strncpy(sub3, &vic2_ser[12], 2);
674 | sub3[2] = '\0';
675 | hextodec(sub3);
676 | int checksum = ergebniss;
677 | char sub2[3] = "";
678 | strncpy(sub2, &vic2_ser[10], 2);
679 | sub2[2] = '\0';
680 | hextodec(sub2);
681 | int b = ergebniss;
682 | strcpy (str, sub2);
683 | char sub1[3] = "";
684 | strncpy(sub1, &vic2_ser[8], 2);
685 | sub1[2] = '\0';
686 | hextodec(sub1);
687 | int a = ergebniss;
688 | strcat (str, sub1);
689 | byte xxx = -370 - a - b;
690 | if (xxx == checksum)
691 | {
692 | hextodec(str);
693 | vic2_h20_mppt = ergebniss * 10;
694 | }
695 | return;
696 | }
697 | }
698 | //****************
699 | void vic3_auswerten()
700 | {
701 | if (strncmp(vic3_ser, ":78DED00", 8) == 0)
702 | {
703 | char str[5];
704 | char sub3[3] = "";
705 | strncpy(sub3, &vic3_ser[12], 2);
706 | sub3[2] = '\0';
707 | hextodec(sub3);
708 | int checksum = ergebniss;
709 | char sub2[3] = "";
710 | strncpy(sub2, &vic3_ser[10], 2);
711 | sub2[2] = '\0';
712 | hextodec(sub2);
713 | int b = ergebniss;
714 | strcpy (str, sub2);
715 | char sub1[3] = "";
716 | strncpy(sub1, &vic3_ser[8], 2);
717 | sub1[2] = '\0';
718 | hextodec(sub1);
719 | int a = ergebniss;
720 | strcat (str, sub1);
721 | byte xxx = -300 - a - b;
722 | if (xxx == checksum)
723 | {
724 | hextodec(str);
725 | vic3_v_bmv = ergebniss / 100.0;
726 | }
727 | return;
728 | }
729 | if (strncmp(vic3_ser, ":78CED00", 8) == 0)
730 | {
731 | char str[9];
732 | char sub5[3] = "";
733 | strncpy(sub5, &vic3_ser[16], 2);
734 | sub5[2] = '\0';
735 | hextodec(sub5);
736 | int checksum = ergebniss;
737 | char sub4[3] = "";
738 | strncpy(sub4, &vic3_ser[14], 2);
739 | sub4[2] = '\0';
740 | hextodec(sub4);
741 | int d = ergebniss;
742 | strcpy (str, sub4);
743 | char sub3[3] = "";
744 | strncpy(sub3, &vic3_ser[12], 2);
745 | sub3[2] = '\0';
746 | hextodec(sub3);
747 | int c = ergebniss;
748 | strcat (str, sub3);
749 | char sub2[3] = "";
750 | strncpy(sub2, &vic3_ser[10], 2);
751 | sub2[2] = '\0';
752 | hextodec(sub2);
753 | int b = ergebniss;
754 | strcat (str, sub2);
755 | char sub1[3] = "";
756 | strncpy(sub1, &vic3_ser[8], 2);
757 | sub1[2] = '\0';
758 | hextodec(sub1);
759 | int a = ergebniss;
760 | strcat (str, sub1);
761 | byte xxx = -299 - a - b - c - d;
762 | if (xxx == checksum)
763 | {
764 | hextodec(str);
765 | vic3_i_bmv = ergebniss / 1000.0;
766 | }
767 | return;
768 | }
769 | if (strncmp(vic3_ser, ":78EED00", 8) == 0)
770 | {
771 | char str[5];
772 | char sub3[3] = "";
773 | strncpy(sub3, &vic3_ser[12], 2);
774 | sub3[2] = '\0';
775 | hextodec(sub3);
776 | int checksum = ergebniss;
777 | char sub2[3] = "";
778 | strncpy(sub2, &vic3_ser[10], 2);
779 | sub2[2] = '\0';
780 | hextodec(sub2);
781 | int b = ergebniss;
782 | strcpy (str, sub2);
783 | char sub1[3] = "";
784 | strncpy(sub1, &vic3_ser[8], 2);
785 | sub1[2] = '\0';
786 | hextodec(sub1);
787 | int a = ergebniss;
788 | strcat (str, sub1);
789 | byte xxx = -301 - a - b;
790 | if (xxx == checksum)
791 | {
792 | hextodec(str);
793 | vic3_p_bmv = ergebniss;
794 | }
795 | return;
