1  | #include <Arduino.h>
2  |
3  | #include "analog2.h"
4  |
5  | // /home/christoph/.arduino15/packages/STMicroelectronics/hardware/stm32/2.3.0/libraries/SrcWrapper/src/stm32
6  | //  analog.cpp
7  | // /home/christoph/.arduino15/packages/STMicroelectronics/hardware/stm32/2.3.0/system/Drivers
8  |
9  | #ifdef __cplusplus
10  | extern "C" {
11  | #endif
12  | uint16_t adc_read_value2(PinName pin, uint32_t resolution);
13  | #ifdef __cplusplus
14  | }
15  | #endif
16  |
17  | #define CHANNEL 5 // PA0 -> A0
18  | //#define CHANNEL 6 // PA1 -> A1
19  | //#define CHANNEL 8 // PA3 -> A2
20  |
21  | // Initialize the ADC1 for single conversion mode
22  | void init_analog()
23  | {
24  |   // something is missing in the following initialization
25  |   // thererfore we need to call the HALL funktions
26  |   // tbd: find the missing register
27  |   // hint: the error might be in a missing clock initialization of the ADC
28  |   adc_read_value2(PA_0, 12);
29  |   // Enable clock for ADC
30  |   //SET_BIT(RCC->AHBENR, RCC_AHBENR_ADC12EN);
31  |   SET_BIT(RCC->AHB2ENR, RCC_AHB2ENR_ADCEN);
32  |
33  |   // Disable the ADC
34  |   if (READ_BIT(ADC1->ISR, ADC_ISR_ADRDY))
35  |   {
36  |     SET_BIT(ADC1->ISR, ADC_ISR_ADRDY);
37  |   }
38  |   if (READ_BIT(ADC1->CR, ADC_CR_ADEN))
39  |   {
40  |     SET_BIT(ADC1->CR, ADC_CR_ADDIS);
41  |   }
42  |
43  |   // Wait until ADC is disabled
44  |   while (READ_BIT(ADC1->CR, ADC_CR_ADEN));
45  |
46  |   // Enable ADC voltage regulator
47  |   MODIFY_REG(ADC1->CR, ADC_CR_ADVREGEN, 0);
48  |   //MODIFY_REG(ADC1->CR, ADC_CR_ADVREGEN, ADC_CR_ADVREGEN_0);
49  |   MODIFY_REG(ADC1->CR, ADC_CR_ADVREGEN, ADC_CR_ADVREGEN);
50  |   // Delay 1-2 ms
51  |   //delay_ms(2);
52  |   delay(2);
53  |
54  |   // ADC Clock = HCLK/4
55  |   //MODIFY_REG(ADC12_COMMON->CCR, ADC12_CCR_CKMODE, ADC12_CCR_CKMODE_0 + ADC12_CCR_CKMODE_1);
56  |   MODIFY_REG(ADC1_COMMON->CCR, ADC_CCR_CKMODE, ADC_CCR_CKMODE_0 + ADC_CCR_CKMODE_1);
57  |
58  |   // Single ended mode for all channels
59  |   WRITE_REG(ADC1->DIFSEL, 0);
60  |
61  |   // Start calibration for single ended mode
62  |   CLEAR_BIT(ADC1->CR, ADC_CR_ADCALDIF);
63  |   SET_BIT(ADC1->CR, ADC_CR_ADCAL);
64  |
65  |   // Wait until the calibration is finished
66  |   while (READ_BIT(ADC1->CR, ADC_CR_ADCAL));
67  |
68  |   // Clear the ready flag
69  |   SET_BIT(ADC1->ISR, ADC_ISR_ADRDY);
70  |
71  |   // Enable the ADC repeatedly until success (workaround from errata)
72  |   do
73  |   {
74  |     SET_BIT(ADC1->CR, ADC_CR_ADEN);
75  |   }
76  |   while (!READ_BIT(ADC1->ISR, ADC_ISR_ADRDY));
77  |
78  |   // Select software start trigger
79  |   MODIFY_REG(ADC1->CFGR, ADC_CFGR_EXTEN, 0);
80  |
81  |   // Select single conversion mode
82  |   CLEAR_BIT(ADC1->CFGR, ADC_CFGR_CONT);
83  |
84  |   // Set sample time to 32 cycles
85  |   MODIFY_REG(ADC1->SMPR1, ADC_SMPR1_SMP1, ADC_SMPR1_SMP1_2);
86  | }
87  |
88  | // Read from an analog input of ADC1
89  | uint32_t read_analog(uint32_t channel)
90  | {
91  |   // Number of channels to convert: 1
92  |   MODIFY_REG(ADC1->SQR1, ADC_SQR1_L, 0);
93  |   // Select the channel
94  |   MODIFY_REG(ADC1->SQR1, ADC_SQR1_SQ1, channel << ADC_SQR1_SQ1_Pos);
95  |   // Clear the finish flag
96  |   CLEAR_BIT(ADC1->ISR, ADC_ISR_EOC);
97  |   // Start a conversion
98  |   SET_BIT(ADC1->CR, ADC_CR_ADSTART);
99  |   // Wait until the conversion is finished
100  |   while (!READ_BIT(ADC1->ISR, ADC_ISR_EOC));
101  |   while (READ_BIT(ADC1->CR, ADC_CR_ADSTART));
102  |   // Return the lower 12 bits of the result
103  |   return ADC1->DR & 0b111111111111;
104  | }
105  |
106  | void speedTest()
107  | {
108  |   uint32_t n;
109  |   float value;
110  |
111  |   Serial.print("channel: ");
112  |   Serial.print((int)CHANNEL);
113  |   Serial.println("");
114  |
115  |   int32_t startTime = micros();
116  |
117  |   for (n = 0; n < 1000; n++)
118  |   {
119  |     read_analog(CHANNEL);
120  |   }
121  |
122  |   int32_t duration1000samples_us = micros() - startTime;
123  |
124  |   Serial.print("1000 samples duration: ");
125  |   Serial.print(duration1000samples_us); Serial.println("us");
126  |   Serial.print("samples per second: ");
127  |   Serial.println((int)(1000 / ((float)duration1000samples_us / 1e6)));
128  |
129  |   delay(5000);
130  | }
131  |
132  | void setup()
133  | {
134  |   Serial.begin(115200);
135  |
136  |   init_analog();
137  |   speedTest();
138  | }
139  |
140  | void loop()
141  | {
142  |   uint16_t v;
143  |   // uint16_t adc_read_value2(PinName pin, uint32_t resolution);
144  |   //v=adc_read_value2(PA_0, 12);
145  |   v = read_analog(CHANNEL);
146  |   Serial.println(v);
147  |   delay(1);
148  |
149  | }