796 | }
797 | if (strncmp(vic3_ser, ":7100300", 8) == 0)
798 | {
799 | char str[9];
800 | char sub5[3] = "";
801 | strncpy(sub5, &vic3_ser[16], 2);
802 | sub5[2] = '\0';
803 | hextodec(sub5);
804 | int checksum = ergebniss;
805 | char sub4[3] = "";
806 | strncpy(sub4, &vic3_ser[14], 2);
807 | sub4[2] = '\0';
808 | hextodec(sub4);
809 | int d = ergebniss;
810 | strcpy (str, sub4);
811 | char sub3[3] = "";
812 | strncpy(sub3, &vic3_ser[12], 2);
813 | sub3[2] = '\0';
814 | hextodec(sub3);
815 | int c = ergebniss;
816 | strcat (str, sub3);
817 | char sub2[3] = "";
818 | strncpy(sub2, &vic3_ser[10], 2);
819 | sub2[2] = '\0';
820 | hextodec(sub2);
821 | int b = ergebniss;
822 | strcat (str, sub2);
823 | char sub1[3] = "";
824 | strncpy(sub1, &vic3_ser[8], 2);
825 | sub1[2] = '\0';
826 | hextodec(sub1);
827 | int a = ergebniss;
828 | strcat (str, sub1);
829 | byte xxx = 59 - a - b - c - d;
830 | if (xxx == checksum)
831 | {
832 | hextodec(str);
833 | vic3_h17_bmv = ergebniss / 100.0;
834 | }
835 | return;
836 | }
837 | if (strncmp(vic3_ser, ":7110300", 8) == 0)
838 | {
839 | char str[9];
840 | char sub5[3] = "";
841 | strncpy(sub5, &vic3_ser[16], 2);
842 | sub5[2] = '\0';
843 | hextodec(sub5);
844 | int checksum = ergebniss;
845 | char sub4[3] = "";
846 | strncpy(sub4, &vic3_ser[14], 2);
847 | sub4[2] = '\0';
848 | hextodec(sub4);
849 | int d = ergebniss;
850 | strcpy (str, sub4);
851 | char sub3[3] = "";
852 | strncpy(sub3, &vic3_ser[12], 2);
853 | sub3[2] = '\0';
854 | hextodec(sub3);
855 | int c = ergebniss;
856 | strcat (str, sub3);
857 | char sub2[3] = "";
858 | strncpy(sub2, &vic3_ser[10], 2);
859 | sub2[2] = '\0';
860 | hextodec(sub2);
861 | int b = ergebniss;
862 | strcat (str, sub2);
863 | char sub1[3] = "";
864 | strncpy(sub1, &vic3_ser[8], 2);
865 | sub1[2] = '\0';
866 | hextodec(sub1);
867 | int a = ergebniss;
868 | strcat (str, sub1);
869 | byte xxx = 58 - a - b - c - d;
870 | if (xxx == checksum)
871 | {
872 | hextodec(str);
873 | vic3_h18_bmv = ergebniss / 100.0;
874 | }
875 | return;
876 | }
877 | if (strncmp(vic3_ser, ":7060300", 8) == 0)
878 | {
879 | char str[9];
880 | char sub5[3] = "";
881 | strncpy(sub5, &vic3_ser[16], 2);
882 | sub5[2] = '\0';
883 | hextodec(sub5);
884 | int checksum = ergebniss;
885 | char sub4[3] = "";
886 | strncpy(sub4, &vic3_ser[14], 2);
887 | sub4[2] = '\0';
888 | hextodec(sub4);
889 | int d = ergebniss;
890 | strcpy (str, sub4);
891 | char sub3[3] = "";
892 | strncpy(sub3, &vic3_ser[12], 2);
893 | sub3[2] = '\0';
894 | hextodec(sub3);
895 | int c = ergebniss;
896 | strcat (str, sub3);
897 | char sub2[3] = "";
898 | strncpy(sub2, &vic3_ser[10], 2);
899 | sub2[2] = '\0';
900 | hextodec(sub2);
901 | int b = ergebniss;
902 | strcat (str, sub2);
903 | char sub1[3] = "";
904 | strncpy(sub1, &vic3_ser[8], 2);
905 | sub1[2] = '\0';
906 | hextodec(sub1);
907 | int a = ergebniss;
908 | strcat (str, sub1);
909 | byte xxx = 69 - a - b - c - d;
910 |
911 | if (xxx == checksum)
912 | {
913 | hextodec(str);
914 | vic3_h7_bmv = ergebniss / 100.0;
915 | }
916 | return;
917 | }
918 | if (strncmp(vic3_ser, ":7070300", 8) == 0)
919 | {
920 | char str[9];
921 | char sub5[3] = "";
922 | strncpy(sub5, &vic3_ser[16], 2);
923 | sub5[2] = '\0';
924 | hextodec(sub5);
925 | int checksum = ergebniss;
926 | char sub4[3] = "";
927 | strncpy(sub4, &vic3_ser[14], 2);
928 | sub4[2] = '\0';
929 | hextodec(sub4);
930 | int d = ergebniss;
931 | strcpy (str, sub4);
932 | char sub3[3] = "";
933 | strncpy(sub3, &vic3_ser[12], 2);
934 | sub3[2] = '\0';
935 | hextodec(sub3);
936 | int c = ergebniss;
937 | strcat (str, sub3);
938 | char sub2[3] = "";
939 | strncpy(sub2, &vic3_ser[10], 2);
940 | sub2[2] = '\0';
941 | hextodec(sub2);
942 | int b = ergebniss;
943 | strcat (str, sub2);
944 | char sub1[3] = "";
945 | strncpy(sub1, &vic3_ser[8], 2);
946 | sub1[2] = '\0';
947 | hextodec(sub1);
948 | int a = ergebniss;
949 | strcat (str, sub1);
950 | byte xxx = 68 - a - b - c - d;
951 | if (xxx == checksum)
952 | {
953 | hextodec(str);
954 | vic3_h8_bmv = ergebniss / 100.0;
955 | }
956 | return;
957 | }
958 | if (strncmp(vic3_ser, ":7FF0F00", 8) == 0)
959 | {
960 | char str[5];
961 | char sub3[3] = "";
962 | strncpy(sub3, &vic3_ser[12], 2);
963 | sub3[2] = '\0';
964 | hextodec(sub3);
965 | int checksum = ergebniss;
966 | char sub2[3] = "";
967 | strncpy(sub2, &vic3_ser[10], 2);
968 | sub2[2] = '\0';
969 | hextodec(sub2);
970 | int b = ergebniss;
971 | strcpy (str, sub2);
972 | char sub1[3] = "";
973 | strncpy(sub1, &vic3_ser[8], 2);
974 | sub1[2] = '\0';
975 | hextodec(sub1);
976 | int a = ergebniss;
977 | strcat (str, sub1);
978 | byte xxx = -192 - a - b;
979 | if (xxx == checksum)
980 | {
981 | hextodec(str);
982 | vic3_soc_bmv = ergebniss / 100.0;
983 | }
984 | return;
985 | }
986 | }
987 | //****************
988 | long hextodec(char*hdec)
989 | {
990 | ergebniss = 0;
991 | while (*hdec)
992 | {
993 | long onebyte = *hdec++;
994 | if (onebyte >= '0' && onebyte <= '9')
995 | {
996 | onebyte = onebyte - '0';
997 | }
998 | else if (onebyte >= 'a' && onebyte <= 'f')
999 | {
1000 | onebyte = onebyte - 'a' + 10;
1001 | }
1002 | else if (onebyte >= 'A' && onebyte <= 'F')
1003 | {
1004 | onebyte = onebyte - 'A' + 10;
1005 | }
1006 | ergebniss = (ergebniss << 4) | (onebyte & 0xF);
1007 | }
1008 | return ergebniss;
1009 | }
1010 | //********************
1011 | void ina_226()
1012 | {
1013 | shunt = readRegister(0x01);
1014 | if (shunt && 0x8000)
1015 | {
1016 | shunt = ~shunt;
1017 | shunt += 1;
1018 | shunt *= -1 ;
1019 | }
1020 | shunt_logger = shunt;
1021 | shunt = constrain(shunt, 3000, 17500);
1022 | p_map = (map(shunt, 3000, 17500, 0, 13000 )) / 10;
1023 | p_ueber = (p_map - vic2_ppv_mppt);
1024 | //p_ueber = constrain(p_ueber, 0, 1300);
1025 | }
1026 | //********************
1027 | void ueberschuss()
1028 | {
1029 | if (vic2_cs_mppt != 4 && vic2_cs_mppt != 5)
1030 | {
1031 | reset();
1032 | relais();
1033 | return;
1034 | }
1035 | if (vic2_cs_mppt == 4 && status_float == 0)
1036 | {
1037 | status_absorption = 0;
1038 | status_float = 1;
1039 | reset();
1040 | relais();
1041 | }
1042 | if (vic2_cs_mppt == 5 && status_absorption == 0)
1043 | {
1044 | status_absorption = 1;
1045 | status_float = 0;
1046 | reset();
1047 | relais();
1048 | }
1049 | if (zaehler < 120)
1050 | {
1051 | if (zaehler < 60)
1052 | {
1053 | messung_1 = samples1.getMedian();
1054 | mess = 1;
1055 | }
1056 | if (zaehler >= 60)
1057 | {
1058 | messung_2 = samples2.getMedian();
1059 | mess = 2;
1060 | }
1061 | samples1.add(vic2_v_mppt_r);
1062 | samples2.add(vic2_v_mppt_r);
1063 | zaehler++;
1064 | }
1065 | if (zaehler == 120)
1066 | {
1067 | mess = 3;
1068 | if (abs(messung_1 - messung_2) <= 3) //<<<<<----- 0.03 Volt
1069 | {
1070 | if (vic2_v_mppt_r > (min(messung_1, messung_2)) - 20) //<<<<<-----0.2 Volt
1071 | {
1072 | if (p_ueber > p_K1 && status_K2 == HIGH && status_K3 == HIGH && status_K4 == HIGH)
1073 | {
1074 | status_K1 = LOW;
1075 | }
1076 | if (p_ueber <= 0 && status_K2 == HIGH && status_K3 == HIGH && status_K4 == HIGH)
1077 | {
1078 | status_K1 = HIGH;
1079 | }
1080 | if (p_ueber > p_K2 && status_K1 == LOW && status_K3 == HIGH && status_K4 == HIGH)
1081 | {
1082 | status_K2 = LOW;
1083 | }
1084 | if (p_ueber <= 0 && status_K1 == LOW && status_K3 == HIGH && status_K4 == HIGH)
1085 | {
1086 | status_K2 = HIGH;
1087 | }
1088 | if (p_ueber > p_K3 && status_K1 == LOW && status_K2 == LOW && status_K4 == HIGH)
1089 | {
1090 | status_K3 = LOW;
1091 | }
1092 | if (p_ueber <= 0 && status_K1 == LOW && status_K2 == LOW && status_K4 == HIGH)
1093 | {
1094 | status_K3 = HIGH;
1095 | }
1096 | if (p_ueber > p_K4 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW)
1097 | {
1098 | status_K4 = LOW;
1099 | }
1100 | if (p_ueber <= 0 && regel == 0 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW)
1101 | {
1102 | status_K4 = HIGH;
1103 | up_down = 0;
1104 | }
1105 | if (p_ueber > 100 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW && status_K4 == LOW)
1106 | {
1107 | static unsigned long prev_millis;
1108 | if (millis() - prev_millis > 2000)
1109 | {
1110 | prev_millis = millis();
1111 | }
1112 | regel++;
1113 | up_down = 1;
1114 | }
1115 | if (p_ueber <= 20 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW && status_K4 == LOW)
1116 | {
1117 | regel--;
1118 | up_down = 2;
1119 | }
1120 | }
1121 | else
1122 | {
1123 | regel = regel - 2;
1124 | up_down = 2;
1125 | }
1126 | }
1127 | else
1128 | {
1129 | reset();
1130 | }
1131 | }
1132 | relais();
1133 | regel = constrain(regel, 0, 20);
1134 | }
1135 | //****************
1136 | void nulldurchgang()
1137 | {
1138 | //regel = 8;
1139 | if (counter == 20) counter = 0;
1140 | if (counter == 0) Status = 1;
1141 | if (counter == regel) Status = 0;
1142 | PORTA = (Status << PA0);
1143 | counter++;
1144 | }
1145 | //********************
1146 | void reset()
1147 | {
1148 | zaehler = 0;
1149 | messung_1 = 0;
1150 | messung_2 = 0;
1151 | mess = 0;
1152 | regel = 0;
1153 | up_down = 0;
1154 | status_K1 = HIGH;
1155 | status_K2 = HIGH;
1156 | status_K3 = HIGH;
1157 | status_K4 = HIGH;
1158 | }
1159 | //********************
1160 | void relais()
1161 | {
1162 | digitalWrite(K1, status_K1);
1163 | digitalWrite(K2, status_K2);
1164 | digitalWrite(K3, status_K3);
1165 | digitalWrite(K4, status_K4);
1166 | }
1167 | //********************
1168 | void thingspeak()
1169 | {
1170 | schalter++;
1171 | switch (schalter)
1172 | {
1173 | case 1: digitalWrite(sim900_pin, HIGH); break;
1174 | case 2: digitalWrite(sim900_pin, LOW); break;
1175 | case 22: Serial_SIM900.println(F("AT+CIPSHUT")); break;
1176 | case 24: Serial_SIM900.println(F("ATE0")); break;
1177 | case 26: Serial_SIM900.println(F("AT+CIPMUX=0")); break;
1178 | case 28: Serial_SIM900.println(F("AT+CSTT=\"internet\"")); break;
1179 | case 30: Serial_SIM900.println(F("AT+CIICR")); break;
1180 | case 32: Serial_SIM900.println(F("AT+CIFSR")); break;
1181 | case 34: Serial_SIM900.println(F("AT+CIPSPRT=0")); break;
1182 | case 36: Serial_SIM900.println(F("AT+CSQ")); break;
1183 | case 38: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break;
1184 | case 41: Serial_SIM900.println(F("AT+CIPSEND")); break;
1185 | case 43: daten1(); break;
1186 | case 45: Serial_SIM900.println((char)26); break;
1187 | case 53: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break;
1188 | case 56: Serial_SIM900.println(F("AT+CIPSEND")); break;
1189 | case 58: daten2(); break;
1190 | case 60: Serial_SIM900.println((char)26); break;
1191 | case 68: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break;
1192 | case 71: Serial_SIM900.println(F("AT+CIPSEND")); break;
1193 | case 73: daten3(); break;
1194 | case 75: Serial_SIM900.println((char)26); break;
1195 | case 83: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break;
1196 | case 86: Serial_SIM900.println(F("AT+CIPSEND")); break;
1197 | case 88: daten4(); break;
1198 | case 90: Serial_SIM900.println((char)26); break;
1199 | case 98:
1200 | schalter = 37;
1201 | if (error >= 1)
1202 | {
1203 | schalter = 21;
1204 | error = 0;
1205 | }
1206 | break;
1207 | }
1208 | }
1209 | //................
1210 | void daten1()
1211 | //MPPT 100/50 12 Volt
1212 | {
1213 | char v[10];
1214 | char i[10];
1215 | char vpv[10];
1216 | char ppv[10];
1217 | char h20[10];
1218 | char cs[10];
1219 |
1220 | dtostrf(vic1_v_mppt, 1, 2, v );
1221 | dtostrf(vic1_i_mppt, 1, 2, i );
1222 | dtostrf(vic1_vpv_mppt, 1, 2, vpv );
1223 | itoa(vic1_ppv_mppt, ppv, 10 );
1224 | itoa(vic1_h20_mppt, h20, 10 );
1225 | itoa(vic1_cs_mppt, cs, 10 );
1226 |
1227 | char daten1[180] = "GET http://api.thingspeak.com/update?api_key=MC6V8698TB8GXDS3&field1=";
1228 | strcat (daten1, v); //MPPT Spannung
1229 | strcat (daten1, "&field2=");
1230 | strcat (daten1, i); //MPPT Strom
1231 | strcat (daten1, "&field3=");
1232 | strcat (daten1, vpv); //PV Spannung
1233 | strcat (daten1, "&field4=");
1234 | strcat (daten1, ppv); //PV Leistung
1235 | strcat (daten1, "&field5=");
1236 | strcat (daten1, h20); //Wh/Tag
1237 | strcat (daten1, "&field6=");
1238 | strcat (daten1, cs); //Status
1239 | Serial_SIM900.println(daten1);
1240 | }
1241 | //................
1242 | void daten2()
1243 | //MPPT 100/50 24 Volt
1244 | {
1245 | char v[10];
1246 | char i[10];
1247 | char vpv[10];
1248 | char ppv[10];
1249 | char h20[10];
1250 | char cs[10];
1251 | char p_ueber_[10];
1252 | char regel_[10];
1253 |
1254 | dtostrf(vic2_v_mppt, 1, 2, v );
1255 | dtostrf(vic2_i_mppt, 1, 2, i );
1256 | dtostrf(vic2_vpv_mppt, 1, 2, vpv );
1257 | itoa(vic2_ppv_mppt, ppv, 10 );
1258 | itoa(vic2_h20_mppt, h20, 10 );
1259 | itoa(vic2_cs_mppt, cs, 10 );
1260 | itoa(p_ueber, p_ueber_, 10 );
1261 | itoa(regel, regel_, 10 );
1262 |
1263 | char daten2[180] = "GET http://api.thingspeak.com/update?api_key=5Y645SG09QQZ3NA8&field1=";
1264 | strcat (daten2, v); //MPPT Spannung
1265 | strcat (daten2, "&field2=");
1266 | strcat (daten2, i); //MPPT Strom
1267 | strcat (daten2, "&field3=");
1268 | strcat (daten2, vpv); //PV Spannung
1269 | strcat (daten2, "&field4=");
1270 | strcat (daten2, ppv); //PV Leistung
1271 | strcat (daten2, "&field5=");
1272 | strcat (daten2, h20); //Wh/Tag
1273 | strcat (daten2, "&field6=");
1274 | strcat (daten2, cs); //Status
1275 | strcat (daten2, "&field7=");
1276 | strcat (daten2, p_ueber_); // Überschuss Leistung
1277 | strcat (daten2, "&field8=");
1278 | strcat (daten2, regel_); // Last 0 - 255
1279 | Serial_SIM900.println(daten2);
1280 | }
1281 | //................
1282 | void daten3()
1283 | //BMV 702 24 Volt
1284 | {
1285 | char v[10];
1286 | char i[10];
1287 | char p[10];
1288 | char h18[10];
1289 | char h17[10];
1290 | char h8[10];
1291 | char h7[10];
1292 | char soc[10];
1293 |
1294 | dtostrf(vic3_v_bmv, 1, 2, v );
1295 | dtostrf(vic3_i_bmv, 1, 2, i );
1296 | itoa(vic3_p_bmv, p , 10 );
1297 | dtostrf(vic3_h18_bmv, 1, 2, h18 );
1298 | dtostrf(vic3_h17_bmv, 1, 2, h17 );
1299 | dtostrf(vic3_h8_bmv, 1, 2, h8 );
1300 | dtostrf(vic3_h7_bmv, 1, 2, h7 );
1301 | dtostrf(vic3_soc_bmv, 1, 2, soc );
1302 |
1303 | char daten3[180] = "GET http://api.thingspeak.com/update?api_key=XDJ604T15I5ZNIWS&field1=";
1304 | strcat (daten3, v); //BMV Spannung
1305 | strcat (daten3, "&field2=");
1306 | strcat (daten3, i); //BMV Strom
1307 | strcat (daten3, "&field3=");
1308 | strcat (daten3, p); //BMV Leistung
1309 | strcat (daten3, "&field4=");
1310 | strcat (daten3, h18); //KWH geladen
1311 | strcat (daten3, "&field5=");
1312 | strcat (daten3, h17); //KWH entladen
1313 | strcat (daten3, "&field6=");
1314 | strcat (daten3, h8); //höchste Spannung
1315 | strcat (daten3, "&field7=");
1316 | strcat (daten3, h7); //niedrigste Spannung
1317 | strcat (daten3, "&field8=");
1318 | strcat (daten3, soc); //SOC
1319 | Serial_SIM900.println(daten3);
1320 | }
1321 | //................
1322 | void daten4()
1323 | //BME 280 / SIM 900
1324 | {
1325 | char temperatur_[10];
1326 | char luftfeuchtigkeit_[10];
1327 | char luftdruck_[10];
1328 | char error_counter_[10];
1329 | char shunt_logger_[10];
1330 |
1331 | dtostrf(temperatur, 1, 2, temperatur_);
1332 | dtostrf(luftfeuchtigkeit, 1, 2, luftfeuchtigkeit_);
1333 | dtostrf(luftdruck, 1, 2, luftdruck_);
1334 | itoa(error_counter, error_counter_ , 10 );
1335 | itoa(shunt_logger, shunt_logger_ , 10 );
1336 |
1337 | char daten4[180] = "GET http://api.thingspeak.com/update?api_key=YNYKLGS425SLZ828&field1=";
1338 | strcat (daten4, temperatur_); //Temperatur
1339 | strcat (daten4, "&field2=");
1340 | strcat (daten4, luftfeuchtigkeit_); //Luftfeuchtigkeit
1341 | strcat (daten4, "&field3=");
1342 | strcat (daten4, luftdruck_); //Luftdruck
1343 | strcat (daten4, "&field4=");
1344 | strcat (daten4, error_counter_); //SIM 900 Error
1345 | strcat (daten4, "&field5=");
1346 | strcat (daten4, shunt_logger_); //Einstrahlung
1347 | Serial_SIM900.println(daten4);
1348 | }
1349 | //********************
1350 | void fest_display()
1351 | {
1352 | lcd.clear();
1353 |
1354 | lcd.setCursor (5, 0);
1355 | lcd.print(F("V"));
1356 | lcd.setCursor (13, 0);
1357 | lcd.print(F("A"));
1358 |
1359 | lcd.setCursor (5, 1);
1360 | lcd.print(F("V"));
1361 | lcd.setCursor (13, 1);
1362 | lcd.print(F("A"));
1363 |
1364 | lcd.setCursor (5, 2);
1365 | lcd.print(F("V"));
1366 | lcd.setCursor (13, 2);
1367 | lcd.print(F("A"));
1368 |
1369 | lcd.setCursor (5, 3);
1370 | lcd.print(F("W"));
1371 |
1372 | lcd.setCursor (18, 3);
1373 | lcd.write(0xdf); //Grad Zeichen
1374 | lcd.setCursor (19, 3);
1375 | lcd.print(F("C"));
1376 | }
1377 | //********************
1378 | void vic1_display()
1379 | {
1380 | lcd.setCursor (0, 0);
1381 | lcd.print(vic1_v_mppt);
1382 |
1383 | lcd.setCursor (9, 0);
1384 | if (vic1_i_mppt < 9.995) lcd.print(F(" "));
1385 | lcd.print(vic1_i_mppt, 1);
1386 |
1387 | lcd.setCursor (15, 0);
1388 | if (vic1_cs_mppt == 0) lcd.print(F("AUS "));
1389 | if (vic1_cs_mppt == 2) lcd.print(F("FAULT"));
1390 | if (vic1_cs_mppt == 3) lcd.print(F("BULK "));
1391 | if (vic1_cs_mppt == 4) lcd.print(F("ABS "));
1392 | if (vic1_cs_mppt == 5) lcd.print(F("FLOAT"));
1393 | if (vic1_cs_mppt == 7) lcd.print(F("EQU M"));
1394 | if (vic1_cs_mppt == 245) lcd.print(F("START"));
1395 | if (vic1_cs_mppt == 247) lcd.print(F("EQU A"));
1396 | if (vic1_cs_mppt == 252) lcd.print(F("EXT "));
1397 | }
1398 | //********************
1399 | void vic2_display()
1400 | {
1401 | lcd.setCursor (0, 1);
1402 | lcd.print(vic2_v_mppt);
1403 |
1404 | lcd.setCursor (9, 1);
1405 | if (vic2_i_mppt < 9.995) lcd.print(F(" "));
1406 | lcd.print(vic2_i_mppt, 1);
1407 |
1408 | lcd.setCursor (15, 1);
1409 | if (vic2_cs_mppt == 0) lcd.print(F("AUS "));
1410 | if (vic2_cs_mppt == 2) lcd.print(F("FAULT"));
1411 | if (vic2_cs_mppt == 3) lcd.print(F("BULK "));
1412 | if (vic2_cs_mppt == 4) lcd.print(F("ABS "));
1413 | if (vic2_cs_mppt == 5) lcd.print(F("FLOAT"));
1414 | if (vic2_cs_mppt == 7) lcd.print(F("EQU M"));
1415 | if (vic2_cs_mppt == 245) lcd.print(F("START"));
1416 | if (vic2_cs_mppt == 247) lcd.print(F("EQU A"));
1417 | if (vic2_cs_mppt == 252) lcd.print(F("EXT "));
1418 | }
1419 | //********************
1420 | void vic3_display()
1421 | {
1422 | lcd.setCursor (0, 2);
1423 | lcd.print(vic3_v_bmv);
1424 |
1425 | lcd.setCursor (7, 2);
1426 | if (abs(vic3_i_bmv) < 99.995) lcd.print(F(" "));
1427 | if (abs(vic3_i_bmv) < 9.995) lcd.print(F(" "));
1428 | if (vic3_i_bmv >= 0) lcd.print(F(" "));
1429 | lcd.print(vic3_i_bmv, 1);
1430 | }
1431 | //********************
1432 | void ueberschuss_display()
1433 | {
1434 | lcd.setCursor (15, 2);
1435 | if (mess == 0) lcd.print(F(" "));
1436 | if (mess == 1) lcd.print(F("MESS1"));
1437 | if (mess == 2) lcd.print(F("MESS2"));
1438 | if (mess == 3) lcd.print(F("UEBER"));
1439 |
1440 | lcd.setCursor (0, 3);
1441 | if (abs(p_ueber) < 1000) lcd.print(F(" "));
1442 | if (abs(p_ueber) < 100) lcd.print(F(" "));
1443 | if (abs(p_ueber) < 10) lcd.print(F(" "));
1444 | if (p_ueber >= 0) lcd.print(F(" "));
1445 | lcd.print(p_ueber);
1446 |
1447 | lcd.setCursor (7, 3);
1448 | if (regel < 100) lcd.print(F(" "));
1449 | if (regel < 10) lcd.print(F(" "));
1450 | lcd.print(regel);
1451 |
1452 | lcd.setCursor (10, 3);
1453 | if (up_down == 0) lcd.write(byte(0));
1454 | if (up_down == 1) lcd.write(byte(1));
1455 | if (up_down == 2) lcd.write(byte(2));
1456 | }
1457 | //********************
1458 | void bme280_display()
1459 | {
1460 | lcd.setCursor (12, 3);
1461 | if (abs(temperatur < 9.995)) lcd.print(F(" "));
1462 | if (temperatur >= 0) lcd.print(F(" "));
1463 | lcd.print(temperatur);
1464 | }
1465 | //********************
1466 | static void writeRegister(byte reg, word value)
1467 | {
1468 | Wire.beginTransmission(ina226_addr);
1469 | Wire.write(reg);
1470 | Wire.write((value >> 8) & 0xFF);
1471 | Wire.write(value & 0xFF);
1472 | Wire.endTransmission();
1473 | }
1474 | //********************
1475 | static word readRegister(byte reg)
1476 | {
1477 | word res = 0x0000;
1478 | Wire.beginTransmission(ina226_addr);
1479 | Wire.write(reg);
1480 | if (Wire.endTransmission() == 0)
1481 | {
1482 | if (Wire.requestFrom(ina226_addr, 2) >= 2)
1483 | {
1484 | res = Wire.read() * 256;
1485 | res += Wire.read();
1486 | }
1487 | }
1488 | return res;
1489 | }
1490 | //********************
1491 | void bme280()
1492 | {
1493 | temperatur = (bme.readTemperature());
1494 | luftfeuchtigkeit = (bme.readHumidity());
1495 | luftdruck = ((bme.readPressure() / 100.0F) + 12.8); //Luftdruck umgerechnet von 103m ueber Meereshoehe auf Meereshoehe
1496 | }
